Changes between Version 81 and Version 82 of DevWikiWinMingW64
- 03/01/12 07:30:46 (15 months ago)
DevWikiWinMingW64
v81 v82 223 223 #if you are building for 64-bit then use x86_64-w64-mingw32 for the build,host,target 224 224 #32 bit uses i686-w64-mingw32 for build, host, target 225 ./configure --prefix=/c/projects/libxml/rel-libxml2-2.7.8w64 --build=x86_64-w64-mingw32 --host=x86_64-w64-mingw32 --target=x86_64-w64-mingw32 --disable-shared CCFLAGS=LDFLAGS="-Wl,-static" CFLAGS=-O2 225 ./configure --prefix=/c/projects/libxml/rel-libxml2-2.7.8w64 --build=x86_64-w64-mingw32 --host=x86_64-w64-mingw32 --target=x86_64-w64-mingw32 --enable-shared CFLAGS=-O2 226 #Note to self: used to have CCFLAGS=LDFLAGS="-Wl,-static" in here will see how it goes without 226 227 make 227 228 make install
