Changes between Version 11 and Version 12 of DevWikiGardenTest
- Oct 8, 2009, 7:16:20 AM (15 years ago)
DevWikiGardenTest
v11 v12 1 1 = PostGIS Garden Test = 2 2 3 The PostGIS Garden Test is a suite of SQL statements designed to stress test the PostGIS library within the PostgreSQL environment. It is a test generated from the reference.xml that tries to test every documented function against every kind of geometry supported by PostGIS. The main objective s of the tests is to try to catch bugs that will crash the server. It is also useful for monitoring odd behavior as well as as a regression test against prior versions of the software. To test against prior versions, build a test from the prior version reference.xml and test against both the old and the new version on the same server and then do a diff between the two. With postgis-1.4 and postgis-1.5 this is much easier to do as you can run both versions on the same server in differen dbs.3 The PostGIS Garden Test is a suite of SQL statements designed to stress test the PostGIS library within the PostgreSQL environment. It is a test generated from the reference.xml that tries to test every documented function against every kind of geometry supported by PostGIS. The main objective of the tests is to try to catch bugs that will crash the server. It is also useful for monitoring odd behavior as well as a regression test against prior versions of the software. To test against prior versions, build a test from the prior version reference.xml and test against both the old and the new version on the same server and then do a diff between the two. With postgis-1.4 and postgis-1.5 this is much easier to do as you can run both versions on the same server in different databases. 4 4 5 5 To build the garden test you need an xsltproc (the same that is used to build the docs or some other .xsl processor). On windows you can download precompiled binaries from [http://www.zlatkovic.com/pub/libxml/] and its part of the libxslt package.
