Changes between Version 44 and Version 45 of WKTRaster/SpecificationFinal01
Show
09/03/10 13:32:21 (3 years ago)
pracine
  • WKTRaster/SpecificationFinal01
    v44 v45
    6060== '''Objective 0.1.6d - Being able to get all the properties of a raster (all the “Get” functions).''' ==
    6161
    62 '''ST_SRID(raster|geometry) -> integer'''[[BR]]
    63
    64 Return the SRID associated with the raster.
    65
    66 '''ST_Width(raster) -> integer'''[[BR]]
    67 Return the width of the raster.
    68
    69 '''ST_Height(raster) -> integer'''[[BR]]
    70 Return the height of the raster.
    71
    72 '''ST_PixelSizeX(raster) -> float64'''[[BR]]
    73 Return the georeference's X pixel size of the raster. [http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668 See].
    74
    75 '''ST_PixelSizeY(raster) -> float64'''[[BR]]
    76 Return the georeference's Y pixel size of the raster. [http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668 See].
    78 '''ST_RotationX(raster) -> float64'''[[BR]]
    79 Return the georeference's X rotation.
    80
    81 '''ST_RotationY(raster) -> float64'''[[BR]]
    82 Return the georeference's Y rotation. [http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668 See].
    83
    84 '''ST_UpperLeftX(raster) -> float64'''[[BR]]
    85 Return the georeference's X-coordinate of the upper left corner of the upper left pixel. [http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668 See].
    86
    87 '''ST_UpperLeftY(raster) -> float64'''[[BR]]
    88 Return the georeference's Y-coordinate of the upper left corner of the upper left pixel. [http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668 See].
    89
    90 '''ST_Georeference(raster, text) -> string'''[[BR]]
    91 Returns the georeference meta data in GDAL or ESRI format as commonly seen in a world file. For ESRI, [http://en.wikipedia.org/wiki/World_file see] for GDAL, [http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668  see].
    92
    93
    94 '''ST_NumBands(raster) -> integer'''[[BR]]
    95 Return the number of band included in the raster.
    96
    97 '''ST_BandPixelType(raster, integer) -> string'''[[BR]]
    98 Return the pixel type of the specified 1-based Nth band of raster. Band index is 1-based. The function returns one of the following values:
     62'''ST_SRID(raster|geometry) -> integer'''
     63
     64 Returns the SRID associated with the raster.
     65
     66'''ST_Width(raster) -> integer'''
     67
     68 Returns the width of the raster.
     69
     70'''ST_Height(raster) -> integer'''
     71
     72 Returns the height of the raster.
     73
     74'''ST_PixelSizeX(raster) -> float64'''
     75
     76 Returns the georeference's X pixel size of the raster. [http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668 See].
     78'''ST_PixelSizeY(raster) -> float64'''
     79
     80 Returns the georeference's Y pixel size of the raster. [http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668 See].
     81
     82'''ST_RotationX(raster) -> float64'''
     83
     84 Returns the georeference's X rotation.
     85
     86'''ST_RotationY(raster) -> float64'''
     87
     88 Returns the georeference's Y rotation. [http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668 See].
     89
     90'''ST_UpperLeftX(raster) -> float64'''
     91
     92 Returns the georeference's X-coordinate of the upper left corner of the upper left pixel. [http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668 See].
     93
     94'''ST_UpperLeftY(raster) -> float64'''
     95
     96 Returns the georeference's Y-coordinate of the upper left corner of the upper left pixel. [http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668 See].
     97
     98'''ST_Georeference(raster, text) -> string'''
     100 Returns the georeference meta data in GDAL or ESRI format as commonly seen in a world file. For ESRI, [http://en.wikipedia.org/wiki/World_file see] for GDAL, [http://www.gdal.org/classGDALDataset.html#f9593cc241e7d140f5f3c4798a43a668  see].
     101
     102
     103'''ST_NumBands(raster) -> integer'''
     104
     105 Returns the number of band included in the raster.
     106
     107'''ST_BandPixelType(raster, integer) -> string'''
     108
     109 Returns the pixel type of the specified 1-based Nth band of raster. Band index is 1-based. The function returns one of the following values:
    99110  * '''1BB''' - 1-bit boolean
    100111  * '''2BUI''' - 2-bit unsigned integer
    109120  * '''64BF''' - 64-bit float
    110121
    111 '''ST_BandNoDataValue(raster, integer) -> float32'''[[BR]]
    112 Return the !NoDataValue of the specified  1-based Nth band of raster. Band index is 1-based. The value is always returned as a float32 even if the pixel type is integer.
     122'''ST_BandNoDataValue(raster, integer) -> float32'''
     123
     124 Returns the !NoDataValue of the specified  1-based Nth band of raster. Band index is 1-based. The value is always returned as a float32 even if the pixel type is integer.
    113125
    114126----
    117129ST_Raster_to_box2d(raster) should be renamed ST_box2d(raster).
    118130
    119 '''ST_Box2D(raster) -> BOX2D''' - Returns a BOX2D representing the extent of the raster.
     131'''ST_Box2D(raster) -> BOX2D'''
     132
     133 Returns a BOX2D representing the extent of the raster.
    120134
    121135 If the raster is rotated, the result is a box2d enclosing the rotated raster.
    129143 This function replaces ST_Raster_to_box2d() and should be used for the "raster AS box2d" cast. It should also be used instead of ST_raster_envelope() when creating indexes in gdal2wktraster.py (to be tested).
    130144
    131 '''ST_ConvexHull(raster) -> polygon geometry''' - Returns the minimum convex geometry that encloses every pixel from the raster.
     145'''ST_ConvexHull(raster) -> polygon geometry'''
     146
     147 Returns the minimum convex geometry that encloses every pixel from the raster.
    132148
    133149 The resulting polygon DOES NOT TAKE the NODATA values into account. The resulting polygon enclose every pixel, even those containing NODATA values. The resulting polygon can be rotated or not depending on the rotation of the raster. If the raster is not rotated ST_ConvexHull(geometry) is (almost) equivalent to ST_Envelope(raster) (ST_Envelope floor the coordinates and hence add a little buffer around the raster).
    137153 This function is actually already implemented by the ST_raster_envelope() function which is wrongly named. There is also a ticket (#348) related to this function: http://trac.osgeo.org/postgis/ticket/348
    138154
    139 '''ST_Envelope(raster) -> polygon geometry''' - Returns the minimum bounding box for the supplied raster, as a geometry.
     155'''ST_Envelope(raster) -> polygon geometry'''
     156
     157 Returns the minimum bounding box for the supplied raster, as a geometry.
    140158
    141159 If the raster is rotated, the envelope is a non-rotated box enclosing the rotated raster.
    153171
    154172
    155 '''ST_Polygon(raster, integer) -> polygon geometry''' - Returns a geometry encomparsing every pixel having a significant value (different than the NODATA value) for the provided band.
     173'''ST_Polygon(raster, integer) -> polygon geometry'''
     174
     175 Returns a geometry encomparsing every pixel having a significant value (different than the NODATA value) for the provided band.
    156176
    157177 This polygon geometry might contain holes if some internal areas of the raster contain pixels with NODATA values.
    169189 This function could be roughly implemented as a SQL function looking like 'SELECT ST_Collect((ST_DumpAsPolygons(raster)).geom)'. For sure a more specialised version could be faster than ST_AsPolygon.
    170190
    171 '''ST_DumpAsPolygons(raster, integer) -> geomval set''' - Returns a set of "geomval" value, one for each contiguous group of pixel sharing the same value for the provided band.
     191'''ST_DumpAsPolygons(raster, integer) -> geomval set'''
     192
     193 Returns a set of "geomval" value, one for each contiguous group of pixel sharing the same value for the provided band.
    172194
    173195 This is a set-returning function (SRF). A "geomval" value is a complex type composed of a polygon geometry (one for each contiguous group of pixel sharing the same value) and the value associated with this geometry. These values are always returned as double precision number. The shape of each polygon follow pixels edges.
    200222[[Image(WKTRasterAsPolygon.gif)]]
    201223
    202 '''DumpAsWKTPolygons(raster, integer) -> wktgeomval set''' - Returns a set of "geomval" value, one for each group of pixel sharing the same value for the provided band.
     224'''DumpAsWKTPolygons(raster, integer) -> wktgeomval set'''
     225
     226 Returns a set of "geomval" value, one for each group of pixel sharing the same value for the provided band.
    203227
    204228 This is a set-returning function (SRF). A "wktgeomval " value is a complex type composed of a the wkt representation of a geometry (one for each group of pixel sharing the same value) and the value associated with this geometry. These values are always returned as a value of type double precision. The shape of each polygon follow pixels edges. Areas with NODATA values are not included in the resulting set.
    215239
    216240
    217 '''ST_Intersects(raster, integer, geometry) -> boolean''' - Returns TRUE if the geometry and the raster "spatially intersect" - (share any portion of space) and FALSE if they don't (they are disjoint).
     241'''ST_Intersects(raster, integer, geometry) -> boolean'''
     242
     243 Returns TRUE if the geometry and the raster "spatially intersect" - (share any portion of space) and FALSE if they don't (they are disjoint).
    218244
    219245 '''Variants'''
    247273 It might be faster to skip test 2) if this test is not signicantly faster than test 3).
    248274
    249 '''ST_Intersection(raster, integer, geometry) -> geometry''' - Returns a set of "geomval" value representing the shared portion of the geometry and the raster band areas sharing a common meaningfull values. The integer parameter is the band number of the raster.
     275'''ST_Intersection(raster, integer, geometry) -> geometry'''
     276
     277 Returns a set of "geomval" value representing the shared portion of the geometry and the raster band areas sharing a common meaningfull values. The integer parameter is the band number of the raster.
    250278
    251279 '''Variants'''
    281309
    282310'''ST_SetSRID(raster, integer)'''
    283  Set the spatial reference on the specified raster. This is the same as the ST_SetSRID function working on geometries.
     311
     312 Sets the spatial reference on the specified raster. This is the same as the ST_SetSRID function working on geometries.
    284313
    285314'''ST_SetPixelSize(raster, pixelsize)'''
    291320  2) ST_SetPixelSize(raster, xsize, ysize)
    292321
    293  Set the pixel size (cell size) on the specified raster. The base method sets the X and Y pixel size to the same value. Variant 2 sets the pixel sizes to the individually specified x and y sizes.
     322 Sets the pixel size (cell size) on the specified raster. The base method sets the X and Y pixel size to the same value. Variant 2 sets the pixel sizes to the individually specified x and y sizes.
    294323
    295324'''ST_SetBandNoDataValue(raster, band, value)'''
    296325
    297  Set the value that corresponds to NODATA in the given raster's band.
     326 Sets the value that corresponds to NODATA in the given raster's band.
    298327
    299328'''ST_SetGeoReference(raster, georef)'''
    305334  2) ST_SetGeoReference(raster, georef)
    306335
    307  Set the georeference fields of the raster (pixel size, skew, upper left location) all in one pass. The 'format' parameter is optional, and defaults to 'GDAL' georeference format if it is not specified.
     336 Sets the georeference fields of the raster (pixel size, skew, upper left location) all in one pass. The 'format' parameter is optional, and defaults to 'GDAL' georeference format if it is not specified.
    308337
    309338 If this function does not receive a georeference string with 6 parameters (or if one of the parameters is not numeric), it raises an exception "st_setgeoreference requires a string with 6 floating point values". If this method receives a NULL raster, it does nothing, and returns a NULL raster.
    311340'''ST_SetSkew(raster, skewx, skewy)'''
    312341
    313  Variants
     342 '''Variants'''
    314343
    315344  1) ST_SetSkew(raster, skewx, skewy)
    321350'''ST_SetUpperLeft(raster, left, top)'''
    322351
    323  Set the location of the upper left pixel (cell). The base method sets the X and Y coordinates to the individually specified left and top coordinates.
     352 Sets the location of the upper left pixel (cell). The base method sets the X and Y coordinates to the individually specified left and top coordinates.
    324353
    325354----
    328357
    329358
    330 '''Mostly changes to raster2pgsql.exe and ST_RasterFromText().'''[[BR]]
    331 '''ST_BandPath(raster, band) -> string'''[[BR]]
    332 Return the path of the filesystem raster associated with this band. The band does not contain any pixel value.
     359'''Changes to raster2pgsql.py'''
     360
     361'''ST_BandPath(raster, band) -> string'''
     362
     363 Return the path of the filesystem raster associated with this band. The band does not contain any pixel value.
    333364
    334365----
    335366== '''Objective 0.1.6h - Being able to quickly get metadata for raster and band.''' ==
    336367
    337 '''ST_Metadata(raster) -> record'''[[BR]]
    338 Returns all the metadata associated with a raster (upper left x, upper left y, width, height, pixelsize x, pixelsize y, skew x, skew y, srid, numbands in this order). Does not include any band metadata. If you want band metadata, add ST_BandMetadata(raster, integer) to your query.
    339
    340 It should be used like this: "SELECT (md).* FROM (SELECT ST_Metadata(rast) AS md FROM myrastertable) foo"
    341
    342 '''ST_BandMetadata(raster, integer) -> record'''[[BR]]
    343 Returns all the metadata associated with a raster band (pixeltype, has nodata value, nodata value, is stored out-db, path, in this order). Does not include embedding raster metadata. If you want embedding raster metadata, add ST_Metadata(raster) to your query.
    344
    345 It should be used like this: "SELECT (bmd).* FROM (SELECT ST_BandMetadata(rast) AS bmd FROM myrastertable) foo"
     368'''ST_Metadata(raster) -> record'''
     369
     370 Returns all the metadata associated with a raster (upper left x, upper left y, width, height, pixelsize x, pixelsize y, skew x, skew y, srid, numbands in this order). Does not include any band metadata. If you want band metadata, add ST_BandMetadata(raster, integer) to your query.
     371
     372 It should be used like this: "SELECT (md).* FROM (SELECT ST_Metadata(rast) AS md FROM myrastertable) foo"
     373
     374'''ST_BandMetadata(raster, integer) -> record'''
     375
     376 Returns all the metadata associated with a raster band (pixeltype, has nodata value, nodata value, is stored out-db, path, in this order). Does not include embedding raster metadata. If you want embedding raster metadata, add ST_Metadata(raster) to your query.
     377
     378 It should be used like this: "SELECT (bmd).* FROM (SELECT ST_BandMetadata(rast) AS bmd FROM myrastertable) foo"
    346379
    347380----
    348381== '''Objective 0.1.6i - Being able to easily convert world coordinates to raster coordinates.''' ==
    349382
    350 '''ST_World2RasterCoordX(rast raster, xw float8, yw float8)'''[[BR]]
    351 Returns the column number of the pixel covering the provided X and Y world coordinates.
    352 This function works even if the world coordinates are outside the raster extent.
    353
    354 '''ST_World2RasteCoordX(rast raster, xw float8)'''[[BR]]
    355 Returns the column number of the pixels covering the provided world X coordinate for a non-rotated raster.
    356 This function works even if the world coordinate is outside the raster extent.
    357 This function returns an error if the raster is rotated. In this case you must also provide a Y.
    358
    359 '''ST_World2RasterCoordX(rast raster, pt geometry)'''[[BR]]
    360 Returns the column number of the pixel covering the provided point geometry.
    361 This function works even if the point is outside the raster extent.
    362
    363 '''ST_World2RasterCoordY(rast raster, xw float8, yw float8)'''[[BR]]
    364 Returns the row number of the pixel covering the provided X and Y world coordinates.
    365 This function works even if the world coordinates are outside the raster extent.
    366
    367 '''ST_World2RasterCoordY(rast raster, yw float8)'''[[BR]]
    368 Returns the row number of the pixels covering the provided world Y coordinate for a non-rotated raster.
    369 This function works even if the world coordinate is outside the raster extent.
    370 This function returns an error if the raster is rotated. In this case you must also provide an X.
    371
    372 '''ST_World2RasterCoordY(rast raster, pt geometry)'''[[BR]]
    373 Returns the row number of the pixel covering the provided point geometry.
    374 This function works even if the point is outside the raster extent.
    375
    376 '''ST_Raster2WorldCoordX(rast raster, xr int, yr int)'''[[BR]]
    377 Returns the X world coordinate of the upper left corner of the pixel located at the provided column and row numbers.
    378 This function works even if the provided raster column and row are beyond or below the raster width and height.
    379
    380
    381 '''ST_Raster2WorldCoordX(rast raster, xr int)'''[[BR]]
    382 Returns the X world coordinate of the upper left corner of the pixel located at the provided column number for a non-rotated raster.
    383 This function works even if the provided raster column is beyond or below the raster width.
    384 This function returns an error if the raster is rotated. In this case you must also provide a Y.
    385
    386 '''ST_Raster2WorldCoordY(rast raster, xr int, yr int)'''[[BR]]
    387 Returns the Y world coordinate of the upper left corner of the pixel located at
    388 the provided column and row numbers.
    389 This function works even if the provided raster column and row are beyond or below the raster width and height.
    390
    391 '''ST_Raster2WorldCoordY(rast raster, yr int)'''[[BR]]
    392 Returns the Y world coordinate of the upper left corner of the pixel located at the provided row number for a non-rotated raster.
    393 This function works even if the provided raster row is beyond or below the raster height.
    394 This function returns an error if the raster is rotated. In this case you must
    395 also provide an X.
     383'''ST_World2RasterCoordX(rast raster, xw float8, yw float8)'''
     384
     385 Returns the column number of the pixel covering the provided X and Y world coordinates.
     386
     387 This function works even if the world coordinates are outside the raster extent.
     388
     389'''ST_World2RasteCoordX(rast raster, xw float8)'''
     390
     391 Returns the column number of the pixels covering the provided world X coordinate for a non-rotated raster.
     392
     393 This function works even if the world coordinate is outside the raster extent. It returns an error if the raster is rotated. In this case you must also provide a Y.
     394
     395'''ST_World2RasterCoordX(rast raster, pt geometry)'''
     396
     397 Returns the column number of the pixel covering the provided point geometry.
     398
     399 This function works even if the point is outside the raster extent.
     400
     401'''ST_World2RasterCoordY(rast raster, xw float8, yw float8)'''
     402
     403 Returns the row number of the pixel covering the provided X and Y world coordinates.
     404
     405 This function works even if the world coordinates are outside the raster extent.
     406
     407'''ST_World2RasterCoordY(rast raster, yw float8)'''
     408
     409 Returns the row number of the pixels covering the provided world Y coordinate for a non-rotated raster.
     410
     411 This function works even if the world coordinate is outside the raster extent. It returns an error if the raster is rotated. In this case you must also provide an X.
     412
     413'''ST_World2RasterCoordY(rast raster, pt geometry)'''
     414
     415 Returns the row number of the pixel covering the provided point geometry.
     416
     417 This function works even if the point is outside the raster extent.
     418
     419'''ST_Raster2WorldCoordX(rast raster, xr int, yr int)'''
     420
     421 Returns the X world coordinate of the upper left corner of the pixel located at the provided column and row numbers.
     422
     423 This function works even if the provided raster column and row are beyond or below the raster width and height.
     424
     425
     426'''ST_Raster2WorldCoordX(rast raster, xr int)'''
     427
     428 Returns the X world coordinate of the upper left corner of the pixel located at the provided column number for a non-rotated raster.
     429
     430 This function works even if the provided raster column is beyond or below the raster width. It returns an error if the raster is rotated. In this case you must also provide a Y.
     431
     432'''ST_Raster2WorldCoordY(rast raster, xr int, yr int)'''
     433
     434 Returns the Y world coordinate of the upper left corner of the pixel located at the provided column and row numbers.
     435
     436 This function works even if the provided raster column and row are beyond or below the raster width and height.
     437
     438'''ST_Raster2WorldCoordY(rast raster, yr int)'''
     439
     440 Returns the Y world coordinate of the upper left corner of the pixel located at the provided row number for a non-rotated raster.
     441
     442 This function works even if the provided raster row is beyond or below the raster height. It returns an error if the raster is rotated. In this case you must also provide an X.
    396443
    397444----
