Changes between Version 9 and Version 10 of UsersWikiPostgisarcgis
- Oct 25, 2012, 7:09:06 AM (11 years ago)
v9 v10 2 2 == Issues / Gotchas / Confusions == 3 3 The biggest problem with using PostGIS in ArcSDE is that you are forced to use older versions of PostGIS and PostgreSQL. 4 5 * If you are running SP1 on ArcGIS 10.1 then you could run PostGIS 2.0 and PostgreSQL 9.1.3, depending on your OS. 6 7 Details: [http://support.esri.com/en/knowledgebase/techarticles/detail/40553] 8 [http://resources.arcgis.com/en/help/system-requirements/10.1/index.html#//015100000075000000] 4 9 5 10 * If you are running ArcGIS 10.1 then only PostGIS 1.5 and PostgreSQL 9.0 are supported.
