Changes between Version 6 and Version 7 of RCDownloads
Sep 30, 2010, 10:59:51 PM (14 years ago)
robe
  • RCDownloads
    v6 v7
    1 [http://trac.osgeo.org/postgis/raw-attachment/wiki/WikiStart/postgis-1.5.2rc1.tar.gz Download PostGIS 1.5.2rc1] 2010-09-19
    2 Items in PostGIS 1.5.2 rc1
    4 {{{
    5  - This is a bug fix release, addressing issues that have been
    6    filed since the 1.5.1 release.
    8  - Bug Fixes
    9    - Loader: fix handling of empty (0-verticed) geometries in shapefiles.
    10      (Sandro Santilli)
    11    - #536, Geography ST_Intersects, ST_Covers, ST_CoveredBy and
    12      Geometry ST_Equals not using spatial index (Regina Obe, Nicklas Aven)
    13    - #573, Improvement to ST_Contains geography
    14    - Loader: Add support for command-q shutdown in Mac GTK build (Paul Ramsey)
    15    - #393, Loader: Add temporary patch for large DBF files
    16      (Maxime Guillaud, Paul Ramsey)
    17    - #507, Fix wrong OGC URN in GeoJSON and GML output (Olivier Courtin)
    18    - spatial_ref_sys.sql Add datum conversion for projection SRID 3021
    19      (Paul Ramsey)
    20    - Geography - remove crash for case when all geographies are out of
    21      the estimate (Paul Ramsey)
    22    - #469, Fix for array_aggregation error (Greg Stark, Paul Ramsey)
    23    - #532, Temporary geography tables showing up in other user sessions
    24      (Paul Ramsey)
    25    - #562, ST_Dwithin errors for large geographies (Paul Ramsey)
    26    - #513, shape loading GUI tries to make spatial index when loading DBF only
    27      mode (Paul Ramsey)
    28    - #527, shape loading GUI should always append log messages
    29      (Mark Cave-Ayland)
    30    - #504 shp2pgsql should rename xmin/xmax fields (Sandro Santilli)
    31    - #458 postgis_comments being installed in contrib instead of
    32      version folder (Mark Cave-Ayland)
    33    - #474 Analyzing a table with geography column crashes server
    34      (Paul Ramsey)
    35    - #581 LWGEOM-expand produces inconsistent results
    36      (Mark Cave-Ayland)
    37    - #471 DocBook dtd errors (Olivier Courtin)
    38    - Fix further build issues against PostgreSQL 9.0
    39      (Mark Cave-Ayland)
    40    - #572 Password whitespace for Shape File to PostGIS
    41      Import not supported (Mark Cave-Ayland)
    42    - #603 shp2pgsql: "-w" produces invalid WKT for MULTI* objects.
    43      (Mark Cave-Ayland)
    44  - Enhancement
    45    - #513 Add dbf filter to shp2pgsql-gui and allow uploading dbf only
    46      (Paul Ramsey)
    47 }}}
     1== No current RC Downloads ==
     2* Refer to [http://www.postgis.org/download/ PostGIS downloads page for nightly source builds]
     3* For [http://www.postgis.org/download/windows/experimental.php Windows Experimental binaries of PostGIS 2.0 and stable branch interim releases]
