Changes between Version 1 and Version 2 of InterTrac
10 Jun 2010, 13:36:28 (14 years ago)
  • InterTrac
    v1 v2
    3030The prefix is case insensitive.
    3131
     32When a TracLink is enclosed in brackets, the alias is expanded.  That is, `[th:ticket:1]` is displayed as `trachacks:ticket:1`, since `th` is an alias for `trachacks`.  If the TracLink is not enclosed in brackets, then the alias is displayed as it is typed.
    3234For convenience, there's also some alternative short-hand form,
    3335where one can use an alias as an immediate prefix
    3638
    3739== Examples ==
    38
    39 {{{
    40 #!comment
    41  Besides the other environments run by the same server process
    42  (called ''sibling'' environments), which are automatically detected,
    43 Support for sibling environments has been disabled.
    44 See http://thread.gmane.org/gmane.comp.version-control.subversion.trac.devel/157
    45 }}}
    4640
    4741It is necessary to setup a configuration for the InterTrac facility.
    5751# -- Link to an external Trac:
    5852trac.title = Edgewall's Trac for Trac
    59 trac.url = http://projects.edgewall.com/trac
    60 trac.compat = false
     53trac.url = http://trac.edgewall.org
    6154}}}
    6255
    6962
    7063Finally, the `.compat` option can be used to activate or disable
    71 a ''compatbility'' mode:
    72  * If the targeted Trac is running a version below milestone:0.10
    73    (r3526 to be precise), then it doesn't know how to dispatch an InterTrac
     64a ''compatibility'' mode:
     65 * If the targeted Trac is running a version below [trac:milestone:0.10 0.10]
     66   ([trac:r3526 r3526] to be precise), then it doesn't know how to dispatch an InterTrac
    7467   link, and it's up to the local Trac to prepare the correct link.
    7568   Not all links will work that way, but the most common do.
    7669   This is called the compatibility mode, and is `true` by default.
    7770 * If you know that the remote Trac knows how to dispatch InterTrac links,
    78    you can explicitely disable this compatibility mode and then ''any''
     71   you can explicitly disable this compatibility mode and then ''any''
    7972   TracLinks can become an InterTrac link.
    8073
    9487   * `trac:log:@3300:3330` trac:log:@3300:3330
    9588   * `[trac 3300:3330]` [trac 3300:3330]
     89 * finally, to link to the start page of a remote trac, simply use its prefix followed by ':', inside an explicit link. Example: `[th: Trac Hacks]` (''since 0.11; note that the ''remote'' Trac has to run 0.11 for this to work'')
    9690
    9791The generic form `intertrac_prefix:module:id` is translated
    10296
    10397----
    104 === Discussion ===
    105
    106 I think that the `trac` prefix could even be set as a default in the `[intertrac]` TracIni section. --CB
    107
    108 ----
    10998See also: TracLinks, InterWiki
