Changes between Version 76 and Version 77 of UsersWikiWinCompile
- Sep 20, 2009, 2:44:14 PM (15 years ago)
UsersWikiWinCompile
v76 v77 193 193 strip /c/postgres/bin/libgeos-3-1-1.dll 194 194 195 NOTE: If you are compiling the latest GEOS (geos/trunk, you may get an error because of a bug in MingW). 195 NOTE: If you are compiling the latest GEOS 3.2 (geos/trunk, you may get an error because of a bug in MingW). GEOS 3.2 is needed 196 to take advantage of the new ST_Buffer enhancements in PostGIS 1.5+ and also some fixes for topology exceptions in intersects and intersection. 196 197 197 198 I had to comment out like below -- change lines (159, 166) to below (in C:\MinGW\include\c++\3.4.5\cwchar (same issue exists under gcc 4.4.0)
