Changes between Version 5 and Version 6 of DevWikiWinMingW64_21
Show
07/31/12 05:21:15 (10 months ago)
robe
  • DevWikiWinMingW64_21
    v5 v6
    186186Download latest GEOS source from http://trac.osgeo.org/geos/
    187187You can also use the trunk svn version https://svn.osgeo.org/geos/trunk which is what we use.
    188 NOTE: To take advantage of new functions like ST_DelaunayTriangles, you need GEOS 3.4dev which is trunk
     188NOTE: To take advantage of new functions like [http://www.postgis.org/documentation/manual-svn/ST_DelaunayTriangles.html ST_DelaunayTriangles], you need GEOS 3.4dev which is trunk
    189189If you are using svn version, make sure to run:
    190190
