Changes between Version 7 and Version 8 of UsersWikiSimplifyPreserveTopology
- 04/08/12 07:26:16 (14 months ago)
v7 v8 148 148 select gid, code_dept, (st_dump(geom)).* 149 149 from departement 150 ) select distinct on (d.code_dept) d.code_dept, qux.geom150 ) select distinct on (d.code_dept) d.code_dept, baz.geom 151 151 from ( 152 select (st_dump(st_polygonize(distinct baz.geom))).geom as geom152 select (st_dump(st_polygonize(distinct geom))).geom as geom 153 153 from ( 154 select (st_dump( geom)).geom as geom154 select (st_dump(st_simplifyPreserveTopology(st_linemerge(st_union(geom)), 10000))).geom as geom 155 155 from ( 156 select st_simplifyPreserveTopology(st_linemerge(st_union(geom)), 10000) as geom 157 from ( 158 select st_exteriorRing((st_dumpRings(geom)).geom) as geom 159 from poly 160 ) as foo 161 ) as bar 162 ) as baz 163 ) as qux, 156 select st_exteriorRing((st_dumpRings(geom)).geom) as geom 157 from poly 158 ) as foo 159 ) as bar 160 ) as baz, 164 161 poly d 165 where st_intersects(d.geom, qux.geom)166 order by d.code_dept, st_area(st_intersection( qux.geom, d.geom))/st_area(qux.geom) desc;162 where st_intersects(d.geom, baz.geom) 163 order by d.code_dept, st_area(st_intersection(baz.geom, d.geom))/st_area(baz.geom) desc; 167 164 }}} 168 165
