Changes between Version 1 and Version 2 of Ticket #2378
- 15 Jul 2022, 19:35:13 (22 months ago)
Ticket #2378 – Description
v1 v2 24 24 Successfully built morecantile 25 25 Installing collected packages: morecantile, rio-cogeo 26 WARNING: The script morecantile is installed in '/home/dbb/.local/bin' which is not on PATH. 27 Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location. 26 28 27 Successfully installed morecantile-3.1.2 rio-cogeo-3.3.0 29 28 … … 98 97 Successfully built rio-color 99 98 Installing collected packages: rfc3986, sniffio, pystac, numexpr, h11, botocore, s3transfer, rio-color, anyio, httpcore, boto3, httpx, rio-tiler 100 WARNING: The script httpx is installed in '/home/dbb/.local/bin' which is not on PATH. 101 Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location. 99 100 102 101 Successfully installed anyio-3.6.1 boto3-1.24.31 botocore-1.27.31 h11-0.12.0 httpcore-0.15.0 httpx-0.23.0 numexpr-2.8.3 pystac-1.4.0 rfc3986-1.5.0 rio-color-1.0.4 rio-tiler-3.1.5 s3transfer-0.6.0 sniffio-1.2.0 103 102
