Changes between Version 34 and Version 35 of WKTRaster/SpecificationFinal01
Aug 27, 2010, 1:13:46 PM (14 years ago)
pracine
  • WKTRaster/SpecificationFinal01
    v34 v35
    293293
    294294----
     295== '''Objective 0.1.6f - Being able to set all the properties of a raster.''' ==
     296
     297
     298'''ST_SetSRID(raster, integer)'''
     299 Set the spatial reference on the specified raster. This is the same as the ST_SetSRID function working on geometries.
     300
     301'''ST_SetPixelSize(raster, pixelsize)'''
     302
     303 Variant 1: ST_SetPixelSize(raster, xsize, ysize)
     304
     305 Set the pixel size (cell size) on the specified raster. The base method sets the X and Y pixel size to the same value. The first variant sets the pixel sizes to the individually specified x and y sizes.
     306
     307'''ST_SetBandNoDataValue(raster, band, value)'''
     308
     309 Set the value that corresponds to NODATA in the given raster's band.
     310
     311'''ST_BandHasNoDataValue(raster, band)'''
     312
     313 Return true if the value stored as a NODATA value for the band must be interpreted as a real NODATA value.
     314
     315'''ST_SetBandHasNoDataValue(raster, band)'''
     316
     317 Set the band NODATA value as a real NODATA value.
     318
     319'''ST_SetGeoReference(raster, georef)'''
     320
     321 Variant 1: ST_SetGeoReference(raster, georef, format)
     322
     323 Set the georeference fields of the raster (pixel size, skew, upper left location) all in one pass. The 'format' parameter is optional, and defaults to 'GDAL' georeference format if it is not specified.
     324
     325 If this function does not receive a georeference string with 6 parameters (or if one of the parameters is not numeric), it raises an exception "st_setgeoreference requires a string with 6 floating point values". If this method receives a NULL raster, it does nothing, and returns a NULL raster.
     326
     327'''ST_SetSkew(raster, skewx, skewy)'''
     328
     329 Variant 1: ST_SetSkew(raster, skew)
     330
     331 Set the skewx and the skewy of the raster's georeference. Variant 1 sets the X and Y skew to the same value.
     332
     333'''ST_SetUpperLeft(raster, left, top)'''
     334
     335 Set the location of the upper left pixel (cell). The base method sets the X and Y coordinates to the individually specified left and top coordinates.
     336
     337----
     338
    295339== '''Objective 0.1.6g - Being able to register TIFF and JPEG tiles as raster stored outside the database.''' ==
    296340
