Changes between Version 36 and Version 37 of WKTRaster/GDALDriverSpecificationWorking
- Jun 28, 2011, 10:05:49 AM (13 years ago)
v36 v37 77 77 '''Pierre comment''': I think the driver should not try to detect bad raster arrangement with SQL queries. It should just get what it needs from the DB and burn rasters tiles as they come. If it detected that the arrangement is regular then burn them as regular. If they are not, then burn them accordingly. 78 78 79 '''Jorge comment''': What does ''accordingly'' mean here? My bet: if the user wants ONE_RASTER_PER_ROW, no problem. Burn one raster file for each tile. If the user wants ONE_RASTER_PER_TABLE and the tiles are not regular, the driver may warn the user and abort or force ONE_RASTER_PER_ROW mode (warning the user first). Any other options? 79 '''Jorge comment''': What does ''accordingly'' mean here? My bet: if the user wants ONE_RASTER_PER_ROW, no problem. Burn one raster file for each tile. If the user wants ONE_RASTER_PER_TABLE and the tiles are not regular, the driver may warn the user and abort or force ONE_RASTER_PER_ROW mode (warning the user first). Any other options? 80 81 Pierre's response: Accordingly to their geolocation. 1) create an empty raster buffer the size of the whole query area 2)you query all the raster rows (tiles) you need 3) write pixel values from those tiles to the correct location (deduced from the georeference) in the buffer one after the other. That they are regularly tiled or not does not matter. Just write the last raster last, overwriting existing underlapping values. 80 82 81 83 * Call the functions limiting the output to one result. Fast operation, but may be incorrect … … 83 85 '''Pierre comment''': What might be incorrect? There should not be different srid, pixeltype, or pixelsize in the same table. We have have to warn that we do not support this bad arrangement yet. 84 86 85 '''Jorge comment''': Related with the previous comment, we could simply warn the user about using that band arrangement and maybe force the ONE_RASTER_PER_ROW arrangement instead.87 '''Jorge comment''': Related with the previous comment, we could simply warn the user about using that band arrangement and maybe force the ONE_RASTER_PER_ROW arrangement instead. 86 88 87 89 Currently, the driver takes the first (and slow) option. That caused performance problems (see ticket #497)
