Changes between Version 105 and Version 106 of UsersWikiWinCompile
- Dec 11, 2009, 11:35:37 AM (14 years ago)
UsersWikiWinCompile
v105 v106 291 291 # make check 292 292 }}} 293 For the "make check" to work the server must be accepting connectionon port 5432 (the default) and your Windows account must be recognized as a role in the database.293 For the "make check" to work the server must be running and accepting connections on port 5432 (the default) and your Windows account must be recognized as a role in the database. 294 294 295 295 If you run into problems with your build, pipe the output into a file for further analysis. The GUI requires that pkg-config be on your PATH, check that it is there by running 'which pkg-config'.
