Changes between Version 30 and Version 31 of WKTRaster/SpecificationFinal01
- Aug 27, 2010, 12:22:05 PM (14 years ago)
v30 v31 170 170 Variant 1: ST_DumpAsPolygons(raster) -> geomval set -- default to band # 1 171 171 172 This function should be used with precaution on raster with float pixel type as it could return one "geomval" (or polygon) per pixel. This kind of raster should be reclassified (using the planned ST_Reclass ify(raster,...) function) before using ST_DumpAsPolygons().172 This function should be used with precaution on raster with float pixel type as it could return one "geomval" (or polygon) per pixel. This kind of raster should be reclassified (using the planned ST_Reclass(raster,...) function) before using ST_DumpAsPolygons(). 173 173 174 174 '''Implementation details''' … … 193 193 '''DumpAsWKTPolygons(raster, integer) -> wktgeomval set''' - Returns a set of "geomval" value, one for each group of pixel sharing the same value for the provided band. 194 194 195 Variant 1: DumpAsWKTPolygons(raster) -> wktgeomval set -- default to band # 1196 197 195 This is a set-returning function (SRF). A "wktgeomval " value is a complex type composed of a the wkt representation of a geometry (one for each group of pixel sharing the same value) and the value associated with this geometry. These values are always returned as a value of type double precision. The shape of each polygon follow pixels edges. Areas with NODATA values are not included in the resulting set. 198 196 199 This function should be used with precaution on raster with float pixel type as it could return one "geomval" (or polygon) per pixel. This kind of raster should be reclassified (using the planned ST_Reclass ify(raster,...) function) before using DumpAsWKTPolygons().197 This function should be used with precaution on raster with float pixel type as it could return one "geomval" (or polygon) per pixel. This kind of raster should be reclassified (using the planned ST_Reclass(raster,...) function) before using DumpAsWKTPolygons(). 200 198 201 199 DumpAsWKTPolygons() should not be used directly. Use ST_DumpAsPolygons() instead.
