Changes between Version 88 and Version 89 of UsersWikiWinCompile
Show
11/23/09 16:51:39 (4 years ago)
pramsey
  • UsersWikiWinCompile
    v88 v89
    5151Run each file and be sure to change the install directory to c:\MinGW
    5252
    53 == 5. Installing LibIconf ==
    54
    55 For iconv we are going to compile our own instead of install from GNUWin since GNUWin changed some constants.
    56
    57   1. download source from http://ftp.gnu.org/gnu/libiconv (we are going to use libiconv-1.13.1.tar.gz)
    58   2. gzip -d -c libiconv-1.13.1.tar.gz | tar xvf -
    59   3. cd libiconv-1.13.1
    60   4. ./configure --prefix=/c/mingw
    61   5. make && make install
    62   6.  verify you are running the latest with --  iconv --version
    63
    64 == 6. Update m4 ==
     53== 5. Update m4 ==
    6554
    6655 1. download from: http://downloads.sourceforge.net/mingw/m4-1.4.7-MSYS.tar.bz2
    6756 2. untar and copy the m4.exe-file in the end of the path to C:\msys\1.0\bin
    6857
    69 == 7. Update environment variables ==
     58== 6. Update environment variables ==
    7059
    7160The below is copied direct from http://www.mingw.org/wiki/HOWTO_Install_the_MinGW_GCC_Compiler_Suite#toc33
    8574
    8675Set the environment variable HOME to C:\msys\1.0\home
     76
     77== 7. Installing !LibIconv ==
     78
     79For iconv we are going to compile our own copy instead of installing from GNUWin.
     80
     81 * http://ftp.gnu.org/gnu/libiconv/libiconv-1.13.1.tar.gz
     82
     83Save the source in your C:\thesrc directory. Open up the MSYS terminal.
     84{{{
     85# cd /c/thesrc
     86# tar xvfz libiconv-1.13.1.tar.gz
     87# cd libiconv-1.13.1
     88# ./configure --prefix=/c/mingw
     89# make
     90# make install
     91}}}
     92Verify you are running the latest version of iconv
     93{{{
     94# iconv --version
     95}}}
    8796
    8897== 8. Installing Autoconf, Automake and Libtool ==
