Changes between Version 57 and Version 58 of WKTRaster/SpecificationWorking01
- Dec 16, 2009, 10:27:37 AM (14 years ago)
v57 v58 191 191 '''Function definition for WKT Raster 0.1.6''' 192 192 193 '''ST_GetBBox(raster) -> polygon geometry''' - Replaced with ST_Envelope() since there is no equivalent function in PostGIS.194 195 193 '''ST_Envelope(raster) -> polygon geometry''' Returns the minimum bounding box for the supplied raster, as a geometry. If the raser is rotated, the envelope is a non-rotated box enclosing the rotated raster. 196 194 197 '''ST_Shape(raster) -> polygon geometry'''- Replaced with ST_ConvexHull(raster).198 199 195 '''ST_ConvexHull(raster) -> polygon geometry''' Returns the minimum convex geometry that encloses every pixel from the raster. 200 196 201 By default the resulting polygon take the NODATA values into account and enclose only pixels having a value different than the NODATA value. The ST_ConvexHull(raster, 'WITHNODATA') variant do not take the NODATA value into account and generally return a square or rectangle polygon that can be rotated or not. If the raster is not rotated ST_ConvexHull(geometry, 'WITHNODATA') is equivalent to ST_Envelope(raster). 197 By default the resulting polygon TAKES the NODATA values into account. The resulting polygon enclose only pixels actually having a value (different than the NODATA value). The ST_ConvexHull(raster, 'WITHNODATA') variant DO NOT TAKE the NODATA value into account. It generally returns a square or rectangle polygon that can be rotated or not depending on the rotation of the raster. If the raster is not rotated ST_ConvexHull(geometry, 'WITHNODATA') is (almost) equivalent to ST_Envelope(raster). 198 199 '''ST_Shape(raster) -> polygon geometry'''- Returns . 202 200 203 201 '''ST_AsPolygon(raster) -> polygon geometry set''' Returns a 202 203 ST_GetBBox(raster) is replaced with ST_Envelope() since there is no equivalent function in PostGIS. 204 204 205 205 206 '''ST_Intersects(raster|geometry, raster|geometry)'''[[BR]][[BR]]
