Changes between Initial Version and Version 1 of TracStandalone
Apr 2, 2009, 10:07:44 AM (15 years ago)
  • TracStandalone
     1= Tracd =
     3Tracd is a lightweight standalone Trac web server. In most cases it's easier to setup and runs faster than the [wiki:TracCgi CGI script].
     5== Pros ==
     7 * Fewer dependencies: You don't need to install apache or any other web-server.
     8 * Fast: Should be almost as fast as the [wiki:TracModPython mod_python] version (and much faster than the [wiki:TracCgi CGI]).
     9 * Automatic reloading: For development, Tracd can be used in ''auto_reload'' mode, which will automatically restart the server whenever you make a change to the code (in Trac itself or in a plugin).
     10
     11== Cons ==
     12
     13 * Fewer features: Tracd implements a very simple web-server and is not as configurable or as scalable as Apache HTTPD.
     14 * No native HTTPS support: [http://www.rickk.com/sslwrap/ sslwrap] can be used instead,
     15   or [http://trac.edgewall.org/wiki/STunnelTracd stunnel -- a tutorial on how to use stunnel with tracd] or Apache with mod_proxy.
     16
     17== Usage examples ==
     18
     19A single project on port 8080. (http://localhost:8080/)
     20{{{
     21 $ tracd -p 8080 /path/to/project
     22}}}
     23With more than one project. (http://localhost:8080/project1/ and http://localhost:8080/project2/)
     24{{{
     25 $ tracd -p 8080 /path/to/project1 /path/to/project2
     26}}}
     27
     28You can't have the last portion of the path identical between the projects since Trac uses that name to keep the URLs of the
     29different projects unique. So if you use `/project1/path/to` and `/project2/path/to`, you will only see the second project.
     30
     31An alternative way to serve multiple projects is to specify a parent directory in which each subdirectory is a Trac project, using the `-e` option. The example above could be rewritten:
     32{{{
     33 $ tracd -p 8080 -e /path/to
     34}}}
     35
     36== Using Authentication ==
     37
     38Tracd provides support for both Basic and Digest authentication. The default is to use Digest; to use Basic authentication, replace `--auth` with `--basic-auth` in the examples below, and omit the realm.
     39
     40  ''Support for Basic authentication was added in version 0.9.''
     41
     42If the file `/path/to/users.htdigest` contains user accounts for project1 with the realm "mycompany.com", you'd use the following command-line to start tracd:
     43{{{
     44 $ tracd -p 8080 --auth project1,/path/to/users.htdigest,mycompany.com /path/to/project1
     45}}}
     46
     47'''Note''': the project "name" passed to the `--auth` option is the base name of the project environment directory.
     48
     49Of course, the digest file can be be shared so that it is used for more than one project:
     50{{{
     51 $ tracd -p 8080 \
     52   --auth project1,/path/to/users.htdigest,mycompany.com \
     53   --auth project2,/path/to/users.htdigest,mycompany.com \
     54   /path/to/project1 /path/to/project2
     55}}}
     56
     57Another way to share the digest file is to specify "*"
     58for the project name:
     59{{{
     60 $ tracd -p 8080 \
     61   --auth *,/path/to/users.htdigest,mycompany.com \
     62   /path/to/project1 /path/to/project2
     63}}}
     64
     65== How to set up an htdigest password file ==
     66
     67If you have Apache available, you can use the htdigest command to generate the password file. Type 'htdigest' to get some usage instructions, or read [http://httpd.apache.org/docs/2.0/programs/htdigest.html this page] from the Apache manual to get precise instructions.  You'll be prompted for a password to enter for each user that you create.  For the name of the password file, you can use whatever you like, but if you use something like `users.htdigest` it will remind you what the file contains. As a suggestion, put it in your <projectname>/conf folder along with the [TracIni trac.ini] file.
     68
     69Note that you can start tracd without the --auth argument, but if you click on the ''Login'' link you will get an error.
     70
     71== Generating Passwords Without Apache ==
     72
     73If you don't have Apache available, you can use this simple Python script to generate your passwords:
     74
     75{{{
     76from optparse import OptionParser
     77import md5
     78
     79# build the options
     80usage = "usage: %prog [options]"
     81parser = OptionParser(usage=usage)
     82parser.add_option("-u", "--username",action="store", dest="username", type = "string",
     83                  help="the username for whom to generate a password")
     84parser.add_option("-p", "--password",action="store", dest="password", type = "string",
     85                  help="the password to use")
     86(options, args) = parser.parse_args()
     87
     88# check options
     89if (options.username is None) or (options.password is None):
     90   parser.error("You must supply both the username and password")
     91
     92# Generate the string to enter into the htdigest file
     93realm = 'trac'
     94kd = lambda x: md5.md5(':'.join(x)).hexdigest()
     95print ':'.join((options.username, realm, kd([options.username, realm, options.password])))
     96}}}
     97
     98Note: If you use the above script you must use the --auth option to tracd, not --basic-auth, and you must set the realm in the --auth value to 'trac' (without the quotes). Example usage (assuming you saved the script as trac-digest.py):
     100{{{
     101python trac-digest.py -u username -p password >> c:\digest.txt
     102python tracd --port 8000 --auth proj_name,c:\digest.txt,trac c:\path\to\proj_name
     103}}}
     104
     105== Tips ==
     106
     107=== Serving static content ===
     108
     109If `tracd` is the only webserver used for the project,
     110it can also be used to distribute static content
     111(tarballs, Doxygen documentation, etc.)
     112
     113This static content should be put in the `$TRAC_ENV/htdocs` folder,
     114and is accessed by URLs like `<project_URL>/chrome/site/...`.
     115
     116Example: given a `$TRAC_ENV/htdocs/software-0.1.tar.gz` file,
     117the corresponding relative URL would be `/<project_name>/chrome/site/software-0.1.tar.gz`,
     118which in turn can be written using the relative link syntax
     119in the Wiki: `[/<project_name>/chrome/site/software-0.1.tar.gz]`
     120
     121The development version of Trac supports a new `htdocs:` TracLinks
     122syntax for the above. With this, the example link above can be written simply
     123`htdocs:software-0.1.tar.gz`.
     124
     125----
     126See also: TracInstall, TracCgi, TracModPython, TracGuide
     127
     128----
     129'''Translation:'''
     130 * [https://opensvn.csie.org/traccgi/trac_rus/wiki/StandAloneTracForTeapot Russian] (перевод на Русский)
