Changes between Version 2 and Version 3 of DevWikiWinMingWSys_20_MSVC
Show
02/28/12 23:39:46 (16 months ago)
mwtoews
add notes for TortoiseSVN option
  • DevWikiWinMingWSys_20_MSVC
    v2 v3
    4242== SVN ==
    4343
    44 In order to build the latest versions of PostGIS 2.0 you will need an SVN client, so download a command line SVN client:
    45
     44In order to build the latest versions of PostGIS 2.0 you will need an SVN client, so download a command line SVN client. Pick only one of the following options: TortoiseSVN or Slik SVN.
     45
     46=== Slik SVN ===
    4647{{{
    4748cd /c/build/binaries
    5051
    5152Once you've downloaded, install with the default options.
     53
     54=== TortoiseSVN ===
     55Download an MSI installer from http://tortoisesvn.net/downloads.html choosing either 32-bit or 64-bit OS versions for your system. Install with most default options BUT add "command line client tools", which is not enabled by default. After completing install, you will need to restart you computer as indicated.
    5256
    5357== Visual C++ Express ==
