Changes between Version 1 and Version 2 of UsersWikiExamplesSpikeRemover
- Dec 3, 2009, 6:33:27 AM (14 years ago)
v1 v2 1 1 = Spike-Remover = 2 2 3 This function searches for spikes and removes them. Spikes arise by the intersection of geometries or by digitization errors. The geometry and the azimuth direction angle is the input. As result you get the clean geometriy back without any spikes. The process is the following: At first the Spike Remover function deagrades the polygon at inner and outer rings. After then the Spike Remover calls the SpikeRemoverCore. This funktion cleans the individual polygons of inner and outside spikes. As a result you get back the clean geometry.3 This function searches for spikes and removes them. Spikes arise by the intersection of geometries or by digitization errors. The geometry and the azimuth direction angle is the input. As result you get the clean geometriy back without any spikes. The process is the following: At first the Spike-Remover function deagrades the polygon at inner and outer rings. After then the Spike Remover calls the Spike-Remover-Core. This funktion cleans the individual polygons of inner and outside spikes. As a result you get back the clean geometry. 4 4 5 5 ''Input Value: Polygon, Angle in float 0.01''
