Changes between Version 1 and Version 2 of UsersWikiPostGIS20Debian7src
Jun 27, 2013, 4:49:24 AM (11 years ago)
Mike Taves
  • UsersWikiPostGIS20Debian7src
    v1 v2
    1 = How to install PostGIS 2.0 on Debian 7.x (''wheezy'') from source =
    3 == Prerequisites ==
    5 Several components are needed, which can either be built from source or installed from pre-built packages, as shown below. It is assumed you have already installed and configured `sudo` (not done by default).
    7 Install prerequisite packages using:
    8 {{{
    9 sudo apt-get install build-essential postgresql-9.1 postgresql-server-dev-9.1 libxml2-dev libgeos-dev libproj-dev libjson0-dev xsltproc docbook-xsl docbook-mathml
    10 }}}
    12 Optional package for raster support (recommended):
    13 {{{
    14 sudo apt-get install libgdal-dev
    15 }}}
    16
    17 == Build PostGIS ==
    18 {{{
    19 wget http://download.osgeo.org/postgis/source/postgis-2.0.3.tar.gz
    20 tar xfvz postgis-2.0.3.tar.gz
    21 cd postgis-2.0.3
    22 }}}
    23 PostGIS 2.0 can be configured to disable topology or raster extensions, using the configure flags `--without-raster` and `--without-topology`. The default is to build both extensions:
    24 {{{
    25 ./configure
    26 make
    27 sudo make install
    28 sudo ldconfig
    29 sudo make comments-install
    30 }}}
    31
    32 Lastly, enable the command-line tools to work from your shell:
    33 {{{
    34 sudo ln -sf /usr/share/postgresql-common/pg_wrapper /usr/local/bin/shp2pgsql
    35 sudo ln -sf /usr/share/postgresql-common/pg_wrapper /usr/local/bin/pgsql2shp
    36 sudo ln -sf /usr/share/postgresql-common/pg_wrapper /usr/local/bin/raster2pgsql
    37 }}}
    38
    39 === PostGIS Extension for PostgreSQL ===
    40 Spatially enabling a database using extensions is a new feature of PostgreSQL 9.1.
    41
    42 Connect to your database using pgAdmin or psql, and run the following commands. To add postgis with raster support:
    43 {{{
    44 CREATE EXTENSION postgis;
    45 }}}
    46
    47 To add topology support, a second extension can be created on the database:
    48 {{{
    49 CREATE EXTENSION postgis_topology;
    50 }}}
    51
    52 === Enabler Scripts / Template ===
    53
    54 Enabler scripts can be used to either build a template, or directly spatially enable a database. This method is older than the extension method, but is required if the raster support is not built.
    56 The following example creates a template, which can be re-used for creating multiple spatially-enabled databases. Or if you just want to make one spatially enabled database, you can modify the commands for your needs.
    57
    58 PostGIS:
    59 {{{
    60 sudo -u postgres createdb template_postgis
    61 sudo -u postgres psql -d template_postgis -c "UPDATE pg_database SET datistemplate=true WHERE datname='template_postgis'"
    62 sudo -u postgres psql -d template_postgis -f /usr/share/postgresql/9.1/contrib/postgis-2.0/postgis.sql
    63 sudo -u postgres psql -d template_postgis -f /usr/share/postgresql/9.1/contrib/postgis-2.0/spatial_ref_sys.sql
    64 sudo -u postgres psql -d template_postgis -f /usr/share/postgresql/9.1/contrib/postgis-2.0/postgis_comments.sql
    65 }}}
    66
    67 with raster support:
    68 {{{
    69 sudo -u postgres psql -d template_postgis -f /usr/share/postgresql/9.1/contrib/postgis-2.0/rtpostgis.sql
    70 sudo -u postgres psql -d template_postgis -f /usr/share/postgresql/9.1/contrib/postgis-2.0/raster_comments.sql
    71 }}}
    72
    73 with topology support:
    74 {{{
    75 sudo -u postgres psql -d template_postgis -f /usr/share/postgresql/9.1/contrib/postgis-2.0/topology.sql
    76 sudo -u postgres psql -d template_postgis -f /usr/share/postgresql/9.1/contrib/postgis-2.0/topology_comments.sql
    77 }}}
     1[wiki:UsersWikiPostGIS20Debian70src]
