Changes between Initial version and Version 1 of WikiStart
25 Jan 2007, 13:28:37 (17 years ago)
  • WikiStart
     1= Welcome to Trac 0.10.3 =
     3Trac is a '''minimalistic''' approach to '''web-based''' management of
     4'''software projects'''. Its goal is to simplify effective tracking and handling of software issues, enhancements and overall progress.
     6All aspects of Trac have been designed with the single goal to
     7'''help developers write great software''' while '''staying out of the way'''
     8and imposing as little as possible on a team's established process and
     9culture.
     10
     11As all Wiki pages, this page is editable, this means that you can
     12modify the contents of this page simply by using your
     13web-browser. Simply click on the "Edit this page" link at the bottom
     14of the page. WikiFormatting will give you a detailed description of
     15available Wiki formatting commands.
     16
     17"[wiki:TracAdmin trac-admin] ''yourenvdir'' initenv" created
     18a new Trac environment, containing a default set of wiki pages and some sample
     19data. This newly created environment also contains
     20[wiki:TracGuide documentation] to help you get started with your project.
     21
     22You can use [wiki:TracAdmin trac-admin] to configure
     23[http://trac.edgewall.org/ Trac] to better fit your project, especially in
     24regard to ''components'', ''versions'' and ''milestones''.
     25
     27TracGuide is a good place to start.
     28
     29Enjoy! [[BR]]
     30''The Trac Team''
     31
     32== Starting Points ==
     34 * TracGuide --  Built-in Documentation
     35 * [http://trac.edgewall.org/ The Trac project] -- Trac Open Source Project
     36 * [http://trac.edgewall.org/wiki/TracFaq Trac FAQ] -- Frequently Asked Questions
     37 * TracSupport --  Trac Support
     38
     39For a complete list of local wiki pages, see TitleIndex.
