Changes between Version 19 and Version 20 of DevWikiDocNewFeature
- Aug 28, 2009, 5:26:53 AM (15 years ago)
v19 v20 24 24 it to generate images for your examples, do the following: 25 25 26 1. Define queries using your new function or if you want to provide images for existing then do that and be careful to make sure the generated geometries fit in a 200x200 grid otherwise they will be cropped. 26 1. Define queries using your new function or if you want to provide images for existing then do that and be careful to make sure the generated geometries fit in a 200x200 grid otherwise they will be cropped. Try to take up as much of the 200x200 realestate you can. 27 27 28 28 2. For your query do an ST_AsText to generate the WKT output of it and save this in the image_src folder on
