Changes between Version 16 and Version 17 of WKTRaster/SpecificationWorking01
- Apr 16, 2009, 8:08:22 AM (15 years ago)
v16 v17 146 146 147 147 ---- 148 Open Question:When exporting a multiband raster to JPEG, TIFF, PNG, SVG or KML, how should we specify the band number in the exporting function.148 '''Open Question:''' When exporting a multiband raster to JPEG, TIFF, PNG, SVG or KML, how should we specify the band number in the exporting function. 149 149 150 150 There is two options to select the band to convert from a multiband raster in all the RT_AsFormat functions. [[BR]] … … 171 171 172 172 ---- 173 Open Question:Is JPEG export limited to raster having 8 bit unsigned integer pixeltype (8BUI)?173 '''Open Question:''' Is JPEG export limited to raster having 8 bit unsigned integer pixeltype (8BUI)? 174 174 175 175 [http://www.gdal.org/frmt_jpeg.html See how GDAL do it]. It converts only 8 bits rasters. Should we do the same? … … 195 195 196 196 ---- 197 Open Question:Is JPEG export limited to raster having 1 or 3 bands?197 '''Open Question:''' Is JPEG export limited to raster having 1 or 3 bands? 198 198 199 199 [http://www.gdal.org/frmt_jpeg.html See how GDAL do it]. It converts only 1 or 3 band rasters. Should we do the same? In this case 1 band rasters would be exported as a greyscale JPEG having R G and B identical and 3 band rasters would be interpreted as R, G and B. … … 210 210 211 211 ---- 212 Open Question:What if we want to export only the first two band of a three band layer?212 '''Open Question:''' What if we want to export only the first two band of a three band layer? 213 213 214 214 Maybe we need a RT_RasterFromBands(band1,band2,etc...) to reconstitute a multiband raster from multiple sources (having the same width, height, pixelsize, etc...)
