Changes between Version 100 and Version 101 of UsersWikiWinCompile
Show
12/08/09 14:04:47 (3 years ago)
pramsey
  • UsersWikiWinCompile
    v100 v101
    262262}}}
    263263
    264 == 14. Compiling PostGIS ==
     264== 14. Install GTK+ Bundle ==
     265
     266If you are compiling the shp2pgsql-gui program, you will need the GTK+ bundle.
     267
     268* http://www.gtk.org/download-windows.html
     269* http://ftp.gnome.org/pub/gnome/binaries/win32/gtk+/2.16/gtk+-bundle_2.16.6-20091013_win32.zip
     270
     271Unzip the bundle in c:\gtkbundle and then alter the system PATH so that c:\gtkbundle\bin is in the PATH.
     272
     273== 15. Compiling PostGIS ==
    265274
    266275=== PostGIS 1.4 ===
    274283      --with-pgconfig=/c/postgresql/bin/pg_config \
    275284      --with-geosconfig=/c/postgresql/bin/geos-config \
    276       --with-projdir=/c/postgresql
     285      --with-projdir=/c/postgresql \
     286      --with-gui
    277287# export PATH=/c/postgres/bin:$PATH
    278288# make clean
    281291# make check
    282292}}}
    283 If you run into problems with your build, pipe the output into a file for further analysis.
     293If you run into problems with your build, pipe the output into a file for further analysis. The GUI requires that pkg-config be on your PATH, check that it is there by running 'which pkg-config'.
    284294{{{
    285295# make 2>&1 | tee /c/build.log
