Changes between Version 2 and Version 3 of WikiRestructuredText
- 22 Apr 2015, 15:34:51 (9 years ago)
v2 v3 1 1 = reStructuredText Support in Trac = 2 2 3 Trac supports using ''reStructuredText'' (RST) as an alternative to wiki markup in any contextWikiFormatting is used.3 Trac supports [http://docutils.sourceforge.net/docs/ref/rst/restructuredtext.html reStructuredText (RST)] as an alternative to wiki markup where WikiFormatting is used. 4 4 5 5 From the reStucturedText webpage: 6 6 "''reStructuredText is an easy-to-read, what-you-see-is-what-you-get plaintext markup syntax and parser system. It is useful for in-line program documentation (such as Python docstrings), for quickly creating simple web pages, and for standalone documents. reStructuredText is designed for extensibility for specific application domains. ''" 7 7 8 If you want a file from your Subversion repository be displayed as reStructuredText in Trac's source browser, set `text/x-rst` asvalue for the Subversion property `svn:mime-type`. See [trac:source:/trunk/INSTALL this example].8 If you want a file from your Subversion repository to be displayed as reStructuredText in the Trac source browser, set `text/x-rst` as the value for the Subversion property `svn:mime-type`. See [trac:source:/trunk/INSTALL this example]. 9 9 10 10 === Requirements === 11 Note that to activate RST support in Trac, the python docutils package must be installed. 12 If not already available on your operating system, you can download it at the [http://docutils.sourceforge.net/rst.html RST Website]. 13 14 Install docutils using `easy_install docutils`. Do not use the package manager of your OS (e.g. `apt-get install python-docutils`), because Trac will not find docutils then. 11 To activate RST support in Trac, install the python docutils package: `easy_install docutils`. If not already available on your operating system, you can download it at the [http://docutils.sourceforge.net/rst.html RST Website]. 12 13 Do not use the package manager of your OS, eg `apt-get install python-docutils`, because Trac will not find docutils then. 15 14 16 15 === More information on RST === … … 27 26 28 27 * Trac provides a custom RST directive `trac::` to allow TracLinks from within RST text. 29 30 Example: 31 {{{ 32 {{{ 33 #!rst 34 This is a reference to |a ticket| 35 36 .. |a ticket| trac:: #42 37 }}} 38 }}} 28 ||= Wiki Markup ||= Display || 29 {{{#!td 30 {{{ 31 {{{ 32 #!rst 33 This is a reference to |a ticket| 34 35 .. |a ticket| trac:: #42 36 }}} 37 }}} 38 }}} 39 {{{#!td 40 {{{ 41 #!rst 42 This is a reference to |a ticket| 43 44 .. |a ticket| trac:: #42 45 }}} 46 }}} 39 47 40 48 * Trac allows an even easier way of creating TracLinks in RST, using the custom `:trac:` role. 41 42 Example: 43 {{{ 44 {{{ 45 #!rst 46 This is a reference to ticket `#12`:trac: 47 48 To learn how to use Trac, see `TracGuide`:trac: 49 }}} 50 }}} 49 ||= Wiki Markup ||= Display || 50 {{{#!td 51 {{{ 52 {{{ 53 #!rst 54 This is a reference to ticket `#12`:trac: 55 56 To learn how to use Trac, see `TracGuide`:trac: 57 }}} 58 }}} 59 }}} 60 {{{#!td 61 {{{ 62 #!rst 63 This is a reference to ticket `#12`:trac: 64 65 To learn how to use Trac, see `TracGuide`:trac: 66 }}} 67 }}} 51 68 52 69 For a complete example of all uses of the `:trac:` role, please see WikiRestructuredTextLinks. 53 70 54 55 71 === Syntax highlighting in reStructuredText === 56 72 57 There is a directive for doing TracSyntaxColoring in RST as well. The directive is called 58 code-block 59 60 Example 61 62 {{{63 {{{ 64 #!rst 65 66 .. code-block:: python 67 68 class Test: 69 70 def TestFunction(self):71 pass72 73 }}}74 }}} 75 76 Will result in the below. 77 78 {{{ 79 #!rst 80 81 .. code-block:: python 82 83 class Test:84 85 def TestFunction(self): 86 pass87 88 }}} 73 There is a directive for doing TracSyntaxColoring in RST as well. The directive is called code-block: 74 75 ||= Wiki Markup ||= Display || 76 {{{#!td 77 {{{ 78 {{{ 79 #!rst 80 81 .. code-block:: python 82 83 class Test: 84 85 def TestFunction(self): 86 pass 87 88 }}} 89 }}} 90 }}} 91 {{{#!td 92 {{{ 93 #!rst 94 95 .. code-block:: python 96 97 class Test: 98 99 def TestFunction(self): 100 pass 101 102 }}} 103 }}} 104 Note the need to indent the code at least one character after the `.. code-block` directive. 89 105 90 106 === Wiki Macros in reStructuredText === 91 107 92 For doing [WikiMacros Wiki Macros] in RST you use the same directive as for syntax highlighting i.e 93 code-block. To work you must use a version of trac that has [trac:ticket:801 #801] applied. 94 95 === Wiki Macro Example === 96 97 {{{ 98 {{{ 99 #!rst 100 101 .. code-block:: RecentChanges 102 103 Trac,3 104 105 }}} 106 }}} 107 108 Will result in the below: 109 110 [[RecentChanges(Trac,3)]] 111 112 Or a more concise Wiki Macro like syntax is also available: 113 114 {{{ 115 {{{ 116 #!rst 117 118 :code-block:`RecentChanges:Trac,3` 119 }}} 108 To enable [WikiMacros Wiki Macros] in RST, you use the same directive as for syntax highlighting, ie code-block: 109 110 ||= Wiki Markup ||= Display || 111 {{{#!td 112 {{{ 113 {{{ 114 #!rst 115 116 .. code-block:: RecentChanges 117 118 Trac,3 119 120 }}} 121 }}} 122 }}} 123 {{{#!td 124 {{{ 125 #!rst 126 127 .. code-block:: RecentChanges 128 129 Trac,3 130 131 }}} 132 }}} 133 134 Or a more concise Wiki Macro-like syntax is also available, using the `:code-block:` role: 135 136 ||= Wiki Markup ||= Display || 137 {{{#!td 138 {{{ 139 {{{ 140 #!rst 141 142 :code-block:`RecentChanges:Trac,3` 143 }}} 144 }}} 145 }}} 146 {{{#!td 147 {{{ 148 #!rst 149 150 :code-block:`RecentChanges:Trac,3` 151 }}} 120 152 }}} 121 153 122 154 === Bigger RST Example === 123 The example below should be mostly self-explanatory: 155 The example below should be self-explanatory: 156 157 ||= Wiki Markup ||= Display || 158 {{{#!td 124 159 {{{ 125 160 #!html … … 151 186 }}}</pre> 152 187 }}} 153 154 155 Results in: 188 }}} 189 {{{#!td 156 190 {{{ 157 191 #!rst … … 180 214 .. _webpage: http://docutils.sourceforge.net/rst.html 181 215 }}} 182 216 }}} 183 217 184 218 ----
