Changes between Version 3 and Version 4 of TracBackup
1 Feb 2017 00:38:41 (2 years ago)
  • TracBackup
    v3 v4
    33[[TracGuideToc]]
    44
    5 Backups are simply a copied snapshot of the entire [wiki:TracEnvironment project environment] directory, including the database. Backups can be created using the `hotcopy` command in [wiki:TracAdmin trac-admin].
     5Trac backups are simply a copied snapshot of the entire [wiki:TracEnvironment project environment] directory, including the database. Backups can be created using the `hotcopy` command in [wiki:TracAdmin trac-admin].
    66
    77'''Note''': Trac uses the `hotcopy` nomenclature to match that of [http://subversion.tigris.org/ Subversion], to make it easier to remember when managing both Trac and Subversion servers.
    2020Please note, the `hotcopy` command will not overwrite a target directory and when such exists, the operation ends with an error: `Command failed: [Errno 17] File exists:` This is discussed in [trac:ticket:3198 #3198].
    2121
    22 === Restoring a Backup
     22== Restoring a Backup
    2323
    2424To restore an environment from a backup, stop the process running Trac, ie the Web server or [wiki:TracStandalone tracd], restore the contents of your backup (path/to/backupdir) to your [wiki:TracEnvironment project environment] directory and restart the service.
    2828psql -U <user> -d <database> -f postgresql.dump
    2929}}}
     30
    3031The `<database>` option is the same as the [TracEnvironment#DatabaseConnectionStrings database connection string] in the `[trac]` `database` option of //trac.ini//.
    3132
