Changes between Version 22 and Version 23 of DevWikiWinMingWSys_20
- Apr 16, 2011, 7:08:18 PM (13 years ago)
v22 v23 318 318 319 319 == 16. Python GDAL bindings == 320 In order to compile raster these days, you now need Python with numpy and gdal bindings. The most bullet proof and easiest install I have found for this 320 In order to compile raster these days, you now need Python with numpy and gdal bindings. 321 So install your flavor of python if you don't have one from -- http://www.python.org/download/ (2.7 will work fine) 322 323 The most bullet proof and easiest install I have found for GDAL and numpy 321 324 is the unofficial python libs from http://www.lfd.uci.edu/~gohlke/pythonlibs/ 322 GDAL-1.7.3.win32-py2.6.exe or GDAL-1.7.3.win32-py2.7.exe (listed in GDAL section) 323 as well as the accompanying Numpy: numpy-1.5.1.win32-py2.6.exe, numpy-1.5.1.win32-py2.7.exe 324 You will need python 2.6 or 2.7 as well. 325 326 327 328 325 * run Numpy: numpy-1.5.1.win32-py2.6.exe, numpy-1.5.1.win32-py2.7.exe 326 * run GDAL-1.7.3.win32-py2.6.exe or GDAL-1.7.3.win32-py2.7.exe (listed in GDAL section) 329 327 330 328 == 17. Compiling PostGIS == … … 355 353 356 354 {{{ 355 #this is need for shp2pgsql-gui compile 357 356 export PATH="/c/gtkbundle/bin:$PATH" 358 357 #this is needed for raster support so it can find the python bindings,replace with which version of python you have
