Changes between Version 2 and Version 3 of WKTRaster/GDALDriverSpecificationWorking
- Feb 17, 2011, 1:57:31 PM (13 years ago)
v2 v3 18 18 The driver is: 19 19 * Able to read in-db evenly blocked rasters (all blocks with same size) 20 20 21 * Able to read in-db one-row-rasters: 22 21 23 - If the table really has more than one row: using -where clause in connection string 24 22 25 - If the table has more than one row: the table must have been marked as "regularly blocked table", with -k in loader 23 * Able to manage two working modes: 26 27 * Able to produce generate two kind of raster object based on two modes: 28 24 29 - ONE_RASTER_PER_ROW ('mode = 1' in connection string, or nothing): The default mode. Each table row is considered as an independent raster. If the table required has more than one row, and no -where clause has been specified in connection string, all the table rows will be considered as reported as Subdatasets. Unless you specify the other working mode 30 25 31 - ONE_RASTER_PER_TABLE ('mode = 2' in connection string): Each table is considered as a raster coverage, and each row is a raster tile. 32 26 33 * Too slow (Reads the entire table metadata for constructing the [http://www.gdal.org/classGDALDataset.html GDALDataset object], and needs one server round per [http://www.gdal.org/classGDALRasterBand.html GDALRasterBand::IReadBlock] call) 27 34
