Changes between Version 22 and Version 23 of DevWikiEmptyGeometry
Oct 6, 2009, 2:15:02 PM (15 years ago)
pramsey
  • DevWikiEmptyGeometry
    v22 v23
    1111 * ST_Distance(geometry, empty) == NULL
    1212 * ST_DWithin(geometry, empty, tolerance) == FALSE (if distance = null, shouldn't DWithin be null?)
    13  * ST_Contains(geometry, empty) == TRUE
    14  * ST_Within(geometry, empty) == FALSE
    15  * ST_Contains(empty, geometry) == FALSE
    16  * ST_Within(empty, geometry) == TRUE
     13 * ST_Contains(geometry, empty) == FALSE (SQL Server says False)
     14 * ST_Within(geometry, empty) == FALSE (SQL Server says False)
     15 * ST_Contains(empty, geometry) == FALSE (SQL Server says False)
     16 * ST_Within(empty, geometry) == FALSE  (SQL Server says False)
    1717 * ST_Contains(empty, empty) == FALSE (SQL Server says False)
    1818 * ST_Intersects(geometry, empty) == FALSE
    115115  => 0
    116116
     117SELECT Geometry::STGeomFromText('POINT(1 2)',4326).STContains(Geometry::STGeomFromText('POLYGON EMPTY',4326))
     118       => 0
     119
     120--geometry within empty
     121 SELECT Geometry::STGeomFromText('POINT(1 2)',4326).STWithin(Geometry::STGeomFromText('POLYGON EMPTY',4326))
     122        => 0
     123
     124--empty contains geometry
     125 SELECT Geometry::STGeomFromText('POLYGON EMPTY',4326).STContains(Geometry::STGeomFromText('POINT(1 2)',4326))
     126 => 0
     127
     128 --empty within geometry
     129SELECT Geometry::STGeomFromText('POLYGON EMPTY',4326).STWithin(Geometry::STGeomFromText('POINT(1 2)',4326))
     130 => 0
    117131
    118132}}}
