Changes between Version 104 and Version 105 of UsersWikiWinCompile
- Dec 11, 2009, 11:34:49 AM (14 years ago)
UsersWikiWinCompile
v104 v105 291 291 # make check 292 292 }}} 293 For the "make check" to work the server must be accepting connection on port 5432 (the default) and your Windows account must be recognized as a role in the database. 294 293 295 If you run into problems with your build, pipe the output into a file for further analysis. The GUI requires that pkg-config be on your PATH, check that it is there by running 'which pkg-config'. 294 296 {{{
