Changes between Version 1 and Version 2 of UsersWikiPostgisTopology
- Apr 14, 2009, 11:56:47 AM (15 years ago)
v1 v2 6 6 7 7 With topology support enabled you can store [wiki:UsersWikiTopologicalPrimitives topological elements], 8 define TopoGeometryobjects as being composed by these elements,9 convert TopoGeometryobjects to simple [wiki:UsersWikiGeometryType Geometry] objects8 define [wiki:UsersWikiTopoGeometry TopoGeometry] objects as being composed by these elements, 9 convert [wiki:UsersWikiTopoGeometry TopoGeometry] objects to simple [wiki:UsersWikiGeometryType Geometry] objects 10 10 to use all functions defined on the latter. 11 11 … … 109 109 == Getting simple Geometry values from !TopoGeometry objects == 110 110 111 You currently need to explicit call the TopoGeometry=>Geometry111 You currently need to explicit call the !TopoGeometry=>Geometry 112 112 cast function. This will probably be made implicit when the 113 113 code is more tested: 114 114 115 115 {{{ 116 SELECT topology.Geometry( TopoGeometry);116 SELECT topology.Geometry(!TopoGeometry); 117 117 118 118 }}}
