Changes between Version 9 and Version 10 of OSSIMVERSIONHistory
Oct 19, 2010, 5:56:13 AM (14 years ago)
pborissow
  • OSSIMVERSIONHistory
    v9 v10
    1 Recent OSSIM version History
     1= Recent OSSIM Version History =
    3 1.8.6 - Slated for June 2010 focused on GUI changes
     3'''1.8.6''' - Slated for June 2010 focused on GUI changes
    44
    5 1.8.4 - Slated for March 2010 to mainly address performance and stability
     5'''1.8.4''' - Slated for March 2010 to mainly address performance and stability
    66
    7 1.8.3 - Engineering release installed on system to address performance and stability issues - GRAILS 1.2 and JMETER testing added.
     7'''1.8.3''' - Engineering release installed on system to address performance and stability issues - GRAILS 1.2 and JMETER testing added.
    88
    9 1.8.2  - Initial release of the SECRET SIPRNET capability with new staging capabilties
     9'''1.8.2'''  - Initial release of the SECRET SIPRNET capability with new staging capabilties
    1010
    11 1.8.0 - Integrated various changes from operational feedback primarily focused on Large Data functionality
     11'''1.8.0''' - Integrated various changes from operational feedback primarily focused on Large Data functionality
    1212
    13 1.7.13 - Rebuild of 1.7.12 with new build procedures.  OMAR and WMS enhancements to the baseline based on Large Data testing.
     13'''1.7.13''' - Rebuild of 1.7.12 with new build procedures.  OMAR and WMS enhancements to the baseline based on Large Data testing.
    1414
    15 1.7.12 - fixed Sousa navigation initialization, note this released was pulled  due to Windows virus in installer - build procedures modified accordingly
     15'''1.7.12''' - fixed Sousa navigation initialization, note this released was pulled  due to Windows virus in installer - build procedures modified accordingly
    1616
    17 1.7.11 - fixes from user testing and feedback.
     17'''1.7.11''' - fixes from user testing and feedback.
     18 * When adding a host to the broadcast section for collaboration, checking the enabled box causes ossimPlanet to hang and crash
     19 * Trying to relocate a file pointer in the layers list always results in that layer being moved to the top of the list
     20 * When opening images, kmls, etc, the open file dialog defaults to the OSSIM install directory, should default to last opened directory
     21 * Open Session dialog box is misnamed Save Session
     22 * OMAR
     23   * The user interface for the Search imagery page is much improved, however same improvements were not made to the video section
     24   * In the search results, the word Thumbnail appears before the filename column and there is nothing above the Thumbnail column
    1825
    19  # When adding a host to the broadcast section for collaboration, checking the enabled box causes ossimPlanet to hang and crash
    20
    21  # Trying to relocate a file pointer in the layers list always results in that layer being moved to the top of the list
    23  # When opening images, kmls, etc, the open file dialog defaults to the OSSIM install directory, should default to last opened directory
    25  # Open Session dialog box is misnamed Save Session
    27 OMAR
    28
    29  # The user interface for the Search imagery page is much improved, however same improvements were not made to the video section
    30
    31  # In the search results, the word Thumbnail appears before the filename column and there is nothing above the Thumbnail column
    32
    33 1.7.10 - OMAR user interface changes, dropped the UDP for navigation in ossimPlanet and went with TCP only.
     26'''1.7.10''' - OMAR user interface changes, dropped the UDP for navigation in ossimPlanet and went with TCP only.
    3427
    3528The OSSIM/OMAR status.  As a result of testing the previous version the following problems were found and fixed:
    3629
    37 *  UAV video indexing would halt when encountering clips that didn't intersect with the ground.  Additional logic was added detecting this condition.  If the four corners of the frame do not interesect it defaults to using the center of the frame and then bottom corners.  If these don't intersect the sensor position is used to geotag the clip.
    38
    39 * UAV file pointers not closing, wouldn't open after 3000 images, bug fixed.
    40
    41 *  The staging and thumbnail generation process was not robust and would abort the process.  Changed the strategy for the generation process.  System now seems to work without hangs on large ingests.
    42
    43 *  Moved the definition of custom tag searches into the administration area.  The system administrator can now define tags and tag names for database searches and the pop up menu on the web page.
    44
    45 *  Ability to select 3 map sizes
    46
    47 *  Left justified user input area on the bottom of the screen.  Input from users of the system.
    48
    49 *  Numerous internal enhancements and structuring to enable web based services that will be introduced in the October release
    50
    51 *  Up is up thumbnail generation
    52
    53 *  Several image chain services are working in headless mode - chipper, ortho, two color, hillshade.  Will be exposed in October release.
    54
    55 ossimPlanet changes
    56
    57         * Red has fled, blue is new support in Layer Operations
    58        * Additional testing for shader capabilities under Layer Operations
    59         * TCP instead of UDP for Navigation
    60        * Binary installers for Windows/ Mac  (will have to build SUSE on site)
    61
    62
    63
    64
     30 * UAV video indexing would halt when encountering clips that didn't intersect with the ground.  Additional logic was added detecting this condition.  If the four corners of the frame do not interesect it defaults to using the center of the frame and then bottom corners.  If these don't intersect the sensor position is used to geotag the clip.
     31 * UAV file pointers not closing, wouldn't open after 3000 images, bug fixed.
     32 * The staging and thumbnail generation process was not robust and would abort the process.  Changed the strategy for the generation process.  System now seems to work without hangs on large ingests.
     33 * Moved the definition of custom tag searches into the administration area.  The system administrator can now define tags and tag names for database searches and the pop up menu on the web page.
     34 * Ability to select 3 map sizes
     35 * Left justified user input area on the bottom of the screen.  Input from users of the system.
     36 * Numerous internal enhancements and structuring to enable web based services that will be introduced in the October release
     37 * Up is up thumbnail generation
     38 * Several image chain services are working in headless mode - chipper, ortho, two color, hillshade.  Will be exposed in October release.
     39 * ossimPlanet changes
     40   * Red has fled, blue is new support in Layer Operations
     41   * Additional testing for shader capabilities under Layer Operations
     42   * TCP instead of UDP for Navigation
     43   * Binary installers for Windows/ Mac  (will have to build SUSE on site)
