Changes between Version 10 and Version 11 of WKTRaster/GDALDriverSpecificationWorking
Feb 17, 2011, 2:31:15 PM (13 years ago)
pracine
  • WKTRaster/GDALDriverSpecificationWorking
    v10 v11
    6969The metadata must be read from the raster table, using SQL functions like ST_Extent (used for raster data extent), ST_Metadata (used for general raster metadata) or functions like ST_SRID, ST_Width, ST_Height, etc. When your GDALDataset matches only one raster row (a raster tile) this is not a problem. But when your GDALDataset matches a whole raster table (ONE_RASTER_PER_TABLE mode), you have 2 options:
    7070  * Call the functions over the whole table and filter the result (i.e.: select distinct st_srid(rast) from raster_table, select distinct st_metadata(rast) from raster table). It can be a really slow operation, but you can check if all tiles are like expected (for example: if they are the same size, if they share the same srid, if they overlap or not, etc)
     71
     72 Pierre: I think the driver should not try to detect bad raster arrangement with SQL queries. It should just get what it needs from the DB and burn rasters tiles as they come.
     73
    7174  * Call the functions limiting the output to one result. Fast operation, but may be incorrect
    7275
