Changes between Version 4 and Version 5 of UsersWikiWinCompileWithgui
- 07/12/09 11:02:14 (4 years ago)
v4 v5 1 Before you can install PostGIS 1.4 with the slick graphical interface for shp2pgsql, you need to install GTK++ 2.8 or above. This is still a work in progress -- since I got as far as getting it to compile to .o but failed at the linker when linking all the .os.1 Before you can compile PostGIS 1.4 with the slick graphical interface for shp2pgsql, you need to install GTK++ 2.8 or above. This is still a work in progress -- since I got as far as getting it to compile to .o but failed at the linker when linking all the .os to make the exe. 2 2 3 3 (If you got to this page before reading full install -- refer to [UsersWikiWinCompile Compiling PostGIS under Windows (basic)] 4 4 '''1. Install GTK++ Bundle''' 5 5 6 1. Download GTK++ bundle described on this page http://www.gtk.org/download-windows.html. 6 7
