Changes between Version 68 and Version 69 of WKTRaster/SpecificationWorking01
- Dec 16, 2009, 1:25:52 PM (14 years ago)
v68 v69 203 203 204 204 The only difference with ST_Box2D(raster) is that ST_Envelope(raster) returns a geometry, not a BOX2D. 205 206 There is also a ticket (#348) related to this function: http://trac.osgeo.org/postgis/ticket/348 205 206 207 '''Implementation details''' 208 209 This function should be implemented as a SQL or a PL/pgSQL function looking like: 'SELECT ST_geometry(ST_Box2D(rast))' 210 211 There is already a ST_raster_envelope() function but this has actually the behavior of the ST_ConvexHull(raster, 'WITHNODATA') described below. There is also a ticket (#348) related to this function: http://trac.osgeo.org/postgis/ticket/348 207 212 208 213 '''ST_ConvexHull(raster) -> polygon geometry''' - Returns the minimum convex geometry that encloses every significant pixel from the raster. … … 210 215 By default the resulting polygon TAKES the NODATA values into account. The resulting polygon enclose only pixels having a significant value (different than the NODATA value). 211 216 212 A ST_ConvexHull(raster, 'WITHNODATA') variant SHOULD NOT TAKE the NODATA value into account. It generally returns a square or rectangle polygon that can be rotated or not depending on the rotation of the raster. If the raster is not rotated ST_ConvexHull(geometry, 'WITHNODATA') is (almost) equivalent to ST_Envelope(raster). 213 214 This variant should replace the actual ST_raster_envelope() function which is wrongly named. 215 217 Variant 1: ST_ConvexHull(raster, 'WITHNODATA') SHOULD NOT TAKE the NODATA value into account. It generally returns a square or rectangle polygon that can be rotated or not depending on the rotation of the raster. If the raster is not rotated ST_ConvexHull(geometry, 'WITHNODATA') is (almost) equivalent to ST_Envelope(raster). 216 218 217 219 '''Implementation details''' … … 219 221 The first variant (taking NODATA values into account) ST_ConvexHull(raster) could be roughly implemented with a SQL or PL/pgSQL function looking like 'SELECT ST_ConvexHull(ST_Shape(raster))'. For sure computing only the external edge (without considering eventual holes like ST_Shape() does) should be faster. This imply writing the equivalent of a more simple version of ST_Shape. 220 222 221 The second variant (not taking NODATA values into account) is 223 The second variant (not taking NODATA values into account) is actually already implemented by the ST_raster_envelope() function which is wrongly named. There is also a ticket (#348) related to this function: http://trac.osgeo.org/postgis/ticket/348 222 224 223 225 '''ST_Shape(raster) -> polygon geometry''' - Returns a geometry encomparsing every pixel having a significant value (different than the NODATA value).
