Changes between Initial Version and Version 1 of UsersWikiPostGIS15Ubuntu1110pkg
Mar 5, 2012, 5:17:14 AM (12 years ago)
Mike Taves
  • UsersWikiPostGIS15Ubuntu1110pkg
     1= How to install PostGIS 1.5 on Ubuntu 11.10 (''oneiric'') from packages =
     3||'''Component'''||'''Version'''||
     4||PostGIS||1.5.3||
     5||PostgreSQL||9.1||
     6||PROJ||4.7.0||
     7||GEOS||3.2.2||
     8
     9Install everything using:
     10{{{
     11sudo apt-get install postgresql-9.1-postgis
     12}}}
     13Accept and install the approx 47 packages.
     14
     15Complete a post-install by creating a template, which can be re-used for creating multiple spatially-enabled databases. Or if you just want to make one spatially enabled database, you can modify the commands for your needs.
     16{{{
     17sudo -u postgres createdb template_postgis
     18sudo -u postgres psql -d template_postgis -f /usr/share/postgresql/9.1/contrib/postgis-1.5/postgis.sql
     19sudo -u postgres psql -d template_postgis -f /usr/share/postgresql/9.1/contrib/postgis-1.5/spatial_ref_sys.sql
     20sudo -u postgres psql -d template_postgis -f /usr/share/postgresql/9.1/contrib/postgis_comments.sql
     21}}}
     23== See also ==
     24 * https://help.ubuntu.com/community/PostgreSQL
