Changes between Version 97 and Version 98 of WKTRaster/Documentation01
- Apr 27, 2010, 11:40:29 AM (14 years ago)
v97 v98 183 183 1. Compile PostGIS [wiki:UsersWikiWinCompile using these instructions]. 184 184 185 2. Get GDAL 1.7.1 sources from [http://trac.osgeo.org/gdal/wiki/DownloadSource] and extract (you need this for advanced features like ST_DumpAsPolygons) 186 187 3. Build gdal make sure to build without libtool. Refer to [http://trac.osgeo.org/gdal/ticket/3465]. 188 ALSO '''NOTE:''' It compiles and binds, but ST_DumpAsPolygons crashes and so do the regression tests involving GDAL. Will try to build as static. 185 2. Get GDAL 1.7.1 sources from [http://trac.osgeo.org/gdal/wiki/DownloadSource] and extract (you need this for advanced features like ST_DumpAsPolygons). 186 187 3. Build GDAL without libtool. Refer to [http://trac.osgeo.org/gdal/ticket/3465]. 189 188 190 189 {{{ 191 190 cd /c/projects/GDAL/gdal-1.7.1 192 ./configure --without-libtool --with-libtiff=internal --with-libz=/c/gtk/include --prefix=/c/projects/GDAL/rel-1.7.1 191 ./configure --without-libtool --with-libtiff=internal --with-libz=/c/gtk/include 192 }}} 193 194 Edit /c/thesrc/gdal/gdal-1.7.1/GNUMakefile so that GDAL_OBJ is assigned this way: 195 196 GDAL_OBJ = ./frmts/o/*.o \[[BR]] 197 ./gcore/*.o \[[BR]] 198 ./port/*.o \[[BR]] 199 ./alg/*.o 200 201 {{{ 193 202 make clean && make 194 203 make install 195 strip /c/projects/GDAL/rel-1.7.1/lib/libgdal.dll 196 cp /c/projects/GDAL/rel-1.7.1/lib/libgdal.dll /c/postgres/bin/ 204 }}} 205 206 libgdal.dll should now exist in /usr/local/lib 207 208 {{{ 209 strip /usr/local/lib/libgdal.dll 197 210 }}} 198 211
