Changes between Version 3 and Version 4 of TracImport
1 Feb 2017 00:38:41 (2 years ago)
  • TracImport
    v3 v4
    1 = Importing ticket data =
    2 [[PageOutline]]
     1= Importing ticket data
    32
    4 To migrate issue tickets from other issue-tracking systems or perform housekeeping actions on tickets or simply synchronize different databases, there are some tools, plug-ins and scripts available, which let you import or update tickets into Trac.
     3[[PageOutline(2-5,Contents,pullout)]]
    54
    6 == !TicketImportPlugin ==
     5To migrate issue tickets from other issue-tracking systems into Trac or perform housekeeping actions on tickets or simply synchronize different databases, there are some tools, plugins and scripts available.
    76
    8 [http://trac-hacks.org/wiki/TicketImportPlugin TicketImportPlugin]: this plug-in lets you import or update into Trac a series of tickets from a '''CSV file''' or (if the [http://pypi.python.org/pypi/xlrd xlrd library] is installed) from an '''Excel spreadsheet'''.
     7== !TicketImportPlugin
    98
    10 == !ExportImportXlsPlugin ==
     9[https://trac-hacks.org/wiki/TicketImportPlugin TicketImportPlugin]: a plugin that lets you import or update into Trac a series of tickets from a '''CSV file''' or (if the [https://pypi.python.org/pypi/xlrd xlrd library] is installed) from an '''Excel spreadsheet'''.
    1110
    12 [http://trac-hacks.org/wiki/ExportImportXlsPlugin ExportImportXlsPlugin]: this plug-in adds an admin panel for exporting and importing tickets via '''XLS file'''. Requires the python packages xlwt/rxld.
     11== !ExportImportXlsPlugin
    1312
    14 == Bugzilla ==
     13[https://trac-hacks.org/wiki/ExportImportXlsPlugin ExportImportXlsPlugin]: a plugin that adds an admin panel for exporting and importing tickets via '''XLS file'''. Requires the python packages xlwt/rxld.
    1514
    16 [http://trac-hacks.org/wiki/BugzillaIssueTrackingPlugin BugzillaIssueTrackingPlugin]: integrates Bugzilla issue data into Trac keeping TracLinks. Ticket data can be imported from Bugzilla using the [trac:browser:trunk/contrib/bugzilla2trac.py bugzilla2trac.py] script, available in the contrib/ directory of the Trac distribution.
     15== Bugzilla
     16
     17[https://trac-hacks.org/wiki/BugzillaIssueTrackingPlugin BugzillaIssueTrackingPlugin]: a plugin that integrates Bugzilla issue data into Trac keeping TracLinks. Ticket data can be imported from Bugzilla using the [trac:browser:trunk/contrib/bugzilla2trac.py bugzilla2trac.py] script, available in the contrib/ directory of the Trac distribution.
    1718
    1819{{{
    3536
    3637Currently, the following data is imported from Bugzilla:
    37   * bugs
    38   * bug activity (field changes)
    39   * bug attachments
    40   * user names and passwords (put into a htpasswd file)
     38 * bugs
     39 * bug activity (field changes)
     40 * bug attachments
     41 * user names and passwords (put into a htpasswd file)
    4142
    4243The script provides a number of features to ease the conversion, such as:
    43   * PRODUCT_KEYWORDS: Trac has no concept of products, so the script provides the ability to attach a ticket keyword instead.
    44   * IGNORE_COMMENTS: Don't import Bugzilla comments that match a certain regexp.
    45   * STATUS_KEYWORDS: Attach ticket keywords for the Bugzilla statuses not available in Trac. By default, the 'VERIFIED' and 'RELEASED' Bugzilla statuses are translated into Trac keywords.
     44 * PRODUCT_KEYWORDS: Trac has no concept of products, so the script provides the ability to attach a ticket keyword instead.
     45 * IGNORE_COMMENTS: Don't import Bugzilla comments that match a certain regexp.
     46 * STATUS_KEYWORDS: Attach ticket keywords for the Bugzilla statuses not available in Trac. By default, the `VERIFIED` and `RELEASED` Bugzilla statuses are translated into Trac keywords.
    4647
    4748For more details on the available options, see the configuration section at the top of the script.
    4849
    49 === Known Issues ===
    50 {{{
    51 #!comment
    52                    Don't merge this section in the default page
     50=== Known Issues
     51{{{#!comment
     52Don't merge this section in the default page
    5353}}}
    5454[[TicketQuery(keywords=~bugzilla,status=!closed)]]
    5656The adequate milestone for valid bugzilla2trac issue is usually ''Not applicable'', which means that fixes to the contributed script are not planned for a particular Trac release, but can happen anytime.
    5757
    58 == Jira ==
     58== Jira
    5959
    60 [http://trac-hacks.org/wiki/JiraToTracIntegration JiraToTracIntegration]: provides tools to import Atlassian Jira backup files into Trac. The plug-in consists of a Python 3.1 commandline tool that:
    61   - Parses the Jira backup XML file.
    62   - Sends the imported Jira data and attachments to Trac using the [http://trac-hacks.org/wiki/XmlRpcPlugin XmlRpcPlugin].
    63   - Generates a htpasswd file containing the imported Jira users and their SHA-512 base64 encoded passwords.
     60[https://trac-hacks.org/wiki/JiraToTracIntegration JiraToTracIntegration]: a plugin that provides tools to import Atlassian Jira backup files into Trac. The plugin consists of a Python 3.1 commandline tool that:
     62 - Sends the imported Jira data and attachments to Trac using the [th:XmlRpcPlugin].
    6464
    65 == Mantis ==
     65== Mantis
    6666
    67 [http://trac-hacks.org/wiki/MantisImportScript MantisImportScript]: script to import the following data from Mantis into Trac:
    68   * bugs
    69   * bug comments
    70   * bug activity (field changes)
    71   * attachments (as long as the files live in the mantis db, not on the filesystem) .
     67[https://trac-hacks.org/wiki/MantisImportScript MantisImportScript]: a script to import the following type of data from Mantis into Trac:
     68 * bugs
     69 * bug comments
     71 * attachments (as long as the files live in the mantis database, not on the filesystem).
    7272
    73 == !PlanetForge ==
     73== !PlanetForge
    7474
    75 [http://trac-hacks.org/wiki/PlanetForgeImportExportPlugin PlanetForgeImportExportPlugin]: this plugin exports Trac data (wiki, tickets, compoments, permissions, repositories, etc.) using the open format designed by the COCLICO project. It extends the webadmin panel and the 'trac admin ...' command. Has no 'import' feature.
     75[https://trac-hacks.org/wiki/PlanetForgeImportExportPlugin PlanetForgeImportExportPlugin]: this plugin exports Trac data (wiki, tickets, compoments, permissions, repositories, etc.) using the open format designed by the [https://gforge.inria.fr/projects/coclico/ COCLICO] project. It extends the webadmin panel and the 'trac admin ...' command. Has no 'import' feature.
    7676
    77 == Scarab ==
     77== Scarab
    7878
    79 [http://trac-hacks.org/wiki/ScarabToTracScript ScarabToTracScript]: script that migrates Scarab issues to Trac tickets. Requires [http://trac-hacks.org/wiki/XmlRpcPlugin XmlRpcPlugin]
     79[https://trac-hacks.org/wiki/ScarabToTracScript ScarabToTracScript]: a script that migrates Scarab issues to Trac tickets. Requires [th:XmlRpcPlugin].
    8080
    81 == Sourceforge ==
     81== Sourceforge
    8282
    83 [http://trac-hacks.org/wiki/SfnToTracScript SfnToTracScript]: importer of !SourceForge's new backup file (originated from #Trac3521).
     83[https://trac-hacks.org/wiki/SfnToTracScript SfnToTracScript]: importer of !SourceForge's new backup file (originated from #Trac3521).
    8484Also, ticket data can be imported from Sourceforge using the [trac:browser:trunk/contrib/sourceforge2trac.py sourceforge2trac.py] script, available in the contrib/ directory of the Trac distribution.
    8585
    86 == Other ==
     86== Other
    8787
    8888Since Trac uses a SQL database to store the data, you can also custom-import from other systems by examining the database tables. Just go into [http://www.sqlite.org/sqlite.html sqlite] command line to look at the tables and import them from your application.
    8989
    90 === Comma delimited file - CSV ===
    91 See [trac:attachment:csv2trac.2.py:wiki:TracSynchronize csv2trac.2.py] for details. This approach is particularly useful if you need to enter a large number of tickets by hand. Note that the ticket type type field, (task etc...) is also needed for this script to work with more recent Trac releases.
     90=== Comma delimited file - CSV
     91
     92See [trac:attachment:csv2trac.2.py:wiki:TracSynchronize csv2trac.2.py] for details. This approach is particularly useful if you need to enter a large number of tickets by hand. Note that the ticket type type field, (task etc.) is also needed for this script to work with more recent Trac releases.
     93
    9294Comments on script: The script has an error on line 168: 'Ticket' needs to be 'ticket'. Also, the listed values for severity and priority are swapped.
    9395
