Changes between Version 32 and Version 33 of WKTRaster/SpecificationWorking01
- Jun 2, 2009, 6:51:32 AM (15 years ago)
v32 v33 42 42 '''-t''' <table> Name of destination table in with or without target schema specified. This parameter is REQUIRED. 43 43 44 45 44 '''OPTIONS:''' 46 45 … … 55 54 '''-o''' <file> Output file for generated SQL commands. If not specified, ''stdout'' is assumed. 56 55 57 '''-R''' Simply register the raster in the database. Absolute path to the raster and georeferencing informations are stored instead of the raster actual 58 data. 56 '''-R''' Simply register the raster in the database. Absolute path to the raster and georeferencing informations are stored instead of the raster actual data. 59 57 60 58 '''-F''' Add a "filename" column containing the original name of the loaded raster file.
