Changes between Version 24 and Version 25 of DevWikiDocNewFeature
Dec 25, 2019, 11:18:26 AM (4 years ago)
robe
  • DevWikiDocNewFeature
    v24 v25
    22[DevWikiMain Back to PostGIS Dev Main]
    4 If you are submitting a patch for a new feature, keep in mind we only allow new feature patches for semi-major (minor) and major releases, not for micro releases.  So for example if the latest stable version of PostGIS is 1.4 or 1.4 is in freeze mode (which usually happens about 2 months or more before planned release), then your new feature must
    5 go into 1.5.  If you are supplying a bug fix then that can go into the next stable release.  So for example a bug fix for 1.4.0 will go into both 1.4.1 and 1.5.0.  A bug fix that fixes further back can be provided for  1.3,1.4, and 1.5
     4If you are submitting a patch for a new feature, keep in mind we only allow new feature patches for semi-major (minor) and major releases, not for micro releases.  So for example if the latest stable version of PostGIS is 3.0.1 and then your new feature must
     5go into 3.1 (or 3.2 if we've already frozen 3.1 - which happens about 1 month before release).  If you are supplying a bug fix then that can go into the next stable release.  So for example a bug fix for 3.0.0 will go into both 3.0.1 .  A bug fix that fixes further back can be provided for  any release not yet End of Lifed - e.g 3.0, 2.5, 2.4
    76For new features, we expect documentation as part of the submission.  To document a new function, please do the following:
    87  1. Make a copy of  template.xml located in trunk/doc of the PostGIS subversion repository ([https://svn.osgeo.org/postgis/trunk/doc])
