Changes between Version 22 and Version 23 of DevWikiWinMingW64_21
- May 2, 2013, 10:34:41 PM (11 years ago)
v22 v23 72 72 Download latest GEOS source from http://trac.osgeo.org/geos/ 73 73 You can also use the trunk svn version https://svn.osgeo.org/geos/trunk which is what we use. 74 NOTE: To take advantage of new functions like [http://www.postgis.org/documentation/manual-svn/ST_DelaunayTriangles.html ST_DelaunayTriangles], you need GEOS 3.4dev which is trunk 74 NOTE: To take advantage of new functions like [http://www.postgis.org/documentation/manual-svn/ST_DelaunayTriangles.html ST_DelaunayTriangles], you need GEOS 3.4dev which is trunk. 75 76 We've never used the tar balls for GEOS we always build from svn 77 and extract into the geos/branches/whateverversion 75 78 If you are using svn version, make sure to run: 76 79 77 80 {{{ 78 81 sh autogen.sh 82 cd ${PROJECTS}/geos/branches/3.4 83 export GEOS_VER=3.4.0dev 84 85 sh autogen.sh 86 ./configure --build=x86_64-w64-mingw32 --prefix=${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD} | tee /c/geos_configure_3.4w${OS_BUILD}.log 87 make 88 make install 89 make check | tee /c/geos_check_3.4_w${OS_BUILD}.log 90 strip ${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/bin/*.dll 79 91 }}} 80 92
