Changes between Version 3 and Version 4 of DevWikiPGRegress
- Jan 14, 2011, 6:20:39 AM (13 years ago)
DevWikiPGRegress
v3 v4 6 6 * Create a .sql file listing key preferably corner cases of your function and name it some variant of your function name e.g myfunc.sql. Examples of these are in the /regress folder e.g. dumppoints.sql 7 7 * Run this sql file in a PostGIS enabled db using psql and save the output in myfunc_expected -- e.g. 8 {{ 8 {{{ 9 9 psql -tXA -h localhost -U postgres -d postgis_reg -f myfunc.sql -o myfunc_expected 10 }} 10 }}} 11 11 * Add this .sql script to the Makefile.in in trunk/regress (NOTE: we can do this if you are submitting the patch). Also note that if your function relies on a particular version of GEOS that is not the minimum version for the PostGIS release, you need to wrap it in a conditional of the form: 12 12
