Changes between Version 5 and Version 6 of pkg-wxpython
Apr 28, 2011, 10:24:16 AM (13 years ago)
jef
  • pkg-wxpython
    v5 v6
    55 * http://download.osgeo.org/osgeo4w/release/python/wxpython/
    66 * http://www.wxpython.org/download.php#stable
    7  * Maintained by ?
     7 * Initial packaged for GRASS by jef
     8 * Maintainer: TBD
     10== Packaging process ==
     12Not sure after 2 years.  Although #85 suggests otherwise, I still have a build directory, which matches the wx DLLs found in {{{bin/}}}.
     13FWIW:
     14
     15{{{
     16diff --exclude-from=wxPython-src-2.8.9.1/exclude -Nur orig/wxPython-src-2.8.9.1/ wxPython-src-2.8.9.1/
     17diff '--exclude-from=wxPython-src-2.8.9.1/exclude' -Nur orig/wxPython-src-2.8.9.1//build/msw/config.vc wxPython-src-2.8.9.1//build/msw/config.vc
     18--- orig/wxPython-src-2.8.9.1//build/msw/config.vc      2008-05-31 08:03:55.000000000 +0200
     19+++ wxPython-src-2.8.9.1//build/msw/config.vc   2009-06-25 23:18:20.000000000 +0200
     20@@ -32,19 +32,19 @@
     21 CPP = $(CC) /EP /nologo
     23 # What type of library to build? [0,1]
     24-SHARED = 0
     25+SHARED = 1
     27 # Build wxUniversal instead of native port? [0,1]
     28 WXUNIV = 0
     29
     30 # Compile Unicode build of wxWidgets? [0,1]
     31-UNICODE = 0
     32+UNICODE = 1
     34 # Use MSLU library when building Unicode version. [0,1]
     35-MSLU = 0
     36+MSLU = 1
     37
     38 # Type of compiled binaries [debug,release]
     39-BUILD = debug
     40+BUILD = release
     41
     42 # The target processor architecture must be specified when it is not X86.
     43 # This does not affect the compiler output, so you still need to make sure
     44@@ -90,7 +90,7 @@
     45 USE_RICHTEXT = 1
     46
     47 # Build OpenGL canvas library (USE_GUI must be 1)? [0,1]
     48-USE_OPENGL = 0
     49+USE_OPENGL = 1
     50
     51 # Build ODBC database classes (USE_GUI must be 1)? [0,1]
     52 USE_ODBC = 0
     53@@ -108,13 +108,13 @@
     54 USE_THREADS = 1
     56 # Link with gdiplus.lib? (Needed for wxGraphicsContext, will also set wxUSE_GRAPHICS_CONTEXT) [0,1]
     57-USE_GDIPLUS = 0
     58+USE_GDIPLUS = 1
     59
     60 # Is this official build by wxWidgets developers? [0,1]
     61-OFFICIAL_BUILD = 0
     62+OFFICIAL_BUILD = 1
     63
     64 # Use this to name your customized DLLs differently
     65-VENDOR = custom
     66+VENDOR =
     67
     68 #
     69 WX_FLAVOUR =
     70diff '--exclude-from=wxPython-src-2.8.9.1/exclude' -Nur orig/wxPython-src-2.8.9.1//exclude wxPython-src-2.8.9.1//exclude
     71--- orig/wxPython-src-2.8.9.1//exclude  1970-01-01 01:00:00.000000000 +0100
     72+++ wxPython-src-2.8.9.1//exclude       2009-04-12 11:59:21.000000000 +0200
     73@@ -0,0 +1,17 @@
     74+*.obj
     75+*.dll
     76+*.pch
     77+*.pdb
     78+*.exp
     79+*.lib
     80+*.res
     81+*.pyc
     82+*.pyd
     83+*.py
     84+*.manifest
     85+*.mo
     86+rcdefs.h
     87+*~
     88+lib.win32-2.5
     89+build.unicode
     90+wx.pth
     91diff '--exclude-from=wxPython-src-2.8.9.1/exclude' -Nur orig/wxPython-src-2.8.9.1//include/wx/defs.h wxPython-src-2.8.9.1//include/wx/defs.h
     92--- orig/wxPython-src-2.8.9.1//include/wx/defs.h        2008-05-12 06:26:45.000000000 +0200
     93+++ wxPython-src-2.8.9.1//include/wx/defs.h     2009-01-30 23:31:51.000000000 +0100
     94@@ -350,11 +350,11 @@
     95     #define wx_truncate_cast(t, x) wx_truncate_cast_impl<t>(x)
     96
     97 #elif defined(__cplusplus) && defined(__VISUALC__) && __VISUALC__ >= 1310
     98-    template <typename T, typename X>
     99-    inline T wx_truncate_cast_impl(X x)
     100+    template <typename wxT, typename wxX>
     101+    inline wxT wx_truncate_cast_impl(wxX x)
     102     {
     103         #pragma warning(push)
     104-        /* conversion from 'X' to 'T', possible loss of data */
     105+        /* conversion from 'wxX' to 'wxT', possible loss of data */
     106         #pragma warning(disable: 4267)
     107
     108         return x;
     109diff '--exclude-from=wxPython-src-2.8.9.1/exclude' -Nur orig/wxPython-src-2.8.9.1//include/wx/msw/setup.h wxPython-src-2.8.9.1//include/wx/msw/setup.h
     110--- orig/wxPython-src-2.8.9.1//include/wx/msw/setup.h   1970-01-01 01:00:00.000000000 +0100
     111+++ wxPython-src-2.8.9.1//include/wx/msw/setup.h        2009-01-31 00:33:52.000000000 +0100
     112@@ -0,0 +1,1349 @@
     113+/////////////////////////////////////////////////////////////////////////////
     114+// Name:        wx/msw/setup.h
     115+// Purpose:     Configuration for the library
     116+// Author:      Julian Smart
     117+// Modified by:
     118+// Created:     01/02/97
     119+// RCS-ID:      $Id: setup0.h 51451 2008-01-29 23:11:55Z VZ $
     120+// Copyright:   (c) Julian Smart
     121+// Licence:     wxWindows licence
     122+/////////////////////////////////////////////////////////////////////////////
     123+
     124+#ifndef _WX_SETUP_H_
     125+#define _WX_SETUP_H_
     126+
     127+/* --- start common options --- */
     128+// ----------------------------------------------------------------------------
     129+// global settings
     130+// ----------------------------------------------------------------------------
     131+
     132+// define this to 0 when building wxBase library - this can also be done from
     133+// makefile/project file overriding the value here
     134+#ifndef wxUSE_GUI
     135+    #define wxUSE_GUI            1
     136+#endif // wxUSE_GUI
     137+
     138+// ----------------------------------------------------------------------------
     139+// compatibility settings
     140+// ----------------------------------------------------------------------------
     141+
     142+// This setting determines the compatibility with 2.4 API: set it to 1 to
     143+// enable it but please consider updating your code instead.
     144+//
     145+// Default is 0
     146+//
     147+// Recommended setting: 0 (please update your code)
     148+#define WXWIN_COMPATIBILITY_2_4 0
     149+
     150+// This setting determines the compatibility with 2.6 API: set it to 0 to
     151+// flag all cases of using deprecated functions.
     152+//
     153+// Default is 1 but please try building your code with 0 as the default will
     154+// change to 0 in the next version and the deprecated functions will disappear
     155+// in the version after it completely.
     156+//
     157+// Recommended setting: 0 (please update your code)
     158+#define WXWIN_COMPATIBILITY_2_6 1
     159+
     160+// MSW-only: Set to 0 for accurate dialog units, else 1 for old behaviour when
     161+// default system font is used for wxWindow::GetCharWidth/Height() instead of
     162+// the current font.
     163+//
     164+// Default is 0
     165+//
     166+// Recommended setting: 0
     167+#define wxDIALOG_UNIT_COMPATIBILITY   0
     168+
     169+// ----------------------------------------------------------------------------
     170+// debugging settings
     171+// ----------------------------------------------------------------------------
     172+
     173+// Generic comment about debugging settings: they are very useful if you don't
     174+// use any other memory leak detection tools such as Purify/BoundsChecker, but
     175+// are probably redundant otherwise. Also, Visual C++ CRT has the same features
     176+// as wxWidgets memory debugging subsystem built in since version 5.0 and you
     177+// may prefer to use it instead of built in memory debugging code because it is
     178+// faster and more fool proof.
     179+//
     180+// Using VC++ CRT memory debugging is enabled by default in debug mode
     181+// (__WXDEBUG__) if wxUSE_GLOBAL_MEMORY_OPERATORS is *not* enabled (i.e. is 0)
     182+// and if __NO_VC_CRTDBG__ is not defined.
     183+
     184+// If 1, enables wxDebugContext, for writing error messages to file, etc. If
     185+// __WXDEBUG__ is not defined, will still use the normal memory operators.
     186+//
     187+// Default is 0
     188+//
     189+// Recommended setting: 0
     190+#define wxUSE_DEBUG_CONTEXT 0
     191+
     192+// If 1, enables debugging versions of wxObject::new and wxObject::delete *IF*
     193+// __WXDEBUG__ is also defined.
     194+//
     195+// WARNING: this code may not work with all architectures, especially if
     196+// alignment is an issue. This switch is currently ignored for mingw / cygwin
     197+//
     198+// Default is 0
     199+//
     200+// Recommended setting: 1 if you are not using a memory debugging tool, else 0
     201+#define wxUSE_MEMORY_TRACING 0
     202+
     203+// In debug mode, cause new and delete to be redefined globally.
     204+// If this causes problems (e.g. link errors which is a common problem
     205+// especially if you use another library which also redefines the global new
     206+// and delete), set this to 0.
     207+// This switch is currently ignored for mingw / cygwin
     208+//
     209+// Default is 0
     210+//
     211+// Recommended setting: 0
     212+#define wxUSE_GLOBAL_MEMORY_OPERATORS 0
     213+
     214+// In debug mode, causes new to be defined to be WXDEBUG_NEW (see object.h). If
     215+// this causes problems (e.g. link errors), set this to 0. You may need to set
     216+// this to 0 if using templates (at least for VC++). This switch is currently
     217+// ignored for mingw / cygwin / CodeWarrior
     218+//
     219+// Default is 0
     220+//
     221+// Recommended setting: 0
     222+#define wxUSE_DEBUG_NEW_ALWAYS 0
     223+
     224+// wxHandleFatalExceptions() may be used to catch the program faults at run
     225+// time and, instead of terminating the program with a usual GPF message box,
     226+// call the user-defined wxApp::OnFatalException() function. If you set
     227+// wxUSE_ON_FATAL_EXCEPTION to 0, wxHandleFatalExceptions() will not work.
     228+//
     229+// This setting is for Win32 only and can only be enabled if your compiler
     230+// supports Win32 structured exception handling (currently only VC++ does)
     231+//
     232+// Default is 1
     233+//
     234+// Recommended setting: 1 if your compiler supports it.
     235+#define wxUSE_ON_FATAL_EXCEPTION 1
     236+
     237+// Set this to 1 to be able to generate a human-readable (unlike
     238+// machine-readable minidump created by wxCrashReport::Generate()) stack back
     239+// trace when your program crashes using wxStackWalker
     240+//
     241+// Default is 1 if supported by the compiler.
     242+//
     243+// Recommended setting: 1, set to 0 if your programs never crash
     244+#define wxUSE_STACKWALKER 1
     245+
     246+// Set this to 1 to compile in wxDebugReport class which allows you to create
     247+// and optionally upload to your web site a debug report consisting of back
     248+// trace of the crash (if wxUSE_STACKWALKER == 1) and other information.
     249+//
     250+// Default is 1 if supported by the compiler.
     251+//
     252+// Recommended setting: 1, it is compiled into a separate library so there
     253+//                         is no overhead if you don't use it
     254+#define wxUSE_DEBUGREPORT 0
     255+
     256+// ----------------------------------------------------------------------------
     257+// Unicode support
     258+// ----------------------------------------------------------------------------
     259+
     260+// Set wxUSE_UNICODE to 1 to compile wxWidgets in Unicode mode: wxChar will be
     261+// defined as wchar_t, wxString will use Unicode internally. If you set this
     262+// to 1, you must use wxT() macro for all literal strings in the program.
     263+//
     264+// Unicode is currently only fully supported under Windows NT/2000/XP
     265+// (Windows 9x doesn't support it and the programs compiled in Unicode mode
     266+// will not run under 9x -- but see wxUSE_UNICODE_MSLU below).
     267+//
     268+// Default is 0
     269+//
     270+// Recommended setting: 0 (unless you only plan to use Windows NT/2000/XP)
     271+#ifndef wxUSE_UNICODE
     272+    #define wxUSE_UNICODE 1
     273+#endif
     274+
     275+// Setting wxUSE_WCHAR_T to 1 gives you some degree of Unicode support without
     276+// compiling the program in Unicode mode. More precisely, it will be possible
     277+// to construct wxString from a wide (Unicode) string and convert any wxString
     278+// to Unicode.
     279+//
     280+// Default is 1
     281+//
     282+// Recommended setting: 1
     283+#define wxUSE_WCHAR_T 1
     284+
     285+// ----------------------------------------------------------------------------
     286+// global features
     287+// ----------------------------------------------------------------------------
     288+
     289+// Compile library in exception-safe mode? If set to 1, the library will try to
     290+// behave correctly in presence of exceptions (even though it still will not
     291+// use the exceptions itself) and notify the user code about any unhandled
     292+// exceptions. If set to 0, propagation of the exceptions through the library
     293+// code will lead to undefined behaviour -- but the code itself will be
     294+// slightly smaller and faster.
     295+//
     296+// Note that like wxUSE_THREADS this option is automatically set to 0 if
     297+// wxNO_EXCEPTIONS is defined.
     298+//
     299+// Default is 1
     300+//
     301+// Recommended setting: depends on whether you intend to use C++ exceptions
     302+//                      in your own code (1 if you do, 0 if you don't)
     303+#define wxUSE_EXCEPTIONS    0
     304+
     305+// Set wxUSE_EXTENDED_RTTI to 1 to use extended RTTI
     306+//
     307+// Default is 0
     308+//
     309+// Recommended setting: 0 (this is still work in progress...)
     310+#define wxUSE_EXTENDED_RTTI 0
     311+
     312+// Set wxUSE_STL to 1 to derive wxList(Foo) and wxArray(Foo) from
     313+// std::list<Foo*> and std::vector<Foo*>, with a compatibility interface,
     314+// and for wxHashMap to be implemented with templates.
     315+//
     316+// Default is 0
     317+//
     318+// Recommended setting: YMMV
     319+#define wxUSE_STL 0
     320+
     321+// Support for message/error logging. This includes wxLogXXX() functions and
     322+// wxLog and derived classes. Don't set this to 0 unless you really know what
     323+// you are doing.
     324+//
     325+// Default is 1
     326+//
     327+// Recommended setting: 1 (always)
     328+#define wxUSE_LOG 1
     329+
     330+// Recommended setting: 1
     331+#define wxUSE_LOGWINDOW 1
     332+
     333+// Recommended setting: 1
     334+#define wxUSE_LOGGUI 1
     335+
     336+// Recommended setting: 1
     337+#define wxUSE_LOG_DIALOG 1
     338+
     339+// Support for command line parsing using wxCmdLineParser class.
     340+//
     341+// Default is 1
     342+//
     343+// Recommended setting: 1 (can be set to 0 if you don't use the cmd line)
     344+#define wxUSE_CMDLINE_PARSER 1
     345+
     346+// Support for multithreaded applications: if 1, compile in thread classes
     347+// (thread.h) and make the library a bit more thread safe. Although thread
     348+// support is quite stable by now, you may still consider recompiling the
     349+// library without it if you have no use for it - this will result in a
     350+// somewhat smaller and faster operation.
     351+//
     352+// Notice that if wxNO_THREADS is defined, wxUSE_THREADS is automatically reset
     353+// to 0 in wx/chkconf.h, so, for example, if you set USE_THREADS to 0 in
     354+// build/msw/config.* file this value will have no effect.
     355+//
     356+// Default is 1
     357+//
     358+// Recommended setting: 0 unless you do plan to develop MT applications
     359+#define wxUSE_THREADS 1
     360+
     361+// If enabled, compiles wxWidgets streams classes
     362+//
     363+// wx stream classes are used for image IO, process IO redirection, network
     364+// protocols implementation and much more and so disabling this results in a
     365+// lot of other functionality being lost.
     366+//
     367+// Default is 1
     368+//
     369+// Recommended setting: 1 as setting it to 0 disables many other things
     370+#define wxUSE_STREAMS       1
     371+
     372+// Use standard C++ streams if 1 instead of wx streams in some places. If
     373+// disabled (default), wx streams are used everywhere and wxWidgets doesn't
     374+// depend on the standard streams library.
     375+//
     376+// Notice that enabling this does not replace wx streams with std streams
     377+// everywhere, in a lot of places wx streams are used no matter what.
     378+//
     379+// Default is 0
     380+//
     381+// Recommended setting: 1 if you use the standard streams anyhow and so
     382+//                      dependency on the standard streams library is not a
     383+//                      problem
     384+#define wxUSE_STD_IOSTREAM  0
     385+
     386+// Enable conversion to standard C++ string if 1.
     387+//
     388+// Default is 1 for most compilers.
     389+//
     390+// Currently the Digital Mars and Watcom compilers come without standard C++
     391+// library headers by default, wxUSE_STD_STRING can be set to 1 if you do have
     392+// them (e.g. from STLPort).
     393+//
     394+// VC++ 5.0 does include standard C++ library header, however they produce
     395+// many warnings that can't be turned off when compiled at warning level 4.
     396+#if defined(__DMC__) || defined(__WATCOMC__) \
     397+        || (defined(_MSC_VER) && _MSC_VER < 1200)
     398+    #define wxUSE_STD_STRING  0
     399+#else
     400+    #define wxUSE_STD_STRING  1
     401+#endif
     402+
     403+// Support for positional parameters (e.g. %1$d, %2$s ...) in wxVsnprintf.
     404+// Note that if the system's implementation does not support positional
     405+// parameters, setting this to 1 forces the use of the wxWidgets implementation
     406+// of wxVsnprintf. The standard vsnprintf() supports positional parameters on
     407+// many Unix systems but usually doesn't under Windows.
     408+//
     409+// Positional parameters are very useful when translating a program since using
     410+// them in formatting strings allow translators to correctly reorder the
     411+// translated sentences.
     412+//
     413+// Default is 1
     414+//
     415+// Recommended setting: 1 if you want to support multiple languages
     416+#define wxUSE_PRINTF_POS_PARAMS      1
     417+
     418+// ----------------------------------------------------------------------------
     419+// non GUI features selection
     420+// ----------------------------------------------------------------------------
     421+
     422+// Set wxUSE_LONGLONG to 1 to compile the wxLongLong class. This is a 64 bit
     423+// integer which is implemented in terms of native 64 bit integers if any or
     424+// uses emulation otherwise.
     425+//
     426+// This class is required by wxDateTime and so you should enable it if you want
     427+// to use wxDateTime. For most modern platforms, it will use the native 64 bit
     428+// integers in which case (almost) all of its functions are inline and it
     429+// almost does not take any space, so there should be no reason to switch it
     430+// off.
     431+//
     432+// Recommended setting: 1
     433+#define wxUSE_LONGLONG      1
     434+
     435+// Set wxUSE_(F)FILE to 1 to compile wx(F)File classes. wxFile uses low level
     436+// POSIX functions for file access, wxFFile uses ANSI C stdio.h functions.
     437+//
     438+// Default is 1
     439+//
     440+// Recommended setting: 1 (wxFile is highly recommended as it is required by
     441+// i18n code, wxFileConfig and others)
     442+#define wxUSE_FILE          1
     443+#define wxUSE_FFILE         1
     444+
     445+// Use wxFSVolume class providing access to the configured/active mount points
     446+//
     447+// Default is 1
     448+//
     449+// Recommended setting: 1 (but may be safely disabled if you don't use it)
     450+#define wxUSE_FSVOLUME      1
     451+
     452+// Use wxStandardPaths class which allows to retrieve some standard locations
     453+// in the file system
     454+//
     455+// Default is 1
     456+//
     457+// Recommended setting: 1 (may be disabled to save space, but not much)
     458+#define wxUSE_STDPATHS      1
     459+
     460+// use wxTextBuffer class: required by wxTextFile
     461+#define wxUSE_TEXTBUFFER    1
     462+
     463+// use wxTextFile class: requires wxFile and wxTextBuffer, required by
     464+// wxFileConfig
     465+#define wxUSE_TEXTFILE      1
     466+
     467+// i18n support: _() macro, wxLocale class. Requires wxTextFile.
     468+#define wxUSE_INTL          1
     469+
     470+// Set wxUSE_DATETIME to 1 to compile the wxDateTime and related classes which
     471+// allow to manipulate dates, times and time intervals. wxDateTime replaces the
     472+// old wxTime and wxDate classes which are still provided for backwards
     473+// compatibility (and implemented in terms of wxDateTime).
     474+//
     475+// Note that this class is relatively new and is still officially in alpha
     476+// stage because some features are not yet (fully) implemented. It is already
     477+// quite useful though and should only be disabled if you are aiming at
     478+// absolutely minimal version of the library.
     479+//
     480+// Requires: wxUSE_LONGLONG
     481+//
     482+// Default is 1
     483+//
     484+// Recommended setting: 1
     485+#define wxUSE_DATETIME      1
     486+
     487+// Set wxUSE_TIMER to 1 to compile wxTimer class
     488+//
     489+// Default is 1
     490+//
     491+// Recommended setting: 1
     492+#define wxUSE_TIMER         1
     493+
     494+// Use wxStopWatch clas.
     495+//
     496+// Default is 1
     497+//
     498+// Recommended setting: 1 (needed by wxSocket)
     499+#define wxUSE_STOPWATCH     1
     500+
     501+// Setting wxUSE_CONFIG to 1 enables the use of wxConfig and related classes
     502+// which allow the application to store its settings in the persistent
     503+// storage. Setting this to 1 will also enable on-demand creation of the
     504+// global config object in wxApp.
     505+//
     506+// See also wxUSE_CONFIG_NATIVE below.
     507+//
     508+// Recommended setting: 1
     509+#define wxUSE_CONFIG        1
     510+
     511+// If wxUSE_CONFIG is 1, you may choose to use either the native config
     512+// classes under Windows (using .INI files under Win16 and the registry under
     513+// Win32) or the portable text file format used by the config classes under
     514+// Unix.
     515+//
     516+// Default is 1 to use native classes. Note that you may still use
     517+// wxFileConfig even if you set this to 1 - just the config object created by
     518+// default for the applications needs will be a wxRegConfig or wxIniConfig and
     519+// not wxFileConfig.
     520+//
     521+// Recommended setting: 1
     522+#define wxUSE_CONFIG_NATIVE   1
     523+
     524+// If wxUSE_DIALUP_MANAGER is 1, compile in wxDialUpManager class which allows
     525+// to connect/disconnect from the network and be notified whenever the dial-up
     526+// network connection is established/terminated. Requires wxUSE_DYNAMIC_LOADER.
     527+//
     528+// Default is 1.
     529+//
     530+// Recommended setting: 1
     531+#define wxUSE_DIALUP_MANAGER   0
     532+
     533+// Compile in classes for run-time DLL loading and function calling.
     534+// Required by wxUSE_DIALUP_MANAGER.
     535+//
     536+// This setting is for Win32 only
     537+//
     538+// Default is 1.
     539+//
     540+// Recommended setting: 1
     541+#define wxUSE_DYNLIB_CLASS    1
     542+
     543+// experimental, don't use for now
     544+#define wxUSE_DYNAMIC_LOADER  1
     545+
     546+// Set to 1 to use socket classes
     547+#define wxUSE_SOCKETS       1
     548+
     549+// Set to 1 to enable virtual file systems (required by wxHTML)
     550+#define wxUSE_FILESYSTEM    1
     551+
     552+// Set to 1 to enable virtual ZIP filesystem (requires wxUSE_FILESYSTEM)
     553+#define wxUSE_FS_ZIP        1
     554+
     555+// Set to 1 to enable virtual archive filesystem (requires wxUSE_FILESYSTEM)
     556+#define wxUSE_FS_ARCHIVE    1
     557+
     558+// Set to 1 to enable virtual Internet filesystem (requires wxUSE_FILESYSTEM)
     559+#define wxUSE_FS_INET       1
     560+
     561+// wxArchive classes for accessing archives such as zip and tar
     562+#define wxUSE_ARCHIVE_STREAMS     1
     563+
     564+// Set to 1 to compile wxZipInput/OutputStream classes.
     565+#define wxUSE_ZIPSTREAM     1
     566+
     567+// Set to 1 to compile wxTarInput/OutputStream classes.
     568+#define wxUSE_TARSTREAM     1
     569+
     570+// Set to 1 to compile wxZlibInput/OutputStream classes. Also required by
     571+// wxUSE_LIBPNG
     572+#define wxUSE_ZLIB          1
     573+
     574+// If enabled, the code written by Apple will be used to write, in a portable
     575+// way, float on the disk. See extended.c for the license which is different
     576+// from wxWidgets one.
     577+//
     578+// Default is 1.
     579+//
     580+// Recommended setting: 1 unless you don't like the license terms (unlikely)
     581+#define wxUSE_APPLE_IEEE          1
     582+
     583+// Joystick support class
     584+#define wxUSE_JOYSTICK            1
     585+
     586+// wxFontMapper class
     587+#define wxUSE_FONTMAP 1
     588+
     589+// wxMimeTypesManager class
     590+#define wxUSE_MIMETYPE 1
     591+
     592+// wxProtocol and related classes: if you want to use either of wxFTP, wxHTTP
     593+// or wxURL you need to set this to 1.
     594+//
     595+// Default is 1.
     596+//
     597+// Recommended setting: 1
     598+#define wxUSE_PROTOCOL 1
     599+
     600+// The settings for the individual URL schemes
     601+#define wxUSE_PROTOCOL_FILE 1
     602+#define wxUSE_PROTOCOL_FTP 1
     603+#define wxUSE_PROTOCOL_HTTP 1
     604+
     605+// Define this to use wxURL class.
     606+#define wxUSE_URL 1
     607+
     608+// Define this to use native platform url and protocol support.
     609+// Currently valid only for MS-Windows.
     610+// Note: if you set this to 1, you can open ftp/http/gopher sites
     611+// and obtain a valid input stream for these sites
     612+// even when you set wxUSE_PROTOCOL_FTP/HTTP to 0.
     613+// Doing so reduces the code size.
     614+//
     615+// This code is experimental and subject to change.
     616+#define wxUSE_URL_NATIVE 0
     617+
     618+// Support for wxVariant class used in several places throughout the library,
     619+// notably in wxDataViewCtrl API.
     620+//
     621+// Default is 1.
     622+//
     623+// Recommended setting: 1 unless you want to reduce the library size as much as
     624+// possible in which case setting this to 0 can gain up to 100KB.
     625+#define wxUSE_VARIANT 1
     626+
     627+// Support for regular expression matching via wxRegEx class: enable this to
     628+// use POSIX regular expressions in your code. You need to compile regex
     629+// library from src/regex to use it under Windows.
     630+//
     631+// Default is 0
     632+//
     633+// Recommended setting: 1 if your compiler supports it, if it doesn't please
     634+// contribute us a makefile for src/regex for it
     635+#define wxUSE_REGEX       1
     636+
     637+// wxSystemOptions class
     638+#define wxUSE_SYSTEM_OPTIONS 1
     639+
     640+// wxSound class
     641+#define wxUSE_SOUND      1
     642+
     643+// Use wxMediaCtrl
     644+//
     645+// Default is 1.
     646+//
     647+// Recommended setting: 1
     648+#define wxUSE_MEDIACTRL     1
     649+
     650+// Use GStreamer for Unix (req a lot of dependancies)
     651+//
     652+// Default is 0
     653+//
     654+// Recommended setting: 1 (wxMediaCtrl won't work by default without it)
     655+#define wxUSE_GSTREAMER    0
     656+
     657+// Use wxWidget's XRC XML-based resource system.  Recommended.
     658+//
     659+// Default is 1
     660+//
     661+// Recommended setting: 1 (requires wxUSE_XML)
     662+#define wxUSE_XRC       1
     663+
     664+// XML parsing classes. Note that their API will change in the future, so
     665+// using wxXmlDocument and wxXmlNode in your app is not recommended.
     666+//
     667+// Default is the same as wxUSE_XRC, i.e. 1 by default.
     668+//
     669+// Recommended setting: 1 (required by XRC)
     670+#define wxUSE_XML       wxUSE_XRC
     671+
     672+// Use wxWidget's AUI docking system
     673+//
     674+// Default is 1
     675+//
     676+// Recommended setting: 1
     677+#define wxUSE_AUI       1
     678+
     679+
     680+// Enable the new wxGraphicsPath and wxGraphicsContext classes for an advanced
     681+// 2D drawing API.  (Still somewhat experimental)
     682+//
     683+// Please note that on Windows you will need to link with gdiplus.lib (use
     684+// USE_GDIPLUS=1 for makefile builds) and distribute gdiplus.dll with your
     685+// application if you want it to be runnable on pre-XP systems.
     686+//
     687+// Default is 0
     688+//
     689+// Recommended setting: 1
     690+#ifndef wxUSE_GRAPHICS_CONTEXT
     691+#define wxUSE_GRAPHICS_CONTEXT 1
     692+#endif
     693+
     694+// ----------------------------------------------------------------------------
     695+// Individual GUI controls
     696+// ----------------------------------------------------------------------------
     697+
     698+// You must set wxUSE_CONTROLS to 1 if you are using any controls at all
     699+// (without it, wxControl class is not compiled)
     700+//
     701+// Default is 1
     702+//
     703+// Recommended setting: 1 (don't change except for very special programs)
     704+#define wxUSE_CONTROLS     1
     705+
     706+// wxPopupWindow class is a top level transient window. It is currently used
     707+// to implement wxTipWindow
     708+//
     709+// Default is 1
     710+//
     711+// Recommended setting: 1 (may be set to 0 if you don't wxUSE_TIPWINDOW)
     712+#define wxUSE_POPUPWIN     1
     713+
     714+// wxTipWindow allows to implement the custom tooltips, it is used by the
     715+// context help classes. Requires wxUSE_POPUPWIN.
     716+//
     717+// Default is 1
     718+//
     719+// Recommended setting: 1 (may be set to 0)
     720+#define wxUSE_TIPWINDOW    1
     721+
     722+// Each of the settings below corresponds to one wxWidgets control. They are
     723+// all switched on by default but may be disabled if you are sure that your
     724+// program (including any standard dialogs it can show!) doesn't need them and
     725+// if you desperately want to save some space. If you use any of these you must
     726+// set wxUSE_CONTROLS as well.
     727+//
     728+// Default is 1
     729+//
     730+// Recommended setting: 1
     731+#define wxUSE_ANIMATIONCTRL 1   // wxAnimationCtrl
     732+#define wxUSE_BUTTON        1   // wxButton
     733+#define wxUSE_BMPBUTTON     1   // wxBitmapButton
     734+#define wxUSE_CALENDARCTRL  1   // wxCalendarCtrl
     735+#define wxUSE_CHECKBOX      1   // wxCheckBox
     736+#define wxUSE_CHECKLISTBOX  1   // wxCheckListBox (requires wxUSE_OWNER_DRAWN)
     737+#define wxUSE_CHOICE        1   // wxChoice
     738+#define wxUSE_COLLPANE      1   // wxCollapsiblePane
     739+#define wxUSE_COLOURPICKERCTRL 1    // wxColourPickerCtrl
     740+#define wxUSE_COMBOBOX      1   // wxComboBox
     741+#define wxUSE_DATAVIEWCTRL  1   // wxDataViewCtrl
     742+#define wxUSE_DATEPICKCTRL  1   // wxDatePickerCtrl
     743+#define wxUSE_DIRPICKERCTRL 1   // wxDirPickerCtrl
     744+#define wxUSE_FILEPICKERCTRL 1  // wxFilePickerCtrl
     745+#define wxUSE_FONTPICKERCTRL 1  // wxFontPickerCtrl
     746+#define wxUSE_GAUGE         1   // wxGauge
     747+#define wxUSE_HYPERLINKCTRL 1   // wxHyperlinkCtrl
     748+#define wxUSE_LISTBOX       1   // wxListBox
     749+#define wxUSE_LISTCTRL      1   // wxListCtrl
     750+#define wxUSE_RADIOBOX      1   // wxRadioBox
     751+#define wxUSE_RADIOBTN      1   // wxRadioButton
     752+#define wxUSE_SCROLLBAR     1   // wxScrollBar
     753+#define wxUSE_SEARCHCTRL    1   // wxSearchCtrl
     754+#define wxUSE_SLIDER        1   // wxSlider
     755+#define wxUSE_SPINBTN       1   // wxSpinButton
     756+#define wxUSE_SPINCTRL      1   // wxSpinCtrl
     757+#define wxUSE_STATBOX       1   // wxStaticBox
     758+#define wxUSE_STATLINE      1   // wxStaticLine
     759+#define wxUSE_STATTEXT      1   // wxStaticText
     760+#define wxUSE_STATBMP       1   // wxStaticBitmap
     761+#define wxUSE_TEXTCTRL      1   // wxTextCtrl
     762+#define wxUSE_TOGGLEBTN     1   // requires wxButton
     763+#define wxUSE_TREECTRL      1   // wxTreeCtrl
     764+
     765+// Use a status bar class? Depending on the value of wxUSE_NATIVE_STATUSBAR
     766+// below either wxStatusBar95 or a generic wxStatusBar will be used.
     767+//
     768+// Default is 1
     769+//
     770+// Recommended setting: 1
     771+#define wxUSE_STATUSBAR    1
     772+
     773+// Two status bar implementations are available under Win32: the generic one
     774+// or the wrapper around native control. For native look and feel the native
     775+// version should be used.
     776+//
     777+// Default is 1 for the platforms where native status bar is supported.
     778+//
     779+// Recommended setting: 1 (there is no advantage in using the generic one)
     780+#define wxUSE_NATIVE_STATUSBAR        1
     781+
     782+// wxToolBar related settings: if wxUSE_TOOLBAR is 0, don't compile any toolbar
     783+// classes at all. Otherwise, use the native toolbar class unless
     784+// wxUSE_TOOLBAR_NATIVE is 0.
     785+//
     786+// Default is 1 for all settings.
     787+//
     788+// Recommended setting: 1 for wxUSE_TOOLBAR and wxUSE_TOOLBAR_NATIVE.
     789+#define wxUSE_TOOLBAR 1
     790+#define wxUSE_TOOLBAR_NATIVE 1
     791+
     792+// wxNotebook is a control with several "tabs" located on one of its sides. It
     793+// may be used to logically organise the data presented to the user instead of
     794+// putting everything in one huge dialog. It replaces wxTabControl and related
     795+// classes of wxWin 1.6x.
     796+//
     797+// Default is 1.
     798+//
     799+// Recommended setting: 1
     800+#define wxUSE_NOTEBOOK 1
     801+
     802+// wxListbook control is similar to wxNotebook but uses wxListCtrl instead of
     803+// the tabs
     804+//
     805+// Default is 1.
     806+//
     807+// Recommended setting: 1
     808+#define wxUSE_LISTBOOK 1
     809+
     810+// wxChoicebook control is similar to wxNotebook but uses wxChoice instead of
     811+// the tabs
     812+//
     813+// Default is 1.
     814+//
     815+// Recommended setting: 1
     816+#define wxUSE_CHOICEBOOK 1
     817+
     818+// wxTreebook control is similar to wxNotebook but uses wxTreeCtrl instead of
     819+// the tabs
     820+//
     821+// Default is 1.
     822+//
     823+// Recommended setting: 1
     824+#define wxUSE_TREEBOOK 1
     825+
     826+// wxToolbook control is similar to wxNotebook but uses wxToolBar instead of
     827+// tabs
     828+//
     829+// Default is 1.
     830+//
     831+// Recommended setting: 1
     832+#define wxUSE_TOOLBOOK 1
     833+
     834+// wxTabDialog is a generic version of wxNotebook but it is incompatible with
     835+// the new class. It shouldn't be used in new code.
     836+//
     837+// Default is 0.
     838+//
     839+// Recommended setting: 0 (use wxNotebook)
     840+#define wxUSE_TAB_DIALOG    0
     841+
     842+// wxGrid class
     843+//
     844+// Default is 1, set to 0 to cut down compilation time and binaries size if you
     845+// don't use it.
     846+//
     847+// Recommended setting: 1
     848+//
     849+#define wxUSE_GRID         1
     850+
     851+// wxMiniFrame class: a frame with narrow title bar
     852+//
     853+// Default is 1.
     854+//
     855+// Recommended setting: 1 (it doesn't cost almost anything)
     856+#define wxUSE_MINIFRAME 1
     857+
     858+// wxComboCtrl and related classes: combobox with custom popup window and
     859+// not necessarily a listbox.
     860+//
     861+// Default is 1.
     862+//
     863+// Recommended setting: 1 but can be safely set to 0 except for wxUniv where it
     864+//                      it used by wxComboBox
     865+#define wxUSE_COMBOCTRL 1
     866+
     867+// wxOwnerDrawnComboBox is a custom combobox allowing to paint the combobox
     868+// items.
     869+//
     870+// Default is 1.
     871+//
     872+// Recommended setting: 1 but can be safely set to 0, except where it is
     873+//                      needed as a base class for generic wxBitmapComboBox.
     874+#define wxUSE_ODCOMBOBOX 1
     875+
     876+// wxBitmapComboBox is a combobox that can have images in front of text items.
     877+//
     878+// Default is 1.
     879+//
     880+// Recommended setting: 1 but can be safely set to 0
     881+#define wxUSE_BITMAPCOMBOBOX 1
     882+
     883+// ----------------------------------------------------------------------------
     884+// Miscellaneous GUI stuff
     885+// ----------------------------------------------------------------------------
     886+
     887+// wxAcceleratorTable/Entry classes and support for them in wxMenu(Bar)
     888+#define wxUSE_ACCEL 1
     889+
     890+// Hotkey support (currently Windows only)
     891+#define wxUSE_HOTKEY 1
     892+
     893+// Use wxCaret: a class implementing a "cursor" in a text control (called caret
     894+// under Windows).
     895+//
     896+// Default is 1.
     897+//
     898+// Recommended setting: 1 (can be safely set to 0, not used by the library)
     899+#define wxUSE_CARET         1
     900+
     901+// Use wxDisplay class: it allows enumerating all displays on a system and
     902+// their geometries as well as finding the display on which the given point or
     903+// window lies.
     904+//
     905+// Default is 1.
     906+//
     907+// Recommended setting: 1 if you need it, can be safely set to 0 otherwise
     908+#define wxUSE_DISPLAY       1
     909+
     910+// Miscellaneous geometry code: needed for Canvas library
     911+#define wxUSE_GEOMETRY            1
     912+
     913+// Use wxImageList. This class is needed by wxNotebook, wxTreeCtrl and
     914+// wxListCtrl.
     915+//
     916+// Default is 1.
     917+//
     918+// Recommended setting: 1 (set it to 0 if you don't use any of the controls
     919+// enumerated above, then this class is mostly useless too)
     920+#define wxUSE_IMAGLIST      1
     921+
     922+// Use wxMenu, wxMenuBar, wxMenuItem.
     923+//
     924+// Default is 1.
     925+//
     926+// Recommended setting: 1 (can't be disabled under MSW)
     927+#define wxUSE_MENUS         1
     928+
     929+// Use wxSashWindow class.
     930+//
     931+// Default is 1.
     932+//
     933+// Recommended setting: 1
     934+#define wxUSE_SASH          1
     935+
     936+// Use wxSplitterWindow class.
     937+//
     938+// Default is 1.
     939+//
     940+// Recommended setting: 1
     941+#define wxUSE_SPLITTER      1
     942+
     943+// Use wxToolTip and wxWindow::Set/GetToolTip() methods.
     944+//
     945+// Default is 1.
     946+//
     947+// Recommended setting: 1
     948+#define wxUSE_TOOLTIPS      1
     949+
     950+// wxValidator class and related methods
     951+#define wxUSE_VALIDATORS 1
     952+
     953+// ----------------------------------------------------------------------------
     954+// common dialogs
     955+// ----------------------------------------------------------------------------
     956+
     957+// On rare occasions (e.g. using DJGPP) may want to omit common dialogs (e.g.
     958+// file selector, printer dialog). Switching this off also switches off the
     959+// printing architecture and interactive wxPrinterDC.
     960+//
     961+// Default is 1
     962+//
     963+// Recommended setting: 1 (unless it really doesn't work)
     964+#define wxUSE_COMMON_DIALOGS 1
     965+
     966+// wxBusyInfo displays window with message when app is busy. Works in same way
     967+// as wxBusyCursor
     968+#define wxUSE_BUSYINFO      1
     969+
     970+// Use single/multiple choice dialogs.
     971+//
     972+// Default is 1
     973+//
     974+// Recommended setting: 1 (used in the library itself)
     975+#define wxUSE_CHOICEDLG     1
     976+
     977+// Use colour picker dialog
     978+//
     979+// Default is 1
     980+//
     981+// Recommended setting: 1
     982+#define wxUSE_COLOURDLG     1
     983+
     984+// wxDirDlg class for getting a directory name from user
     985+#define wxUSE_DIRDLG 1
     986+
     987+// TODO: setting to choose the generic or native one
     988+
     989+// Use file open/save dialogs.
     990+//
     991+// Default is 1
     992+//
     993+// Recommended setting: 1 (used in many places in the library itself)
     994+#define wxUSE_FILEDLG       1
     995+
     996+// Use find/replace dialogs.
     997+//
     998+// Default is 1
     999+//
     1000+// Recommended setting: 1 (but may be safely set to 0)
     1001+#define wxUSE_FINDREPLDLG       1
     1002+
     1003+// Use font picker dialog
     1004+//
     1005+// Default is 1
     1006+//
     1007+// Recommended setting: 1 (used in the library itself)
     1008+#define wxUSE_FONTDLG       1
     1009+
     1010+// Use wxMessageDialog and wxMessageBox.
     1011+//
     1012+// Default is 1
     1013+//
     1014+// Recommended setting: 1 (used in the library itself)
     1015+#define wxUSE_MSGDLG        1
     1016+
     1017+// progress dialog class for lengthy operations
     1018+#define wxUSE_PROGRESSDLG 1
     1019+
     1020+// support for startup tips (wxShowTip &c)
     1021+#define wxUSE_STARTUP_TIPS 1
     1022+
     1023+// text entry dialog and wxGetTextFromUser function
     1024+#define wxUSE_TEXTDLG 1
     1025+
     1026+// number entry dialog
     1027+#define wxUSE_NUMBERDLG 1
     1028+
     1029+// splash screen class
     1030+#define wxUSE_SPLASH 1
     1031+
     1032+// wizards
     1033+#define wxUSE_WIZARDDLG 1
     1034+
     1035+// Compile in wxAboutBox() function showing the standard "About" dialog.
     1036+//
     1037+// Default is 1
     1038+//
     1039+// Recommended setting: 1 but can be set to 0 to save some space if you don't
     1040+//                      use this function
     1041+#define wxUSE_ABOUTDLG 1
     1042+
     1043+// ----------------------------------------------------------------------------
     1044+// Metafiles support
     1045+// ----------------------------------------------------------------------------
     1046+
     1047+// Windows supports the graphics format known as metafile which is, though not
     1048+// portable, is widely used under Windows and so is supported by wxWin (under
     1049+// Windows only, of course). Win16 (Win3.1) used the so-called "Window
     1050+// MetaFiles" or WMFs which were replaced with "Enhanced MetaFiles" or EMFs in
     1051+// Win32 (Win9x, NT, 2000). Both of these are supported in wxWin and, by
     1052+// default, WMFs will be used under Win16 and EMFs under Win32. This may be
     1053+// changed by setting wxUSE_WIN_METAFILES_ALWAYS to 1 and/or setting
     1054+// wxUSE_ENH_METAFILE to 0. You may also set wxUSE_METAFILE to 0 to not compile
     1055+// in any metafile related classes at all.
     1056+//
     1057+// Default is 1 for wxUSE_ENH_METAFILE and 0 for wxUSE_WIN_METAFILES_ALWAYS.
     1058+//
     1059+// Recommended setting: default or 0 for everything for portable programs.
     1060+#define wxUSE_METAFILE              1
     1061+#define wxUSE_ENH_METAFILE          1
     1062+#define wxUSE_WIN_METAFILES_ALWAYS  0
     1063+
     1064+// ----------------------------------------------------------------------------
     1065+// Big GUI components
     1066+// ----------------------------------------------------------------------------
     1067+
     1068+// Set to 0 to disable MDI support.
     1069+//
     1070+// Requires wxUSE_NOTEBOOK under platforms other than MSW.
     1071+//
     1072+// Default is 1.
     1073+//
     1074+// Recommended setting: 1, can be safely set to 0.
     1075+#define wxUSE_MDI 1
     1076+
     1077+// Set to 0 to disable document/view architecture
     1078+#define wxUSE_DOC_VIEW_ARCHITECTURE 1
     1079+
     1080+// Set to 0 to disable MDI document/view architecture
     1081+//
     1082+// Requires wxUSE_MDI && wxUSE_DOC_VIEW_ARCHITECTURE
     1083+#define wxUSE_MDI_ARCHITECTURE    1
     1084+
     1085+// Set to 0 to disable print/preview architecture code
     1086+#define wxUSE_PRINTING_ARCHITECTURE  1
     1087+
     1088+// wxHTML sublibrary allows to display HTML in wxWindow programs and much,
     1089+// much more.
     1090+//
     1091+// Default is 1.
     1092+//
     1093+// Recommended setting: 1 (wxHTML is great!), set to 0 if you want compile a
     1094+// smaller library.
     1095+#define wxUSE_HTML          1
     1096+
     1097+// Setting wxUSE_GLCANVAS to 1 enables OpenGL support. You need to have OpenGL
     1098+// headers and libraries to be able to compile the library with wxUSE_GLCANVAS
     1099+// set to 1. Note that for some compilers (notably Microsoft Visual C++) you
     1100+// will need to manually add opengl32.lib and glu32.lib to the list of
     1101+// libraries linked with your program if you use OpenGL.
     1102+//
     1103+// Default is 0.
     1104+//
     1105+// Recommended setting: 1 if you intend to use OpenGL, 0 otherwise
     1106+#define wxUSE_GLCANVAS       1
     1107+
     1108+// wxRichTextCtrl allows editing of styled text.
     1109+//
     1110+// Default is 1.
     1111+//
     1112+// Recommended setting: 1, set to 0 if you want compile a
     1113+// smaller library.
     1114+#define wxUSE_RICHTEXT       1
     1115+
     1116+// ----------------------------------------------------------------------------
     1117+// Data transfer
     1118+// ----------------------------------------------------------------------------
     1119+
     1120+// Use wxClipboard class for clipboard copy/paste.
     1121+//
     1122+// Default is 1.
     1123+//
     1124+// Recommended setting: 1
     1125+#define wxUSE_CLIPBOARD     1
     1126+
     1127+// Use wxDataObject and related classes. Needed for clipboard and OLE drag and
     1128+// drop
     1129+//
     1130+// Default is 1.
     1131+//
     1132+// Recommended setting: 1
     1133+#define wxUSE_DATAOBJ       1
     1134+
     1135+// Use wxDropTarget and wxDropSource classes for drag and drop (this is
     1136+// different from "built in" drag and drop in wxTreeCtrl which is always
     1137+// available). Requires wxUSE_DATAOBJ.
     1138+//
     1139+// Default is 1.
     1140+//
     1141+// Recommended setting: 1
     1142+#define wxUSE_DRAG_AND_DROP 1
     1143+
     1144+// Use wxAccessible for enhanced and customisable accessibility.
     1145+// Depends on wxUSE_OLE.
     1146+//
     1147+// Default is 0.
     1148+//
     1149+// Recommended setting (at present): 0
     1150+#define wxUSE_ACCESSIBILITY 0
     1151+
     1152+// ----------------------------------------------------------------------------
     1153+// miscellaneous settings
     1154+// ----------------------------------------------------------------------------
     1155+
     1156+// wxSingleInstanceChecker class allows to verify at startup if another program
     1157+// instance is running.
     1158+//
     1159+// Default is 1
     1160+//
     1161+// Recommended setting: 1 (the class is tiny, disabling it won't save much
     1162+// space)
     1163+#define wxUSE_SNGLINST_CHECKER  1
     1164+
     1165+#define wxUSE_DRAGIMAGE 1
     1166+
     1167+#define wxUSE_IPC         1
     1168+                                // 0 for no interprocess comms
     1169+#define wxUSE_HELP        1
     1170+                                // 0 for no help facility
     1171+
     1172+// Should we use MS HTML help for wxHelpController? If disabled, neither
     1173+// wxCHMHelpController nor wxBestHelpController are available.
     1174+//
     1175+// Default is 1 under MSW, 0 is always used for the other platforms.
     1176+//
     1177+// Recommended setting: 1, only set to 0 if you have trouble compiling
     1178+// wxCHMHelpController (could be a problem with really ancient compilers)
     1179+#define wxUSE_MS_HTML_HELP 1
     1180+
     1181+
     1182+// Use wxHTML-based help controller?
     1183+#define wxUSE_WXHTML_HELP 1
     1184+
     1185+#define wxUSE_RESOURCES   0
     1186+                                // 0 for no wxGetResource/wxWriteResource
     1187+#define wxUSE_CONSTRAINTS 1
     1188+                                // 0 for no window layout constraint system
     1189+
     1190+#define wxUSE_SPLINES     1
     1191+                                // 0 for no splines
     1192+
     1193+#define wxUSE_MOUSEWHEEL        1
     1194+                                // Include mouse wheel support
     1195+
     1196+// ----------------------------------------------------------------------------
     1197+// postscript support settings
     1198+// ----------------------------------------------------------------------------
     1199+
     1200+// Set to 1 for PostScript device context.
     1201+#define wxUSE_POSTSCRIPT  1
     1202+
     1203+// Set to 1 to use font metric files in GetTextExtent
     1204+#define wxUSE_AFM_FOR_POSTSCRIPT 0
     1205+
     1206+// ----------------------------------------------------------------------------
     1207+// database classes
     1208+// ----------------------------------------------------------------------------
     1209+
     1210+// Define 1 to use ODBC classes
     1211+#define wxUSE_ODBC          0
     1212+
     1213+// For backward compatibility reasons, this parameter now only controls the
     1214+// default scrolling method used by cursors.  This default behavior can be
     1215+// overriden by setting the second param of wxDB::wxDbGetConnection() or
     1216+// wxDb() constructor to indicate whether the connection (and any wxDbTable()s
     1217+// that use the connection) should support forward only scrolling of cursors,
     1218+// or both forward and backward support for backward scrolling cursors is
     1219+// dependent on the data source as well as the ODBC driver being used.
     1220+#define wxODBC_FWD_ONLY_CURSORS         1
     1221+
     1222+// Default is 0.  Set to 1 to use the deprecated classes, enum types, function,
     1223+// member variables.  With a setting of 1, full backward compatibility with the
     1224+// 2.0.x release is possible. It is STRONGLY recommended that this be set to 0,
     1225+// as future development will be done only on the non-deprecated
     1226+// functions/classes/member variables/etc.
     1227+#define wxODBC_BACKWARD_COMPATABILITY 0
     1228+
     1229+// ----------------------------------------------------------------------------
     1230+// other compiler (mis)features
     1231+// ----------------------------------------------------------------------------
     1232+
     1233+// Set this to 0 if your compiler can't cope with omission of prototype
     1234+// parameters.
     1235+//
     1236+// Default is 1.
     1237+//
     1238+// Recommended setting: 1 (should never need to set this to 0)
     1239+#define REMOVE_UNUSED_ARG   1
     1240+
     1241+// VC++ 4.2 and above allows <iostream> and <iostream.h> but you can't mix
     1242+// them. Set to 1 for <iostream.h>, 0 for <iostream>. Note that VC++ 7.1
     1243+// and later doesn't support wxUSE_IOSTREAMH == 1 and so <iostream> will be
     1244+// used anyhow.
     1245+//
     1246+// Default is 1.
     1247+//
     1248+// Recommended setting: whatever your compiler likes more
     1249+#define wxUSE_IOSTREAMH     1
     1250+
     1251+// ----------------------------------------------------------------------------
     1252+// image format support
     1253+// ----------------------------------------------------------------------------
     1254+
     1255+// wxImage supports many different image formats which can be configured at
     1256+// compile-time. BMP is always supported, others are optional and can be safely
     1257+// disabled if you don't plan to use images in such format sometimes saving
     1258+// substantial amount of code in the final library.
     1259+//
     1260+// Some formats require an extra library which is included in wxWin sources
     1261+// which is mentioned if it is the case.
     1262+
     1263+// Set to 1 for wxImage support (recommended).
     1264+#define wxUSE_IMAGE         1
     1265+
     1266+// Set to 1 for PNG format support (requires libpng). Also requires wxUSE_ZLIB.
     1267+#define wxUSE_LIBPNG        1
     1268+
     1269+// Set to 1 for JPEG format support (requires libjpeg)
     1270+#define wxUSE_LIBJPEG       1
     1271+
     1272+// Set to 1 for TIFF format support (requires libtiff)
     1273+#define wxUSE_LIBTIFF       1
     1274+
     1275+// Set to 1 for TGA format support (loading only)
     1276+#define wxUSE_TGA           1
     1277+
     1278+// Set to 1 for GIF format support
     1279+#define wxUSE_GIF           1
     1280+
     1281+// Set to 1 for PNM format support
     1282+#define wxUSE_PNM           1
     1283+
     1284+// Set to 1 for PCX format support
     1285+#define wxUSE_PCX           1
     1286+
     1287+// Set to 1 for IFF format support (Amiga format)
     1288+#define wxUSE_IFF           0
     1289+
     1290+// Set to 1 for XPM format support
     1291+#define wxUSE_XPM           1
     1292+
     1293+// Set to 1 for MS Icons and Cursors format support
     1294+#define wxUSE_ICO_CUR       1
     1295+
     1296+// Set to 1 to compile in wxPalette class
     1297+#define wxUSE_PALETTE       1
     1298+
     1299+// ----------------------------------------------------------------------------
     1300+// wxUniversal-only options
     1301+// ----------------------------------------------------------------------------
     1302+
     1303+// Set to 1 to enable compilation of all themes, this is the default
     1304+#define wxUSE_ALL_THEMES    1
     1305+
     1306+// Set to 1 to enable the compilation of individual theme if wxUSE_ALL_THEMES
     1307+// is unset, if it is set these options are not used; notice that metal theme
     1308+// uses Win32 one
     1309+#define wxUSE_THEME_GTK     0
     1310+#define wxUSE_THEME_METAL   0
     1311+#define wxUSE_THEME_MONO    0
     1312+#define wxUSE_THEME_WIN32   0
     1313+
     1314+
     1315+/* --- end common options --- */
     1316+
     1317+// ----------------------------------------------------------------------------
     1318+// Windows-only settings
     1319+// ----------------------------------------------------------------------------
     1320+
     1321+// Set wxUSE_UNICODE_MSLU to 1 if you're compiling wxWidgets in Unicode mode
     1322+// and want to run your programs under Windows 9x and not only NT/2000/XP.
     1323+// This setting enables use of unicows.dll from MSLU (MS Layer for Unicode, see
     1324+// http://www.microsoft.com/globaldev/handson/dev/mslu_announce.mspx). Note
     1325+// that you will have to modify the makefiles to include unicows.lib import
     1326+// library as the first library (see installation instructions in install.txt
     1327+// to learn how to do it when building the library or samples).
     1328+//
     1329+// If your compiler doesn't have unicows.lib, you can get a version of it at
     1330+// http://libunicows.sourceforge.net
     1331+//
     1332+// Default is 0
     1333+//
     1334+// Recommended setting: 0 (1 if you want to deploy Unicode apps on 9x systems)
     1335+#ifndef wxUSE_UNICODE_MSLU
     1336+    #define wxUSE_UNICODE_MSLU 0
     1337+#endif
     1338+
     1339+// Set this to 1 if you want to use wxWidgets and MFC in the same program. This
     1340+// will override some other settings (see below)
     1341+//
     1342+// Default is 0.
     1343+//
     1344+// Recommended setting: 0 unless you really have to use MFC
     1345+#define wxUSE_MFC           0
     1346+
     1347+// Set this to 1 for generic OLE support: this is required for drag-and-drop,
     1348+// clipboard, OLE Automation. Only set it to 0 if your compiler is very old and
     1349+// can't compile/doesn't have the OLE headers.
     1350+//
     1351+// Default is 1.
     1352+//
     1353+// Recommended setting: 1
     1354+#define wxUSE_OLE           1
     1355+
     1356+// Set this to 1 to enable wxAutomationObject class.
     1357+//
     1358+// Default is 1.
     1359+//
     1360+// Recommended setting: 1 if you need to control other applications via OLE
     1361+// Automation, can be safely set to 0 otherwise
     1362+#define wxUSE_OLE_AUTOMATION 1
     1363+
     1364+// Set this to 1 to enable wxActiveXContainer class allowing to embed OLE
     1365+// controls in wx.
     1366+//
     1367+// Default is 1.
     1368+//
     1369+// Recommended setting: 1, required by wxMediaCtrl
     1370+#define wxUSE_ACTIVEX 1
     1371+
     1372+// wxDC cacheing implementation
     1373+#define wxUSE_DC_CACHEING 1
     1374+
     1375+// Set this to 1 to enable the use of DIB's for wxBitmap to support
     1376+// bitmaps > 16MB on Win95/98/Me.  Set to 0 to use DDB's only.
     1377+#define wxUSE_DIB_FOR_BITMAP 1
     1378+
     1379+// Set this to 1 to enable wxDIB class used internally for manipulating
     1380+// wxBitmao data.
     1381+//
     1382+// Default is 1, set it to 0 only if you don't use wxImage neither
     1383+//
     1384+// Recommended setting: 1 (without it conversion to/from wxImage won't work)
     1385+#define wxUSE_WXDIB 1
     1386+
     1387+// Set to 0 to disable PostScript print/preview architecture code under Windows
     1388+// (just use Windows printing).
     1389+#define wxUSE_POSTSCRIPT_ARCHITECTURE_IN_MSW 1
     1390+
     1391+// Set this to 1 to use RICHEDIT controls for wxTextCtrl with style wxTE_RICH
     1392+// which allows to put more than ~32Kb of text in it even under Win9x (NT
     1393+// doesn't have such limitation).
     1394+//
     1395+// Default is 1 for compilers which support it
     1396+//
     1397+// Recommended setting: 1, only set it to 0 if your compiler doesn't have
     1398+//                      or can't compile <richedit.h>
     1399+#define wxUSE_RICHEDIT  1
     1400+
     1401+// Set this to 1 to use extra features of richedit v2 and later controls
     1402+//
     1403+// Default is 1 for compilers which support it
     1404+//
     1405+// Recommended setting: 1
     1406+#define wxUSE_RICHEDIT2 1
     1407+
     1408+// Set this to 1 to enable support for the owner-drawn menu and listboxes. This
     1409+// is required by wxUSE_CHECKLISTBOX.
     1410+//
     1411+// Default is 1.
     1412+//
     1413+// Recommended setting: 1, set to 0 for a small library size reduction
     1414+#define wxUSE_OWNER_DRAWN 1
     1415+
     1416+// Set to 1 to compile MS Windows XP theme engine support
     1417+#define wxUSE_UXTHEME           1
     1418+
     1419+// Set to 1 to auto-adapt to MS Windows XP themes where possible
     1420+// (notably, wxNotebook pages)
     1421+#define wxUSE_UXTHEME_AUTO      1
     1422+
     1423+// Set to 1 to use InkEdit control (Tablet PC), if available
     1424+#define wxUSE_INKEDIT  0
     1425+
     1426+// ----------------------------------------------------------------------------
     1427+// Generic versions of native controls
     1428+// ----------------------------------------------------------------------------
     1429+
     1430+// Set this to 1 to be able to use wxDatePickerCtrlGeneric in addition to the
     1431+// native wxDatePickerCtrl
     1432+//
     1433+// Default is 0.
     1434+//
     1435+// Recommended setting: 0, this is mainly used for testing
     1436+#define wxUSE_DATEPICKCTRL_GENERIC 1
     1437+
     1438+// ----------------------------------------------------------------------------
     1439+// Crash debugging helpers
     1440+// ----------------------------------------------------------------------------
     1441+
     1442+// Set this to 1 to be able to use wxCrashReport::Generate() to create mini
     1443+// dumps of your program when it crashes (or at any other moment)
     1444+//
     1445+// Default is 1 if supported by the compiler (VC++ and recent BC++ only).
     1446+//
     1447+// Recommended setting: 1, set to 0 if your programs never crash
     1448+#define wxUSE_CRASHREPORT 1
     1449+
     1450+// ----------------------------------------------------------------------------
     1451+// obsolete settings
     1452+// ----------------------------------------------------------------------------
     1453+
     1454+// NB: all settings in this section are obsolete and should not be used/changed
     1455+//     at all, they will disappear
     1456+
     1457+// Define 1 to use bitmap messages.
     1458+#define wxUSE_BITMAP_MESSAGE         1
     1459+
     1460+#endif // _WX_SETUP_H_
     1461+
     1462diff '--exclude-from=wxPython-src-2.8.9.1/exclude' -Nur orig/wxPython-src-2.8.9.1//include/wx/msw/winundef.h wxPython-src-2.8.9.1//include/wx/msw/winundef.h
     1463--- orig/wxPython-src-2.8.9.1//include/wx/msw/winundef.h        2007-07-04 21:24:59.000000000 +0200
     1464+++ wxPython-src-2.8.9.1//include/wx/msw/winundef.h     2009-01-31 00:48:49.000000000 +0100
     1465@@ -30,24 +30,32 @@
     1466 #if defined(CreateDialog)
     1467     #undef CreateDialog
     1468
     1469+#ifdef _UNICODE
     1470     inline HWND CreateDialog(HINSTANCE hInstance,
     1471-                             LPCTSTR pTemplate,
     1472+                             LPCWSTR pTemplate,
     1473                              HWND hwndParent,
     1474                              DLGPROC pDlgProc)
     1475     {
     1476-        #ifdef _UNICODE
     1477             return CreateDialogW(hInstance, pTemplate, hwndParent, pDlgProc);
     1478-        #else
     1479+    }
     1480+#else
     1481+    inline HWND CreateDialog(HINSTANCE hInstance,
     1482+                             LPCSTR pTemplate,
     1483+                             HWND hwndParent,
     1484+                             DLGPROC pDlgProc)
     1485+    {
     1486             return CreateDialogA(hInstance, pTemplate, hwndParent, pDlgProc);
     1487-        #endif
     1488     }
     1489 #endif
     1490
     1491+#endif
     1492+
     1493 // CreateFont
     1494
     1495 #ifdef CreateFont
     1496     #undef CreateFont
     1497
     1498+#ifdef _UNICODE
     1499     inline HFONT CreateFont(int height,
     1500                             int width,
     1501                             int escapement,
     1502@@ -61,20 +69,35 @@
     1503                             DWORD clipprecision,
     1504                             DWORD quality,
     1505                             DWORD family,
     1506-                            LPCTSTR facename)
     1507+                            LPCWSTR facename)
     1508     {
     1509-        #ifdef _UNICODE
     1510             return CreateFontW(height, width, escapement, orientation,
     1511                                weight, italic, underline, strikeout, charset,
     1512                                outprecision, clipprecision, quality,
     1513                                family, facename);
     1514-        #else
     1515+    }
     1516+#else
     1517+    inline HFONT CreateFont(int height,
     1518+                            int width,
     1519+                            int escapement,
     1520+                            int orientation,
     1521+                            int weight,
     1522+                            DWORD italic,
     1523+                            DWORD underline,
     1524+                            DWORD strikeout,
     1525+                            DWORD charset,
     1526+                            DWORD outprecision,
     1527+                            DWORD clipprecision,
     1528+                            DWORD quality,
     1529+                            DWORD family,
     1530+                            LPCSTR facename)
     1531+    {
     1532             return CreateFontA(height, width, escapement, orientation,
     1533                                weight, italic, underline, strikeout, charset,
     1534                                outprecision, clipprecision, quality,
     1535                                family, facename);
     1536-        #endif
     1537     }
     1538+#endif
     1539 #endif // CreateFont
     1540
     1541 // CreateWindow
     1542@@ -82,8 +105,9 @@
     1543 #if defined(CreateWindow)
     1544     #undef CreateWindow
     1545
     1546-    inline HWND CreateWindow(LPCTSTR lpClassName,
     1547-                             LPCTSTR lpWndClass,
     1548+#ifdef _UNICODE
     1549+    inline HWND CreateWindow(LPCWSTR lpClassName,
     1550+                             LPCWSTR lpWndClass,
     1551                              DWORD dwStyle,
     1552                              int x, int y, int w, int h,
     1553                              HWND hWndParent,
     1554@@ -91,30 +115,42 @@
     1555                              HINSTANCE hInstance,
     1556                              LPVOID lpParam)
     1557     {
     1558-        #ifdef _UNICODE
     1559             return CreateWindowW(lpClassName, lpWndClass, dwStyle, x, y, w, h,
     1560                                  hWndParent, hMenu, hInstance, lpParam);
     1561-        #else
     1562+    }
     1563+#else
     1564+    inline HWND CreateWindow(LPCSTR lpClassName,
     1565+                             LPCSTR lpWndClass,
     1566+                             DWORD dwStyle,
     1567+                             int x, int y, int w, int h,
     1568+                             HWND hWndParent,
     1569+                             HMENU hMenu,
     1570+                             HINSTANCE hInstance,
     1571+                             LPVOID lpParam)
     1572+    {
     1573             return CreateWindowA(lpClassName, lpWndClass, dwStyle, x, y, w, h,
     1574                                  hWndParent, hMenu, hInstance, lpParam);
     1575-        #endif
     1576     }
     1577 #endif
     1578+#endif
     1579
     1580 // LoadMenu
     1581
     1582 #ifdef LoadMenu
     1583     #undef LoadMenu
     1584
     1585-    inline HMENU LoadMenu(HINSTANCE instance, LPCTSTR name)
     1586+#ifdef _UNICODE
     1587+    inline HMENU LoadMenu(HINSTANCE instance, LPCWSTR name)
     1588     {
     1589-        #ifdef _UNICODE
     1590             return LoadMenuW(instance, name);
     1591-        #else
     1592+    }
     1593+#else
     1594+    inline HMENU LoadMenu(HINSTANCE instance, LPCSTR name)
     1595+    {
     1596             return LoadMenuA(instance, name);
     1597-        #endif
     1598     }
     1599 #endif
     1600+#endif
     1601
     1602 // FindText
     1603
     1604@@ -312,27 +348,33 @@
     1605 // LoadIcon
     1606 #ifdef LoadIcon
     1607     #undef LoadIcon
     1608-    inline HICON LoadIcon(HINSTANCE hInstance, LPCTSTR lpIconName)
     1609+#ifdef _UNICODE
     1610+    inline HICON LoadIcon(HINSTANCE hInstance, LPCWSTR lpIconName)
     1611     {
     1612-        #ifdef _UNICODE
     1613             return LoadIconW(hInstance, lpIconName);
     1614-        #else // ANSI
     1615+    }
     1616+#else // ANSI
     1617+    inline HICON LoadIcon(HINSTANCE hInstance, LPCSTR lpIconName)
     1618+    {
     1619             return LoadIconA(hInstance, lpIconName);
     1620-        #endif // Unicode/ANSI
     1621     }
     1622+#endif // Unicode/ANSI
     1623 #endif // LoadIcon
     1624
     1625 // LoadBitmap
     1626 #ifdef LoadBitmap
     1627     #undef LoadBitmap
     1628-    inline HBITMAP LoadBitmap(HINSTANCE hInstance, LPCTSTR lpBitmapName)
     1629+#ifdef _UNICODE
     1630+    inline HBITMAP LoadBitmap(HINSTANCE hInstance, LPCWSTR lpBitmapName)
     1631     {
     1632-        #ifdef _UNICODE
     1633             return LoadBitmapW(hInstance, lpBitmapName);
     1634-        #else // ANSI
     1635+    }
     1636+#else
     1637+    inline HBITMAP LoadBitmap(HINSTANCE hInstance, LPCSTR lpBitmapName)
     1638+    {
     1639             return LoadBitmapA(hInstance, lpBitmapName);
     1640-        #endif // Unicode/ANSI
     1641     }
     1642+#endif // Unicode/ANSI
     1643 #endif // LoadBitmap
     1644
     1645 // LoadLibrary
     1646@@ -477,6 +519,35 @@
     1647     }
     1648 #endif
     1649
     1650+#ifdef GetModuleFileName
     1651+   #undef GetModuleFileName
     1652+#ifdef _UNICODE
     1653+    inline DWORD GetModuleFileName(HMODULE hModule, LPWCH lpFilename, DWORD nSize)
     1654+    {
     1655+       return GetModuleFileNameW(hModule, lpFilename, nSize);
     1656+    }
     1657+#else
     1658+    inline DWORD GetModuleFileName(HMODULE hModule, LPCH lpFilename, DWORD nSize)
     1659+    {
     1660+       return GetModuleFileNameA(hModule, lpFilename, nSize);
     1661+    }
     1662+#endif
     1663+#endif
     1664+
     1665+#ifdef UnregisterClass
     1666+   #undef UnregisterClass
     1667+#ifdef _UNICODE
     1668+    inline BOOL UnregisterClass(LPCWSTR lpClassName, HINSTANCE hInstance)
     1669+    {
     1670+       return UnregisterClassW(lpClassName, hInstance);
     1671+    }
     1672+#else
     1673+    inline DWORD GetModuleFileName(LPCSTR lpClassName, HINSTANCE hInstance)
     1674+    {
     1675+       return UnregisterClassA(lpClassName, hInstance);
     1676+    }
     1677+#endif
     1678+#endif
     1679
     1680 // GetWindowProc
     1681 //ifdef GetWindowProc
     1682diff '--exclude-from=wxPython-src-2.8.9.1/exclude' -Nur orig/wxPython-src-2.8.9.1//lib/vc_dll/msw/wx/setup.h wxPython-src-2.8.9.1//lib/vc_dll/msw/wx/setup.h
     1683--- orig/wxPython-src-2.8.9.1//lib/vc_dll/msw/wx/setup.h        1970-01-01 01:00:00.000000000 +0100
     1684+++ wxPython-src-2.8.9.1//lib/vc_dll/msw/wx/setup.h     2009-01-30 23:58:57.000000000 +0100
     1685@@ -0,0 +1,1349 @@
     1686+/////////////////////////////////////////////////////////////////////////////
     1687+// Name:        wx/msw/setup.h
     1688+// Purpose:     Configuration for the library
     1689+// Author:      Julian Smart
     1690+// Modified by:
     1691+// Created:     01/02/97
     1692+// RCS-ID:      $Id: setup0.h 51451 2008-01-29 23:11:55Z VZ $
     1693+// Copyright:   (c) Julian Smart
     1694+// Licence:     wxWindows licence
     1695+/////////////////////////////////////////////////////////////////////////////
     1696+
     1697+#ifndef _WX_SETUP_H_
     1698+#define _WX_SETUP_H_
     1699+
     1700+/* --- start common options --- */
     1701+// ----------------------------------------------------------------------------
     1702+// global settings
     1703+// ----------------------------------------------------------------------------
     1704+
     1705+// define this to 0 when building wxBase library - this can also be done from
     1706+// makefile/project file overriding the value here
     1707+#ifndef wxUSE_GUI
     1708+    #define wxUSE_GUI            1
     1709+#endif // wxUSE_GUI
     1710+
     1711+// ----------------------------------------------------------------------------
     1712+// compatibility settings
     1713+// ----------------------------------------------------------------------------
     1714+
     1715+// This setting determines the compatibility with 2.4 API: set it to 1 to
     1716+// enable it but please consider updating your code instead.
     1717+//
     1718+// Default is 0
     1719+//
     1720+// Recommended setting: 0 (please update your code)
     1721+#define WXWIN_COMPATIBILITY_2_4 0
     1722+
     1723+// This setting determines the compatibility with 2.6 API: set it to 0 to
     1724+// flag all cases of using deprecated functions.
     1725+//
     1726+// Default is 1 but please try building your code with 0 as the default will
     1727+// change to 0 in the next version and the deprecated functions will disappear
     1728+// in the version after it completely.
     1729+//
     1730+// Recommended setting: 0 (please update your code)
     1731+#define WXWIN_COMPATIBILITY_2_6 1
     1732+
     1733+// MSW-only: Set to 0 for accurate dialog units, else 1 for old behaviour when
     1734+// default system font is used for wxWindow::GetCharWidth/Height() instead of
     1735+// the current font.
     1736+//
     1737+// Default is 0
     1738+//
     1739+// Recommended setting: 0
     1740+#define wxDIALOG_UNIT_COMPATIBILITY   0
     1741+
     1742+// ----------------------------------------------------------------------------
     1743+// debugging settings
     1744+// ----------------------------------------------------------------------------
     1745+
     1746+// Generic comment about debugging settings: they are very useful if you don't
     1747+// use any other memory leak detection tools such as Purify/BoundsChecker, but
     1748+// are probably redundant otherwise. Also, Visual C++ CRT has the same features
     1749+// as wxWidgets memory debugging subsystem built in since version 5.0 and you
     1750+// may prefer to use it instead of built in memory debugging code because it is
     1751+// faster and more fool proof.
     1752+//
     1753+// Using VC++ CRT memory debugging is enabled by default in debug mode
     1754+// (__WXDEBUG__) if wxUSE_GLOBAL_MEMORY_OPERATORS is *not* enabled (i.e. is 0)
     1755+// and if __NO_VC_CRTDBG__ is not defined.
     1756+
     1757+// If 1, enables wxDebugContext, for writing error messages to file, etc. If
     1758+// __WXDEBUG__ is not defined, will still use the normal memory operators.
     1759+//
     1760+// Default is 0
     1761+//
     1762+// Recommended setting: 0
     1763+#define wxUSE_DEBUG_CONTEXT 0
     1764+
     1765+// If 1, enables debugging versions of wxObject::new and wxObject::delete *IF*
     1766+// __WXDEBUG__ is also defined.
     1767+//
     1768+// WARNING: this code may not work with all architectures, especially if
     1769+// alignment is an issue. This switch is currently ignored for mingw / cygwin
     1770+//
     1771+// Default is 0
     1772+//
     1773+// Recommended setting: 1 if you are not using a memory debugging tool, else 0
     1774+#define wxUSE_MEMORY_TRACING 0
     1775+
     1776+// In debug mode, cause new and delete to be redefined globally.
     1777+// If this causes problems (e.g. link errors which is a common problem
     1778+// especially if you use another library which also redefines the global new
     1779+// and delete), set this to 0.
     1780+// This switch is currently ignored for mingw / cygwin
     1781+//
     1782+// Default is 0
     1783+//
     1784+// Recommended setting: 0
     1785+#define wxUSE_GLOBAL_MEMORY_OPERATORS 0
     1786+
     1787+// In debug mode, causes new to be defined to be WXDEBUG_NEW (see object.h). If
     1788+// this causes problems (e.g. link errors), set this to 0. You may need to set
     1789+// this to 0 if using templates (at least for VC++). This switch is currently
     1790+// ignored for mingw / cygwin / CodeWarrior
     1791+//
     1792+// Default is 0
     1793+//
     1794+// Recommended setting: 0
     1795+#define wxUSE_DEBUG_NEW_ALWAYS 0
     1796+
     1797+// wxHandleFatalExceptions() may be used to catch the program faults at run
     1798+// time and, instead of terminating the program with a usual GPF message box,
     1799+// call the user-defined wxApp::OnFatalException() function. If you set
     1800+// wxUSE_ON_FATAL_EXCEPTION to 0, wxHandleFatalExceptions() will not work.
     1801+//
     1802+// This setting is for Win32 only and can only be enabled if your compiler
     1803+// supports Win32 structured exception handling (currently only VC++ does)
     1804+//
     1805+// Default is 1
     1806+//
     1807+// Recommended setting: 1 if your compiler supports it.
     1808+#define wxUSE_ON_FATAL_EXCEPTION 1
     1809+
     1810+// Set this to 1 to be able to generate a human-readable (unlike
     1811+// machine-readable minidump created by wxCrashReport::Generate()) stack back
     1812+// trace when your program crashes using wxStackWalker
     1813+//
     1814+// Default is 1 if supported by the compiler.
     1815+//
     1816+// Recommended setting: 1, set to 0 if your programs never crash
     1817+#define wxUSE_STACKWALKER 1
     1818+
     1819+// Set this to 1 to compile in wxDebugReport class which allows you to create
     1820+// and optionally upload to your web site a debug report consisting of back
     1821+// trace of the crash (if wxUSE_STACKWALKER == 1) and other information.
     1822+//
     1823+// Default is 1 if supported by the compiler.
     1824+//
     1825+// Recommended setting: 1, it is compiled into a separate library so there
     1826+//                         is no overhead if you don't use it
     1827+#define wxUSE_DEBUGREPORT 0
     1828+
     1829+// ----------------------------------------------------------------------------
     1830+// Unicode support
     1831+// ----------------------------------------------------------------------------
     1832+
     1833+// Set wxUSE_UNICODE to 1 to compile wxWidgets in Unicode mode: wxChar will be
     1834+// defined as wchar_t, wxString will use Unicode internally. If you set this
     1835+// to 1, you must use wxT() macro for all literal strings in the program.
     1836+//
     1837+// Unicode is currently only fully supported under Windows NT/2000/XP
     1838+// (Windows 9x doesn't support it and the programs compiled in Unicode mode
     1839+// will not run under 9x -- but see wxUSE_UNICODE_MSLU below).
     1840+//
     1841+// Default is 0
     1842+//
     1843+// Recommended setting: 0 (unless you only plan to use Windows NT/2000/XP)
     1844+#ifndef wxUSE_UNICODE
     1845+    #define wxUSE_UNICODE 0
     1846+#endif
     1847+
     1848+// Setting wxUSE_WCHAR_T to 1 gives you some degree of Unicode support without
     1849+// compiling the program in Unicode mode. More precisely, it will be possible
     1850+// to construct wxString from a wide (Unicode) string and convert any wxString
     1851+// to Unicode.
     1852+//
     1853+// Default is 1
     1854+//
     1855+// Recommended setting: 1
     1856+#define wxUSE_WCHAR_T 1
     1857+
     1858+// ----------------------------------------------------------------------------
     1859+// global features
     1860+// ----------------------------------------------------------------------------
     1861+
     1862+// Compile library in exception-safe mode? If set to 1, the library will try to
     1863+// behave correctly in presence of exceptions (even though it still will not
     1864+// use the exceptions itself) and notify the user code about any unhandled
     1865+// exceptions. If set to 0, propagation of the exceptions through the library
     1866+// code will lead to undefined behaviour -- but the code itself will be
     1867+// slightly smaller and faster.
     1868+//
     1869+// Note that like wxUSE_THREADS this option is automatically set to 0 if
     1870+// wxNO_EXCEPTIONS is defined.
     1871+//
     1872+// Default is 1
     1873+//
     1874+// Recommended setting: depends on whether you intend to use C++ exceptions
     1875+//                      in your own code (1 if you do, 0 if you don't)
     1876+#define wxUSE_EXCEPTIONS    0
     1877+
     1878+// Set wxUSE_EXTENDED_RTTI to 1 to use extended RTTI
     1879+//
     1880+// Default is 0
     1881+//
     1882+// Recommended setting: 0 (this is still work in progress...)
     1883+#define wxUSE_EXTENDED_RTTI 0
     1884+
     1885+// Set wxUSE_STL to 1 to derive wxList(Foo) and wxArray(Foo) from
     1886+// std::list<Foo*> and std::vector<Foo*>, with a compatibility interface,
     1887+// and for wxHashMap to be implemented with templates.
     1888+//
     1889+// Default is 0
     1890+//
     1891+// Recommended setting: YMMV
     1892+#define wxUSE_STL 0
     1893+
     1894+// Support for message/error logging. This includes wxLogXXX() functions and
     1895+// wxLog and derived classes. Don't set this to 0 unless you really know what
     1896+// you are doing.
     1897+//
     1898+// Default is 1
     1899+//
     1900+// Recommended setting: 1 (always)
     1901+#define wxUSE_LOG 1
     1902+
     1903+// Recommended setting: 1
     1904+#define wxUSE_LOGWINDOW 1
     1905+
     1906+// Recommended setting: 1
     1907+#define wxUSE_LOGGUI 1
     1908+
     1909+// Recommended setting: 1
     1910+#define wxUSE_LOG_DIALOG 1
     1911+
     1912+// Support for command line parsing using wxCmdLineParser class.
     1913+//
     1914+// Default is 1
     1915+//
     1916+// Recommended setting: 1 (can be set to 0 if you don't use the cmd line)
     1917+#define wxUSE_CMDLINE_PARSER 1
     1918+
     1919+// Support for multithreaded applications: if 1, compile in thread classes
     1920+// (thread.h) and make the library a bit more thread safe. Although thread
     1921+// support is quite stable by now, you may still consider recompiling the
     1922+// library without it if you have no use for it - this will result in a
     1923+// somewhat smaller and faster operation.
     1924+//
     1925+// Notice that if wxNO_THREADS is defined, wxUSE_THREADS is automatically reset
     1926+// to 0 in wx/chkconf.h, so, for example, if you set USE_THREADS to 0 in
     1927+// build/msw/config.* file this value will have no effect.
     1928+//
     1929+// Default is 1
     1930+//
     1931+// Recommended setting: 0 unless you do plan to develop MT applications
     1932+#define wxUSE_THREADS 1
     1933+
     1934+// If enabled, compiles wxWidgets streams classes
     1935+//
     1936+// wx stream classes are used for image IO, process IO redirection, network
     1937+// protocols implementation and much more and so disabling this results in a
     1938+// lot of other functionality being lost.
     1939+//
     1940+// Default is 1
     1941+//
     1942+// Recommended setting: 1 as setting it to 0 disables many other things
     1943+#define wxUSE_STREAMS       1
     1944+
     1945+// Use standard C++ streams if 1 instead of wx streams in some places. If
     1946+// disabled (default), wx streams are used everywhere and wxWidgets doesn't
     1947+// depend on the standard streams library.
     1948+//
     1949+// Notice that enabling this does not replace wx streams with std streams
     1950+// everywhere, in a lot of places wx streams are used no matter what.
     1951+//
     1952+// Default is 0
     1953+//
     1954+// Recommended setting: 1 if you use the standard streams anyhow and so
     1955+//                      dependency on the standard streams library is not a
     1956+//                      problem
     1957+#define wxUSE_STD_IOSTREAM  0
     1958+
     1959+// Enable conversion to standard C++ string if 1.
     1960+//
     1961+// Default is 1 for most compilers.
     1962+//
     1963+// Currently the Digital Mars and Watcom compilers come without standard C++
     1964+// library headers by default, wxUSE_STD_STRING can be set to 1 if you do have
     1965+// them (e.g. from STLPort).
     1966+//
     1967+// VC++ 5.0 does include standard C++ library header, however they produce
     1968+// many warnings that can't be turned off when compiled at warning level 4.
     1969+#if defined(__DMC__) || defined(__WATCOMC__) \
     1970+        || (defined(_MSC_VER) && _MSC_VER < 1200)
     1971+    #define wxUSE_STD_STRING  0
     1972+#else
     1973+    #define wxUSE_STD_STRING  1
     1974+#endif
     1975+
     1976+// Support for positional parameters (e.g. %1$d, %2$s ...) in wxVsnprintf.
     1977+// Note that if the system's implementation does not support positional
     1978+// parameters, setting this to 1 forces the use of the wxWidgets implementation
     1979+// of wxVsnprintf. The standard vsnprintf() supports positional parameters on
     1980+// many Unix systems but usually doesn't under Windows.
     1981+//
     1982+// Positional parameters are very useful when translating a program since using
     1983+// them in formatting strings allow translators to correctly reorder the
     1984+// translated sentences.
     1985+//
     1986+// Default is 1
     1987+//
     1988+// Recommended setting: 1 if you want to support multiple languages
     1989+#define wxUSE_PRINTF_POS_PARAMS      1
     1990+
     1991+// ----------------------------------------------------------------------------
     1992+// non GUI features selection
     1993+// ----------------------------------------------------------------------------
     1994+
     1995+// Set wxUSE_LONGLONG to 1 to compile the wxLongLong class. This is a 64 bit
     1996+// integer which is implemented in terms of native 64 bit integers if any or
     1997+// uses emulation otherwise.
     1998+//
     1999+// This class is required by wxDateTime and so you should enable it if you want
     2000+// to use wxDateTime. For most modern platforms, it will use the native 64 bit
     2001+// integers in which case (almost) all of its functions are inline and it
     2002+// almost does not take any space, so there should be no reason to switch it
     2003+// off.
     2004+//
     2005+// Recommended setting: 1
     2006+#define wxUSE_LONGLONG      1
     2007+
     2008+// Set wxUSE_(F)FILE to 1 to compile wx(F)File classes. wxFile uses low level
     2009+// POSIX functions for file access, wxFFile uses ANSI C stdio.h functions.
     2010+//
     2011+// Default is 1
     2012+//
     2013+// Recommended setting: 1 (wxFile is highly recommended as it is required by
     2014+// i18n code, wxFileConfig and others)
     2015+#define wxUSE_FILE          1
     2016+#define wxUSE_FFILE         1
     2017+
     2018+// Use wxFSVolume class providing access to the configured/active mount points
     2019+//
     2020+// Default is 1
     2021+//
     2022+// Recommended setting: 1 (but may be safely disabled if you don't use it)
     2023+#define wxUSE_FSVOLUME      1
     2024+
     2025+// Use wxStandardPaths class which allows to retrieve some standard locations
     2026+// in the file system
     2027+//
     2028+// Default is 1
     2029+//
     2030+// Recommended setting: 1 (may be disabled to save space, but not much)
     2031+#define wxUSE_STDPATHS      1
     2032+
     2033+// use wxTextBuffer class: required by wxTextFile
     2034+#define wxUSE_TEXTBUFFER    1
     2035+
     2036+// use wxTextFile class: requires wxFile and wxTextBuffer, required by
     2037+// wxFileConfig
     2038+#define wxUSE_TEXTFILE      1
     2039+
     2040+// i18n support: _() macro, wxLocale class. Requires wxTextFile.
     2041+#define wxUSE_INTL          1
     2042+
     2043+// Set wxUSE_DATETIME to 1 to compile the wxDateTime and related classes which
     2044+// allow to manipulate dates, times and time intervals. wxDateTime replaces the
     2045+// old wxTime and wxDate classes which are still provided for backwards
     2046+// compatibility (and implemented in terms of wxDateTime).
     2047+//
     2048+// Note that this class is relatively new and is still officially in alpha
     2049+// stage because some features are not yet (fully) implemented. It is already
     2050+// quite useful though and should only be disabled if you are aiming at
     2051+// absolutely minimal version of the library.
     2052+//
     2053+// Requires: wxUSE_LONGLONG
     2054+//
     2055+// Default is 1
     2056+//
     2057+// Recommended setting: 1
     2058+#define wxUSE_DATETIME      1
     2059+
     2060+// Set wxUSE_TIMER to 1 to compile wxTimer class
     2061+//
     2062+// Default is 1
     2063+//
     2064+// Recommended setting: 1
     2065+#define wxUSE_TIMER         1
     2066+
     2067+// Use wxStopWatch clas.
     2068+//
     2069+// Default is 1
     2070+//
     2071+// Recommended setting: 1 (needed by wxSocket)
     2072+#define wxUSE_STOPWATCH     1
     2073+
     2074+// Setting wxUSE_CONFIG to 1 enables the use of wxConfig and related classes
     2075+// which allow the application to store its settings in the persistent
     2076+// storage. Setting this to 1 will also enable on-demand creation of the
     2077+// global config object in wxApp.
     2078+//
     2079+// See also wxUSE_CONFIG_NATIVE below.
     2080+//
     2081+// Recommended setting: 1
     2082+#define wxUSE_CONFIG        1
     2083+
     2084+// If wxUSE_CONFIG is 1, you may choose to use either the native config
     2085+// classes under Windows (using .INI files under Win16 and the registry under
     2086+// Win32) or the portable text file format used by the config classes under
     2087+// Unix.
     2088+//
     2089+// Default is 1 to use native classes. Note that you may still use
     2090+// wxFileConfig even if you set this to 1 - just the config object created by
     2091+// default for the applications needs will be a wxRegConfig or wxIniConfig and
     2092+// not wxFileConfig.
     2093+//
     2094+// Recommended setting: 1
     2095+#define wxUSE_CONFIG_NATIVE   1
     2096+
     2097+// If wxUSE_DIALUP_MANAGER is 1, compile in wxDialUpManager class which allows
     2098+// to connect/disconnect from the network and be notified whenever the dial-up
     2099+// network connection is established/terminated. Requires wxUSE_DYNAMIC_LOADER.
     2100+//
     2101+// Default is 1.
     2102+//
     2103+// Recommended setting: 1
     2104+#define wxUSE_DIALUP_MANAGER   0
     2105+
     2106+// Compile in classes for run-time DLL loading and function calling.
     2107+// Required by wxUSE_DIALUP_MANAGER.
     2108+//
     2109+// This setting is for Win32 only
     2110+//
     2111+// Default is 1.
     2112+//
     2113+// Recommended setting: 1
     2114+#define wxUSE_DYNLIB_CLASS    1
     2115+
     2116+// experimental, don't use for now
     2117+#define wxUSE_DYNAMIC_LOADER  1
     2118+
     2119+// Set to 1 to use socket classes
     2120+#define wxUSE_SOCKETS       1
     2121+
     2122+// Set to 1 to enable virtual file systems (required by wxHTML)
     2123+#define wxUSE_FILESYSTEM    1
     2124+
     2125+// Set to 1 to enable virtual ZIP filesystem (requires wxUSE_FILESYSTEM)
     2126+#define wxUSE_FS_ZIP        1
     2127+
     2128+// Set to 1 to enable virtual archive filesystem (requires wxUSE_FILESYSTEM)
     2129+#define wxUSE_FS_ARCHIVE    1
     2130+
     2131+// Set to 1 to enable virtual Internet filesystem (requires wxUSE_FILESYSTEM)
     2132+#define wxUSE_FS_INET       1
     2133+
     2134+// wxArchive classes for accessing archives such as zip and tar
     2135+#define wxUSE_ARCHIVE_STREAMS     1
     2136+
     2137+// Set to 1 to compile wxZipInput/OutputStream classes.
     2138+#define wxUSE_ZIPSTREAM     1
     2139+
     2140+// Set to 1 to compile wxTarInput/OutputStream classes.
     2141+#define wxUSE_TARSTREAM     1
     2142+
     2143+// Set to 1 to compile wxZlibInput/OutputStream classes. Also required by
     2144+// wxUSE_LIBPNG
     2145+#define wxUSE_ZLIB          1
     2146+
     2147+// If enabled, the code written by Apple will be used to write, in a portable
     2148+// way, float on the disk. See extended.c for the license which is different
     2149+// from wxWidgets one.
     2150+//
     2151+// Default is 1.
     2152+//
     2153+// Recommended setting: 1 unless you don't like the license terms (unlikely)
     2154+#define wxUSE_APPLE_IEEE          1
     2155+
     2156+// Joystick support class
     2157+#define wxUSE_JOYSTICK            1
     2158+
     2159+// wxFontMapper class
     2160+#define wxUSE_FONTMAP 1
     2161+
     2162+// wxMimeTypesManager class
     2163+#define wxUSE_MIMETYPE 1
     2164+
     2165+// wxProtocol and related classes: if you want to use either of wxFTP, wxHTTP
     2166+// or wxURL you need to set this to 1.
     2167+//
     2168+// Default is 1.
     2169+//
     2170+// Recommended setting: 1
     2171+#define wxUSE_PROTOCOL 1
     2172+
     2173+// The settings for the individual URL schemes
     2174+#define wxUSE_PROTOCOL_FILE 1
     2175+#define wxUSE_PROTOCOL_FTP 1
     2176+#define wxUSE_PROTOCOL_HTTP 1
     2177+
     2178+// Define this to use wxURL class.
     2179+#define wxUSE_URL 1
     2180+
     2181+// Define this to use native platform url and protocol support.
     2182+// Currently valid only for MS-Windows.
     2183+// Note: if you set this to 1, you can open ftp/http/gopher sites
     2184+// and obtain a valid input stream for these sites
     2185+// even when you set wxUSE_PROTOCOL_FTP/HTTP to 0.
     2186+// Doing so reduces the code size.
     2187+//
     2188+// This code is experimental and subject to change.
     2189+#define wxUSE_URL_NATIVE 0
     2190+
     2191+// Support for wxVariant class used in several places throughout the library,
     2192+// notably in wxDataViewCtrl API.
     2193+//
     2194+// Default is 1.
     2195+//
     2196+// Recommended setting: 1 unless you want to reduce the library size as much as
     2197+// possible in which case setting this to 0 can gain up to 100KB.
     2198+#define wxUSE_VARIANT 1
     2199+
     2200+// Support for regular expression matching via wxRegEx class: enable this to
     2201+// use POSIX regular expressions in your code. You need to compile regex
     2202+// library from src/regex to use it under Windows.
     2203+//
     2204+// Default is 0
     2205+//
     2206+// Recommended setting: 1 if your compiler supports it, if it doesn't please
     2207+// contribute us a makefile for src/regex for it
     2208+#define wxUSE_REGEX       1
     2209+
     2210+// wxSystemOptions class
     2211+#define wxUSE_SYSTEM_OPTIONS 1
     2212+
     2213+// wxSound class
     2214+#define wxUSE_SOUND      1
     2215+
     2216+// Use wxMediaCtrl
     2217+//
     2218+// Default is 1.
     2219+//
     2220+// Recommended setting: 1
     2221+#define wxUSE_MEDIACTRL     1
     2222+
     2223+// Use GStreamer for Unix (req a lot of dependancies)
     2224+//
     2225+// Default is 0
     2226+//
     2227+// Recommended setting: 1 (wxMediaCtrl won't work by default without it)
     2228+#define wxUSE_GSTREAMER    0
     2229+
     2230+// Use wxWidget's XRC XML-based resource system.  Recommended.
     2231+//
     2232+// Default is 1
     2233+//
     2234+// Recommended setting: 1 (requires wxUSE_XML)
     2235+#define wxUSE_XRC       1
     2236+
     2237+// XML parsing classes. Note that their API will change in the future, so
     2238+// using wxXmlDocument and wxXmlNode in your app is not recommended.
     2239+//
     2240+// Default is the same as wxUSE_XRC, i.e. 1 by default.
     2241+//
     2242+// Recommended setting: 1 (required by XRC)
     2243+#define wxUSE_XML       wxUSE_XRC
     2244+
     2245+// Use wxWidget's AUI docking system
     2246+//
     2247+// Default is 1
     2248+//
     2249+// Recommended setting: 1
     2250+#define wxUSE_AUI       1
     2251+
     2252+
     2253+// Enable the new wxGraphicsPath and wxGraphicsContext classes for an advanced
     2254+// 2D drawing API.  (Still somewhat experimental)
     2255+//
     2256+// Please note that on Windows you will need to link with gdiplus.lib (use
     2257+// USE_GDIPLUS=1 for makefile builds) and distribute gdiplus.dll with your
     2258+// application if you want it to be runnable on pre-XP systems.
     2259+//
     2260+// Default is 0
     2261+//
     2262+// Recommended setting: 1
     2263+#ifndef wxUSE_GRAPHICS_CONTEXT
     2264+#define wxUSE_GRAPHICS_CONTEXT 1
     2265+#endif
     2266+
     2267+// ----------------------------------------------------------------------------
     2268+// Individual GUI controls
     2269+// ----------------------------------------------------------------------------
     2270+
     2271+// You must set wxUSE_CONTROLS to 1 if you are using any controls at all
     2272+// (without it, wxControl class is not compiled)
     2273+//
     2274+// Default is 1
     2275+//
     2276+// Recommended setting: 1 (don't change except for very special programs)
     2277+#define wxUSE_CONTROLS     1
     2278+
     2279+// wxPopupWindow class is a top level transient window. It is currently used
     2280+// to implement wxTipWindow
     2281+//
     2282+// Default is 1
     2283+//
     2284+// Recommended setting: 1 (may be set to 0 if you don't wxUSE_TIPWINDOW)
     2285+#define wxUSE_POPUPWIN     1
     2286+
     2287+// wxTipWindow allows to implement the custom tooltips, it is used by the
     2288+// context help classes. Requires wxUSE_POPUPWIN.
     2289+//
     2290+// Default is 1
     2291+//
     2292+// Recommended setting: 1 (may be set to 0)
     2293+#define wxUSE_TIPWINDOW    1
     2294+
     2295+// Each of the settings below corresponds to one wxWidgets control. They are
     2296+// all switched on by default but may be disabled if you are sure that your
     2297+// program (including any standard dialogs it can show!) doesn't need them and
     2298+// if you desperately want to save some space. If you use any of these you must
     2299+// set wxUSE_CONTROLS as well.
     2300+//
     2301+// Default is 1
     2302+//
     2303+// Recommended setting: 1
     2304+#define wxUSE_ANIMATIONCTRL 1   // wxAnimationCtrl
     2305+#define wxUSE_BUTTON        1   // wxButton
     2306+#define wxUSE_BMPBUTTON     1   // wxBitmapButton
     2307+#define wxUSE_CALENDARCTRL  1   // wxCalendarCtrl
     2308+#define wxUSE_CHECKBOX      1   // wxCheckBox
     2309+#define wxUSE_CHECKLISTBOX  1   // wxCheckListBox (requires wxUSE_OWNER_DRAWN)
     2310+#define wxUSE_CHOICE        1   // wxChoice
     2311+#define wxUSE_COLLPANE      1   // wxCollapsiblePane
     2312+#define wxUSE_COLOURPICKERCTRL 1    // wxColourPickerCtrl
     2313+#define wxUSE_COMBOBOX      1   // wxComboBox
     2314+#define wxUSE_DATAVIEWCTRL  1   // wxDataViewCtrl
     2315+#define wxUSE_DATEPICKCTRL  1   // wxDatePickerCtrl
     2316+#define wxUSE_DIRPICKERCTRL 1   // wxDirPickerCtrl
     2317+#define wxUSE_FILEPICKERCTRL 1  // wxFilePickerCtrl
     2318+#define wxUSE_FONTPICKERCTRL 1  // wxFontPickerCtrl
     2319+#define wxUSE_GAUGE         1   // wxGauge
     2320+#define wxUSE_HYPERLINKCTRL 1   // wxHyperlinkCtrl
     2321+#define wxUSE_LISTBOX       1   // wxListBox
     2322+#define wxUSE_LISTCTRL      1   // wxListCtrl
     2323+#define wxUSE_RADIOBOX      1   // wxRadioBox
     2324+#define wxUSE_RADIOBTN      1   // wxRadioButton
     2325+#define wxUSE_SCROLLBAR     1   // wxScrollBar
     2326+#define wxUSE_SEARCHCTRL    1   // wxSearchCtrl
     2327+#define wxUSE_SLIDER        1   // wxSlider
     2328+#define wxUSE_SPINBTN       1   // wxSpinButton
     2329+#define wxUSE_SPINCTRL      1   // wxSpinCtrl
     2330+#define wxUSE_STATBOX       1   // wxStaticBox
     2331+#define wxUSE_STATLINE      1   // wxStaticLine
     2332+#define wxUSE_STATTEXT      1   // wxStaticText
     2333+#define wxUSE_STATBMP       1   // wxStaticBitmap
     2334+#define wxUSE_TEXTCTRL      1   // wxTextCtrl
     2335+#define wxUSE_TOGGLEBTN     1   // requires wxButton
     2336+#define wxUSE_TREECTRL      1   // wxTreeCtrl
     2337+
     2338+// Use a status bar class? Depending on the value of wxUSE_NATIVE_STATUSBAR
     2339+// below either wxStatusBar95 or a generic wxStatusBar will be used.
     2340+//
     2341+// Default is 1
     2342+//
     2343+// Recommended setting: 1
     2344+#define wxUSE_STATUSBAR    1
     2345+
     2346+// Two status bar implementations are available under Win32: the generic one
     2347+// or the wrapper around native control. For native look and feel the native
     2348+// version should be used.
     2349+//
     2350+// Default is 1 for the platforms where native status bar is supported.
     2351+//
     2352+// Recommended setting: 1 (there is no advantage in using the generic one)
     2353+#define wxUSE_NATIVE_STATUSBAR        1
     2354+
     2355+// wxToolBar related settings: if wxUSE_TOOLBAR is 0, don't compile any toolbar
     2356+// classes at all. Otherwise, use the native toolbar class unless
     2357+// wxUSE_TOOLBAR_NATIVE is 0.
     2358+//
     2359+// Default is 1 for all settings.
     2360+//
     2361+// Recommended setting: 1 for wxUSE_TOOLBAR and wxUSE_TOOLBAR_NATIVE.
     2362+#define wxUSE_TOOLBAR 1
     2363+#define wxUSE_TOOLBAR_NATIVE 1
     2364+
     2365+// wxNotebook is a control with several "tabs" located on one of its sides. It
     2366+// may be used to logically organise the data presented to the user instead of
     2367+// putting everything in one huge dialog. It replaces wxTabControl and related
     2368+// classes of wxWin 1.6x.
     2369+//
     2370+// Default is 1.
     2371+//
     2372+// Recommended setting: 1
     2373+#define wxUSE_NOTEBOOK 1
     2374+
     2375+// wxListbook control is similar to wxNotebook but uses wxListCtrl instead of
     2376+// the tabs
     2377+//
     2378+// Default is 1.
     2379+//
     2380+// Recommended setting: 1
     2381+#define wxUSE_LISTBOOK 1
     2382+
     2383+// wxChoicebook control is similar to wxNotebook but uses wxChoice instead of
     2384+// the tabs
     2385+//
     2386+// Default is 1.
     2387+//
     2388+// Recommended setting: 1
     2389+#define wxUSE_CHOICEBOOK 1
     2390+
     2391+// wxTreebook control is similar to wxNotebook but uses wxTreeCtrl instead of
     2392+// the tabs
     2393+//
     2394+// Default is 1.
     2395+//
     2396+// Recommended setting: 1
     2397+#define wxUSE_TREEBOOK 1
     2398+
     2399+// wxToolbook control is similar to wxNotebook but uses wxToolBar instead of
     2400+// tabs
     2401+//
     2402+// Default is 1.
     2403+//
     2404+// Recommended setting: 1
     2405+#define wxUSE_TOOLBOOK 1
     2406+
     2407+// wxTabDialog is a generic version of wxNotebook but it is incompatible with
     2408+// the new class. It shouldn't be used in new code.
     2409+//
     2410+// Default is 0.
     2411+//
     2412+// Recommended setting: 0 (use wxNotebook)
     2413+#define wxUSE_TAB_DIALOG    0
     2414+
     2415+// wxGrid class
     2416+//
     2417+// Default is 1, set to 0 to cut down compilation time and binaries size if you
     2418+// don't use it.
     2419+//
     2420+// Recommended setting: 1
     2421+//
     2422+#define wxUSE_GRID         1
     2423+
     2424+// wxMiniFrame class: a frame with narrow title bar
     2425+//
     2426+// Default is 1.
     2427+//
     2428+// Recommended setting: 1 (it doesn't cost almost anything)
     2429+#define wxUSE_MINIFRAME 1
     2430+
     2431+// wxComboCtrl and related classes: combobox with custom popup window and
     2432+// not necessarily a listbox.
     2433+//
     2434+// Default is 1.
     2435+//
     2436+// Recommended setting: 1 but can be safely set to 0 except for wxUniv where it
     2437+//                      it used by wxComboBox
     2438+#define wxUSE_COMBOCTRL 1
     2439+
     2440+// wxOwnerDrawnComboBox is a custom combobox allowing to paint the combobox
     2441+// items.
     2442+//
     2443+// Default is 1.
     2444+//
     2445+// Recommended setting: 1 but can be safely set to 0, except where it is
     2446+//                      needed as a base class for generic wxBitmapComboBox.
     2447+#define wxUSE_ODCOMBOBOX 1
     2448+
     2449+// wxBitmapComboBox is a combobox that can have images in front of text items.
     2450+//
     2451+// Default is 1.
     2452+//
     2453+// Recommended setting: 1 but can be safely set to 0
     2454+#define wxUSE_BITMAPCOMBOBOX 1
     2455+
     2456+// ----------------------------------------------------------------------------
     2457+// Miscellaneous GUI stuff
     2458+// ----------------------------------------------------------------------------
     2459+
     2460+// wxAcceleratorTable/Entry classes and support for them in wxMenu(Bar)
     2461+#define wxUSE_ACCEL 1
     2462+
     2463+// Hotkey support (currently Windows only)
     2464+#define wxUSE_HOTKEY 1
     2465+
     2466+// Use wxCaret: a class implementing a "cursor" in a text control (called caret
     2467+// under Windows).
     2468+//
     2469+// Default is 1.
     2470+//
     2471+// Recommended setting: 1 (can be safely set to 0, not used by the library)
     2472+#define wxUSE_CARET         1
     2473+
     2474+// Use wxDisplay class: it allows enumerating all displays on a system and
     2475+// their geometries as well as finding the display on which the given point or
     2476+// window lies.
     2477+//
     2478+// Default is 1.
     2479+//
     2480+// Recommended setting: 1 if you need it, can be safely set to 0 otherwise
     2481+#define wxUSE_DISPLAY       1
     2482+
     2483+// Miscellaneous geometry code: needed for Canvas library
     2484+#define wxUSE_GEOMETRY            1
     2485+
     2486+// Use wxImageList. This class is needed by wxNotebook, wxTreeCtrl and
     2487+// wxListCtrl.
     2488+//
     2489+// Default is 1.
     2490+//
     2491+// Recommended setting: 1 (set it to 0 if you don't use any of the controls
     2492+// enumerated above, then this class is mostly useless too)
     2493+#define wxUSE_IMAGLIST      1
     2494+
     2495+// Use wxMenu, wxMenuBar, wxMenuItem.
     2496+//
     2497+// Default is 1.
     2498+//
     2499+// Recommended setting: 1 (can't be disabled under MSW)
     2500+#define wxUSE_MENUS         1
     2501+
     2502+// Use wxSashWindow class.
     2503+//
     2504+// Default is 1.
     2505+//
     2506+// Recommended setting: 1
     2507+#define wxUSE_SASH          1
     2508+
     2509+// Use wxSplitterWindow class.
     2510+//
     2511+// Default is 1.
     2512+//
     2513+// Recommended setting: 1
     2514+#define wxUSE_SPLITTER      1
     2515+
     2516+// Use wxToolTip and wxWindow::Set/GetToolTip() methods.
     2517+//
     2518+// Default is 1.
     2519+//
     2520+// Recommended setting: 1
     2521+#define wxUSE_TOOLTIPS      1
     2522+
     2523+// wxValidator class and related methods
     2524+#define wxUSE_VALIDATORS 1
     2525+
     2526+// ----------------------------------------------------------------------------
     2527+// common dialogs
     2528+// ----------------------------------------------------------------------------
     2529+
     2530+// On rare occasions (e.g. using DJGPP) may want to omit common dialogs (e.g.
     2531+// file selector, printer dialog). Switching this off also switches off the
     2532+// printing architecture and interactive wxPrinterDC.
     2533+//
     2534+// Default is 1
     2535+//
     2536+// Recommended setting: 1 (unless it really doesn't work)
     2537+#define wxUSE_COMMON_DIALOGS 1
     2538+
     2539+// wxBusyInfo displays window with message when app is busy. Works in same way
     2540+// as wxBusyCursor
     2541+#define wxUSE_BUSYINFO      1
     2542+
     2543+// Use single/multiple choice dialogs.
     2544+//
     2545+// Default is 1
     2546+//
     2547+// Recommended setting: 1 (used in the library itself)
     2548+#define wxUSE_CHOICEDLG     1
     2549+
     2550+// Use colour picker dialog
     2551+//
     2552+// Default is 1
     2553+//
     2554+// Recommended setting: 1
     2555+#define wxUSE_COLOURDLG     1
     2556+
     2557+// wxDirDlg class for getting a directory name from user
     2558+#define wxUSE_DIRDLG 1
     2559+
     2560+// TODO: setting to choose the generic or native one
     2561+
     2562+// Use file open/save dialogs.
     2563+//
     2564+// Default is 1
     2565+//
     2566+// Recommended setting: 1 (used in many places in the library itself)
     2567+#define wxUSE_FILEDLG       1
     2568+
     2569+// Use find/replace dialogs.
     2570+//
     2571+// Default is 1
     2572+//
     2573+// Recommended setting: 1 (but may be safely set to 0)
     2574+#define wxUSE_FINDREPLDLG       1
     2575+
     2576+// Use font picker dialog
     2577+//
     2578+// Default is 1
     2579+//
     2580+// Recommended setting: 1 (used in the library itself)
     2581+#define wxUSE_FONTDLG       1
     2582+
     2583+// Use wxMessageDialog and wxMessageBox.
     2584+//
     2585+// Default is 1
     2586+//
     2587+// Recommended setting: 1 (used in the library itself)
     2588+#define wxUSE_MSGDLG        1
     2589+
     2590+// progress dialog class for lengthy operations
     2591+#define wxUSE_PROGRESSDLG 1
     2592+
     2593+// support for startup tips (wxShowTip &c)
     2594+#define wxUSE_STARTUP_TIPS 1
     2595+
     2596+// text entry dialog and wxGetTextFromUser function
     2597+#define wxUSE_TEXTDLG 1
     2598+
     2599+// number entry dialog
     2600+#define wxUSE_NUMBERDLG 1
     2601+
     2602+// splash screen class
     2603+#define wxUSE_SPLASH 1
     2604+
     2605+// wizards
     2606+#define wxUSE_WIZARDDLG 1
     2607+
     2608+// Compile in wxAboutBox() function showing the standard "About" dialog.
     2609+//
     2610+// Default is 1
     2611+//
     2612+// Recommended setting: 1 but can be set to 0 to save some space if you don't
     2613+//                      use this function
     2614+#define wxUSE_ABOUTDLG 1
     2615+
     2616+// ----------------------------------------------------------------------------
     2617+// Metafiles support
     2618+// ----------------------------------------------------------------------------
     2619+
     2620+// Windows supports the graphics format known as metafile which is, though not
     2621+// portable, is widely used under Windows and so is supported by wxWin (under
     2622+// Windows only, of course). Win16 (Win3.1) used the so-called "Window
     2623+// MetaFiles" or WMFs which were replaced with "Enhanced MetaFiles" or EMFs in
     2624+// Win32 (Win9x, NT, 2000). Both of these are supported in wxWin and, by
     2625+// default, WMFs will be used under Win16 and EMFs under Win32. This may be
     2626+// changed by setting wxUSE_WIN_METAFILES_ALWAYS to 1 and/or setting
     2627+// wxUSE_ENH_METAFILE to 0. You may also set wxUSE_METAFILE to 0 to not compile
     2628+// in any metafile related classes at all.
     2629+//
     2630+// Default is 1 for wxUSE_ENH_METAFILE and 0 for wxUSE_WIN_METAFILES_ALWAYS.
     2631+//
     2632+// Recommended setting: default or 0 for everything for portable programs.
     2633+#define wxUSE_METAFILE              1
     2634+#define wxUSE_ENH_METAFILE          1
     2635+#define wxUSE_WIN_METAFILES_ALWAYS  0
     2636+
     2637+// ----------------------------------------------------------------------------
     2638+// Big GUI components
     2639+// ----------------------------------------------------------------------------
     2640+
     2641+// Set to 0 to disable MDI support.
     2642+//
     2643+// Requires wxUSE_NOTEBOOK under platforms other than MSW.
     2644+//
     2645+// Default is 1.
     2646+//
     2647+// Recommended setting: 1, can be safely set to 0.
     2648+#define wxUSE_MDI 1
     2649+
     2650+// Set to 0 to disable document/view architecture
     2651+#define wxUSE_DOC_VIEW_ARCHITECTURE 1
     2652+
     2653+// Set to 0 to disable MDI document/view architecture
     2654+//
     2655+// Requires wxUSE_MDI && wxUSE_DOC_VIEW_ARCHITECTURE
     2656+#define wxUSE_MDI_ARCHITECTURE    1
     2657+
     2658+// Set to 0 to disable print/preview architecture code
     2659+#define wxUSE_PRINTING_ARCHITECTURE  1
     2660+
     2661+// wxHTML sublibrary allows to display HTML in wxWindow programs and much,
     2662+// much more.
     2663+//
     2664+// Default is 1.
     2665+//
     2666+// Recommended setting: 1 (wxHTML is great!), set to 0 if you want compile a
     2667+// smaller library.
     2668+#define wxUSE_HTML          1
     2669+
     2670+// Setting wxUSE_GLCANVAS to 1 enables OpenGL support. You need to have OpenGL
     2671+// headers and libraries to be able to compile the library with wxUSE_GLCANVAS
     2672+// set to 1. Note that for some compilers (notably Microsoft Visual C++) you
     2673+// will need to manually add opengl32.lib and glu32.lib to the list of
     2674+// libraries linked with your program if you use OpenGL.
     2675+//
     2676+// Default is 0.
     2677+//
     2678+// Recommended setting: 1 if you intend to use OpenGL, 0 otherwise
     2679+#define wxUSE_GLCANVAS       1
     2680+
     2681+// wxRichTextCtrl allows editing of styled text.
     2682+//
     2683+// Default is 1.
     2684+//
     2685+// Recommended setting: 1, set to 0 if you want compile a
     2686+// smaller library.
     2687+#define wxUSE_RICHTEXT       1
     2688+
     2689+// ----------------------------------------------------------------------------
     2690+// Data transfer
     2691+// ----------------------------------------------------------------------------
     2692+
     2693+// Use wxClipboard class for clipboard copy/paste.
     2694+//
     2695+// Default is 1.
     2696+//
     2697+// Recommended setting: 1
     2698+#define wxUSE_CLIPBOARD     1
     2699+
     2700+// Use wxDataObject and related classes. Needed for clipboard and OLE drag and
     2701+// drop
     2702+//
     2703+// Default is 1.
     2704+//
     2705+// Recommended setting: 1
     2706+#define wxUSE_DATAOBJ       1
     2707+
     2708+// Use wxDropTarget and wxDropSource classes for drag and drop (this is
     2709+// different from "built in" drag and drop in wxTreeCtrl which is always
     2710+// available). Requires wxUSE_DATAOBJ.
     2711+//
     2712+// Default is 1.
     2713+//
     2714+// Recommended setting: 1
     2715+#define wxUSE_DRAG_AND_DROP 1
     2716+
     2717+// Use wxAccessible for enhanced and customisable accessibility.
     2718+// Depends on wxUSE_OLE.
     2719+//
     2720+// Default is 0.
     2721+//
     2722+// Recommended setting (at present): 0
     2723+#define wxUSE_ACCESSIBILITY 0
     2724+
     2725+// ----------------------------------------------------------------------------
     2726+// miscellaneous settings
     2727+// ----------------------------------------------------------------------------
     2728+
     2729+// wxSingleInstanceChecker class allows to verify at startup if another program
     2730+// instance is running.
     2731+//
     2732+// Default is 1
     2733+//
     2734+// Recommended setting: 1 (the class is tiny, disabling it won't save much
     2735+// space)
     2736+#define wxUSE_SNGLINST_CHECKER  1
     2737+
     2738+#define wxUSE_DRAGIMAGE 1
     2739+
     2740+#define wxUSE_IPC         1
     2741+                                // 0 for no interprocess comms
     2742+#define wxUSE_HELP        1
     2743+                                // 0 for no help facility
     2744+
     2745+// Should we use MS HTML help for wxHelpController? If disabled, neither
     2746+// wxCHMHelpController nor wxBestHelpController are available.
     2747+//
     2748+// Default is 1 under MSW, 0 is always used for the other platforms.
     2749+//
     2750+// Recommended setting: 1, only set to 0 if you have trouble compiling
     2751+// wxCHMHelpController (could be a problem with really ancient compilers)
     2752+#define wxUSE_MS_HTML_HELP 1
     2753+
     2754+
     2755+// Use wxHTML-based help controller?
     2756+#define wxUSE_WXHTML_HELP 1
     2757+
     2758+#define wxUSE_RESOURCES   0
     2759+                                // 0 for no wxGetResource/wxWriteResource
     2760+#define wxUSE_CONSTRAINTS 1
     2761+                                // 0 for no window layout constraint system
     2762+
     2763+#define wxUSE_SPLINES     1
     2764+                                // 0 for no splines
     2765+
     2766+#define wxUSE_MOUSEWHEEL        1
     2767+                                // Include mouse wheel support
     2768+
     2769+// ----------------------------------------------------------------------------
     2770+// postscript support settings
     2771+// ----------------------------------------------------------------------------
     2772+
     2773+// Set to 1 for PostScript device context.
     2774+#define wxUSE_POSTSCRIPT  1
     2775+
     2776+// Set to 1 to use font metric files in GetTextExtent
     2777+#define wxUSE_AFM_FOR_POSTSCRIPT 1
     2778+
     2779+// ----------------------------------------------------------------------------
     2780+// database classes
     2781+// ----------------------------------------------------------------------------
     2782+
     2783+// Define 1 to use ODBC classes
     2784+#define wxUSE_ODBC          0
     2785+
     2786+// For backward compatibility reasons, this parameter now only controls the
     2787+// default scrolling method used by cursors.  This default behavior can be
     2788+// overriden by setting the second param of wxDB::wxDbGetConnection() or
     2789+// wxDb() constructor to indicate whether the connection (and any wxDbTable()s
     2790+// that use the connection) should support forward only scrolling of cursors,
     2791+// or both forward and backward support for backward scrolling cursors is
     2792+// dependent on the data source as well as the ODBC driver being used.
     2793+#define wxODBC_FWD_ONLY_CURSORS         1
     2794+
     2795+// Default is 0.  Set to 1 to use the deprecated classes, enum types, function,
     2796+// member variables.  With a setting of 1, full backward compatibility with the
     2797+// 2.0.x release is possible. It is STRONGLY recommended that this be set to 0,
     2798+// as future development will be done only on the non-deprecated
     2799+// functions/classes/member variables/etc.
     2800+#define wxODBC_BACKWARD_COMPATABILITY 0
     2801+
     2802+// ----------------------------------------------------------------------------
     2803+// other compiler (mis)features
     2804+// ----------------------------------------------------------------------------
     2805+
     2806+// Set this to 0 if your compiler can't cope with omission of prototype
     2807+// parameters.
     2808+//
     2809+// Default is 1.
     2810+//
     2811+// Recommended setting: 1 (should never need to set this to 0)
     2812+#define REMOVE_UNUSED_ARG   1
     2813+
     2814+// VC++ 4.2 and above allows <iostream> and <iostream.h> but you can't mix
     2815+// them. Set to 1 for <iostream.h>, 0 for <iostream>. Note that VC++ 7.1
     2816+// and later doesn't support wxUSE_IOSTREAMH == 1 and so <iostream> will be
     2817+// used anyhow.
     2818+//
     2819+// Default is 1.
     2820+//
     2821+// Recommended setting: whatever your compiler likes more
     2822+#define wxUSE_IOSTREAMH     1
     2823+
     2824+// ----------------------------------------------------------------------------
     2825+// image format support
     2826+// ----------------------------------------------------------------------------
     2827+
     2828+// wxImage supports many different image formats which can be configured at
     2829+// compile-time. BMP is always supported, others are optional and can be safely
     2830+// disabled if you don't plan to use images in such format sometimes saving
     2831+// substantial amount of code in the final library.
     2832+//
     2833+// Some formats require an extra library which is included in wxWin sources
     2834+// which is mentioned if it is the case.
     2835+
     2836+// Set to 1 for wxImage support (recommended).
     2837+#define wxUSE_IMAGE         1
     2838+
     2839+// Set to 1 for PNG format support (requires libpng). Also requires wxUSE_ZLIB.
     2840+#define wxUSE_LIBPNG        1
     2841+
     2842+// Set to 1 for JPEG format support (requires libjpeg)
     2843+#define wxUSE_LIBJPEG       1
     2844+
     2845+// Set to 1 for TIFF format support (requires libtiff)
     2846+#define wxUSE_LIBTIFF       1
     2847+
     2848+// Set to 1 for TGA format support (loading only)
     2849+#define wxUSE_TGA           1
     2850+
     2851+// Set to 1 for GIF format support
     2852+#define wxUSE_GIF           1
     2853+
     2854+// Set to 1 for PNM format support
     2855+#define wxUSE_PNM           1
     2856+
     2857+// Set to 1 for PCX format support
     2858+#define wxUSE_PCX           1
     2859+
     2860+// Set to 1 for IFF format support (Amiga format)
     2861+#define wxUSE_IFF           0
     2862+
     2863+// Set to 1 for XPM format support
     2864+#define wxUSE_XPM           1
     2865+
     2866+// Set to 1 for MS Icons and Cursors format support
     2867+#define wxUSE_ICO_CUR       1
     2868+
     2869+// Set to 1 to compile in wxPalette class
     2870+#define wxUSE_PALETTE       1
     2871+
     2872+// ----------------------------------------------------------------------------
     2873+// wxUniversal-only options
     2874+// ----------------------------------------------------------------------------
     2875+
     2876+// Set to 1 to enable compilation of all themes, this is the default
     2877+#define wxUSE_ALL_THEMES    1
     2878+
     2879+// Set to 1 to enable the compilation of individual theme if wxUSE_ALL_THEMES
     2880+// is unset, if it is set these options are not used; notice that metal theme
     2881+// uses Win32 one
     2882+#define wxUSE_THEME_GTK     0
     2883+#define wxUSE_THEME_METAL   0
     2884+#define wxUSE_THEME_MONO    0
     2885+#define wxUSE_THEME_WIN32   0
     2886+
     2887+
     2888+/* --- end common options --- */
     2889+
     2890+// ----------------------------------------------------------------------------
     2891+// Windows-only settings
     2892+// ----------------------------------------------------------------------------
     2893+
     2894+// Set wxUSE_UNICODE_MSLU to 1 if you're compiling wxWidgets in Unicode mode
     2895+// and want to run your programs under Windows 9x and not only NT/2000/XP.
     2896+// This setting enables use of unicows.dll from MSLU (MS Layer for Unicode, see
     2897+// http://www.microsoft.com/globaldev/handson/dev/mslu_announce.mspx). Note
     2898+// that you will have to modify the makefiles to include unicows.lib import
     2899+// library as the first library (see installation instructions in install.txt
     2900+// to learn how to do it when building the library or samples).
     2901+//
     2902+// If your compiler doesn't have unicows.lib, you can get a version of it at
     2903+// http://libunicows.sourceforge.net
     2904+//
     2905+// Default is 0
     2906+//
     2907+// Recommended setting: 0 (1 if you want to deploy Unicode apps on 9x systems)
     2908+#ifndef wxUSE_UNICODE_MSLU
     2909+    #define wxUSE_UNICODE_MSLU 1
     2910+#endif
     2911+
     2912+// Set this to 1 if you want to use wxWidgets and MFC in the same program. This
     2913+// will override some other settings (see below)
     2914+//
     2915+// Default is 0.
     2916+//
     2917+// Recommended setting: 0 unless you really have to use MFC
     2918+#define wxUSE_MFC           0
     2919+
     2920+// Set this to 1 for generic OLE support: this is required for drag-and-drop,
     2921+// clipboard, OLE Automation. Only set it to 0 if your compiler is very old and
     2922+// can't compile/doesn't have the OLE headers.
     2923+//
     2924+// Default is 1.
     2925+//
     2926+// Recommended setting: 1
     2927+#define wxUSE_OLE           1
     2928+
     2929+// Set this to 1 to enable wxAutomationObject class.
     2930+//
     2931+// Default is 1.
     2932+//
     2933+// Recommended setting: 1 if you need to control other applications via OLE
     2934+// Automation, can be safely set to 0 otherwise
     2935+#define wxUSE_OLE_AUTOMATION 1
     2936+
     2937+// Set this to 1 to enable wxActiveXContainer class allowing to embed OLE
     2938+// controls in wx.
     2939+//
     2940+// Default is 1.
     2941+//
     2942+// Recommended setting: 1, required by wxMediaCtrl
     2943+#define wxUSE_ACTIVEX 1
     2944+
     2945+// wxDC cacheing implementation
     2946+#define wxUSE_DC_CACHEING 1
     2947+
     2948+// Set this to 1 to enable the use of DIB's for wxBitmap to support
     2949+// bitmaps > 16MB on Win95/98/Me.  Set to 0 to use DDB's only.
     2950+#define wxUSE_DIB_FOR_BITMAP 1
     2951+
     2952+// Set this to 1 to enable wxDIB class used internally for manipulating
     2953+// wxBitmao data.
     2954+//
     2955+// Default is 1, set it to 0 only if you don't use wxImage neither
     2956+//
     2957+// Recommended setting: 1 (without it conversion to/from wxImage won't work)
     2958+#define wxUSE_WXDIB 1
     2959+
     2960+// Set to 0 to disable PostScript print/preview architecture code under Windows
     2961+// (just use Windows printing).
     2962+#define wxUSE_POSTSCRIPT_ARCHITECTURE_IN_MSW 1
     2963+
     2964+// Set this to 1 to use RICHEDIT controls for wxTextCtrl with style wxTE_RICH
     2965+// which allows to put more than ~32Kb of text in it even under Win9x (NT
     2966+// doesn't have such limitation).
     2967+//
     2968+// Default is 1 for compilers which support it
     2969+//
     2970+// Recommended setting: 1, only set it to 0 if your compiler doesn't have
     2971+//                      or can't compile <richedit.h>
     2972+#define wxUSE_RICHEDIT  1
     2973+
     2974+// Set this to 1 to use extra features of richedit v2 and later controls
     2975+//
     2976+// Default is 1 for compilers which support it
     2977+//
     2978+// Recommended setting: 1
     2979+#define wxUSE_RICHEDIT2 1
     2980+
     2981+// Set this to 1 to enable support for the owner-drawn menu and listboxes. This
     2982+// is required by wxUSE_CHECKLISTBOX.
     2983+//
     2984+// Default is 1.
     2985+//
     2986+// Recommended setting: 1, set to 0 for a small library size reduction
     2987+#define wxUSE_OWNER_DRAWN 1
     2988+
     2989+// Set to 1 to compile MS Windows XP theme engine support
     2990+#define wxUSE_UXTHEME           1
     2991+
     2992+// Set to 1 to auto-adapt to MS Windows XP themes where possible
     2993+// (notably, wxNotebook pages)
     2994+#define wxUSE_UXTHEME_AUTO      1
     2995+
     2996+// Set to 1 to use InkEdit control (Tablet PC), if available
     2997+#define wxUSE_INKEDIT  0
     2998+
     2999+// ----------------------------------------------------------------------------
     3000+// Generic versions of native controls
     3001+// ----------------------------------------------------------------------------
     3002+
     3003+// Set this to 1 to be able to use wxDatePickerCtrlGeneric in addition to the
     3004+// native wxDatePickerCtrl
     3005+//
     3006+// Default is 0.
     3007+//
     3008+// Recommended setting: 0, this is mainly used for testing
     3009+#define wxUSE_DATEPICKCTRL_GENERIC 1
     3010+
     3011+// ----------------------------------------------------------------------------
     3012+// Crash debugging helpers
     3013+// ----------------------------------------------------------------------------
     3014+
     3015+// Set this to 1 to be able to use wxCrashReport::Generate() to create mini
     3016+// dumps of your program when it crashes (or at any other moment)
     3017+//
     3018+// Default is 1 if supported by the compiler (VC++ and recent BC++ only).
     3019+//
     3020+// Recommended setting: 1, set to 0 if your programs never crash
     3021+#define wxUSE_CRASHREPORT 1
     3022+
     3023+// ----------------------------------------------------------------------------
     3024+// obsolete settings
     3025+// ----------------------------------------------------------------------------
     3026+
     3027+// NB: all settings in this section are obsolete and should not be used/changed
     3028+//     at all, they will disappear
     3029+
     3030+// Define 1 to use bitmap messages.
     3031+#define wxUSE_BITMAP_MESSAGE         1
     3032+
     3033+#endif // _WX_SETUP_H_
     3034+
     3035diff '--exclude-from=wxPython-src-2.8.9.1/exclude' -Nur orig/wxPython-src-2.8.9.1//lib/vc_dll/mswu/build.cfg wxPython-src-2.8.9.1//lib/vc_dll/mswu/build.cfg
     3036--- orig/wxPython-src-2.8.9.1//lib/vc_dll/mswu/build.cfg        1970-01-01 01:00:00.000000000 +0100
     3037+++ wxPython-src-2.8.9.1//lib/vc_dll/mswu/build.cfg     2009-06-25 23:46:18.000000000 +0200
     3038@@ -0,0 +1,31 @@
     3039+WXVER_MAJOR=2
     3040+WXVER_MINOR=8
     3041+WXVER_RELEASE=8
     3042+BUILD=release
     3043+MONOLITHIC=0
     3044+SHARED=1
     3045+UNICODE=1
     3046+WXUNIV=0
     3047+CFG=
     3048+VENDOR=
     3049+OFFICIAL_BUILD=1
     3050+DEBUG_FLAG=default
     3051+DEBUG_INFO=default
     3052+RUNTIME_LIBS=dynamic
     3053+MSLU=1
     3054+USE_EXCEPTIONS=1
     3055+USE_THREADS=1
     3056+USE_GUI=1
     3057+USE_HTML=1
     3058+USE_MEDIA=1
     3059+USE_ODBC=0
     3060+USE_OPENGL=1
     3061+USE_QA=1
     3062+USE_GDIPLUS=1
     3063+COMPILER=vc
     3064+CC=cl
     3065+CXX=cl
     3066+CFLAGS=
     3067+CPPFLAGS=
     3068+CXXFLAGS=
     3069+LDFLAGS=
     3070diff '--exclude-from=wxPython-src-2.8.9.1/exclude' -Nur orig/wxPython-src-2.8.9.1//lib/vc_dll/mswu/wx/setup.h wxPython-src-2.8.9.1//lib/vc_dll/mswu/wx/setup.h
     3071--- orig/wxPython-src-2.8.9.1//lib/vc_dll/mswu/wx/setup.h       1970-01-01 01:00:00.000000000 +0100
     3072+++ wxPython-src-2.8.9.1//lib/vc_dll/mswu/wx/setup.h    2009-01-30 18:59:12.000000000 +0100
     3073@@ -0,0 +1,1349 @@
     3074+/////////////////////////////////////////////////////////////////////////////
     3075+// Name:        wx/msw/setup.h
     3076+// Purpose:     Configuration for the library
     3077+// Author:      Julian Smart
     3078+// Modified by:
     3079+// Created:     01/02/97
     3080+// RCS-ID:      $Id: setup0.h 51451 2008-01-29 23:11:55Z VZ $
     3081+// Copyright:   (c) Julian Smart
     3082+// Licence:     wxWindows licence
     3083+/////////////////////////////////////////////////////////////////////////////
     3084+
     3085+#ifndef _WX_SETUP_H_
     3086+#define _WX_SETUP_H_
     3087+
     3088+/* --- start common options --- */
     3089+// ----------------------------------------------------------------------------
     3090+// global settings
     3091+// ----------------------------------------------------------------------------
     3092+
     3093+// define this to 0 when building wxBase library - this can also be done from
     3094+// makefile/project file overriding the value here
     3095+#ifndef wxUSE_GUI
     3096+    #define wxUSE_GUI            1
     3097+#endif // wxUSE_GUI
     3098+
     3099+// ----------------------------------------------------------------------------
     3100+// compatibility settings
     3101+// ----------------------------------------------------------------------------
     3102+
     3103+// This setting determines the compatibility with 2.4 API: set it to 1 to
     3104+// enable it but please consider updating your code instead.
     3105+//
     3106+// Default is 0
     3107+//
     3108+// Recommended setting: 0 (please update your code)
     3109+#define WXWIN_COMPATIBILITY_2_4 0
     3110+
     3111+// This setting determines the compatibility with 2.6 API: set it to 0 to
     3112+// flag all cases of using deprecated functions.
     3113+//
     3114+// Default is 1 but please try building your code with 0 as the default will
     3115+// change to 0 in the next version and the deprecated functions will disappear
     3116+// in the version after it completely.
     3117+//
     3118+// Recommended setting: 0 (please update your code)
     3119+#define WXWIN_COMPATIBILITY_2_6 1
     3120+
     3121+// MSW-only: Set to 0 for accurate dialog units, else 1 for old behaviour when
     3122+// default system font is used for wxWindow::GetCharWidth/Height() instead of
     3123+// the current font.
     3124+//
     3125+// Default is 0
     3126+//
     3127+// Recommended setting: 0
     3128+#define wxDIALOG_UNIT_COMPATIBILITY   0
     3129+
     3130+// ----------------------------------------------------------------------------
     3131+// debugging settings
     3132+// ----------------------------------------------------------------------------
     3133+
     3134+// Generic comment about debugging settings: they are very useful if you don't
     3135+// use any other memory leak detection tools such as Purify/BoundsChecker, but
     3136+// are probably redundant otherwise. Also, Visual C++ CRT has the same features
     3137+// as wxWidgets memory debugging subsystem built in since version 5.0 and you
     3138+// may prefer to use it instead of built in memory debugging code because it is
     3139+// faster and more fool proof.
     3140+//
     3141+// Using VC++ CRT memory debugging is enabled by default in debug mode
     3142+// (__WXDEBUG__) if wxUSE_GLOBAL_MEMORY_OPERATORS is *not* enabled (i.e. is 0)
     3143+// and if __NO_VC_CRTDBG__ is not defined.
     3144+
     3145+// If 1, enables wxDebugContext, for writing error messages to file, etc. If
     3146+// __WXDEBUG__ is not defined, will still use the normal memory operators.
     3147+//
     3148+// Default is 0
     3149+//
     3150+// Recommended setting: 0
     3151+#define wxUSE_DEBUG_CONTEXT 0
     3152+
     3153+// If 1, enables debugging versions of wxObject::new and wxObject::delete *IF*
     3154+// __WXDEBUG__ is also defined.
     3155+//
     3156+// WARNING: this code may not work with all architectures, especially if
     3157+// alignment is an issue. This switch is currently ignored for mingw / cygwin
     3158+//
     3159+// Default is 0
     3160+//
     3161+// Recommended setting: 1 if you are not using a memory debugging tool, else 0
     3162+#define wxUSE_MEMORY_TRACING 0
     3163+
     3164+// In debug mode, cause new and delete to be redefined globally.
     3165+// If this causes problems (e.g. link errors which is a common problem
     3166+// especially if you use another library which also redefines the global new
     3167+// and delete), set this to 0.
     3168+// This switch is currently ignored for mingw / cygwin
     3169+//
     3170+// Default is 0
     3171+//
     3172+// Recommended setting: 0
     3173+#define wxUSE_GLOBAL_MEMORY_OPERATORS 0
     3174+
     3175+// In debug mode, causes new to be defined to be WXDEBUG_NEW (see object.h). If
     3176+// this causes problems (e.g. link errors), set this to 0. You may need to set
     3177+// this to 0 if using templates (at least for VC++). This switch is currently
     3178+// ignored for mingw / cygwin / CodeWarrior
     3179+//
     3180+// Default is 0
     3181+//
     3182+// Recommended setting: 0
     3183+#define wxUSE_DEBUG_NEW_ALWAYS 0
     3184+
     3185+// wxHandleFatalExceptions() may be used to catch the program faults at run
     3186+// time and, instead of terminating the program with a usual GPF message box,
     3187+// call the user-defined wxApp::OnFatalException() function. If you set
     3188+// wxUSE_ON_FATAL_EXCEPTION to 0, wxHandleFatalExceptions() will not work.
     3189+//
     3190+// This setting is for Win32 only and can only be enabled if your compiler
     3191+// supports Win32 structured exception handling (currently only VC++ does)
     3192+//
     3193+// Default is 1
     3194+//
     3195+// Recommended setting: 1 if your compiler supports it.
     3196+#define wxUSE_ON_FATAL_EXCEPTION 1
     3197+
     3198+// Set this to 1 to be able to generate a human-readable (unlike
     3199+// machine-readable minidump created by wxCrashReport::Generate()) stack back
     3200+// trace when your program crashes using wxStackWalker
     3201+//
     3202+// Default is 1 if supported by the compiler.
     3203+//
     3204+// Recommended setting: 1, set to 0 if your programs never crash
     3205+#define wxUSE_STACKWALKER 1
     3206+
     3207+// Set this to 1 to compile in wxDebugReport class which allows you to create
     3208+// and optionally upload to your web site a debug report consisting of back
     3209+// trace of the crash (if wxUSE_STACKWALKER == 1) and other information.
     3210+//
     3211+// Default is 1 if supported by the compiler.
     3212+//
     3213+// Recommended setting: 1, it is compiled into a separate library so there
     3214+//                         is no overhead if you don't use it
     3215+#define wxUSE_DEBUGREPORT 0
     3216+
     3217+// ----------------------------------------------------------------------------
     3218+// Unicode support
     3219+// ----------------------------------------------------------------------------
     3220+
     3221+// Set wxUSE_UNICODE to 1 to compile wxWidgets in Unicode mode: wxChar will be
     3222+// defined as wchar_t, wxString will use Unicode internally. If you set this
     3223+// to 1, you must use wxT() macro for all literal strings in the program.
     3224+//
     3225+// Unicode is currently only fully supported under Windows NT/2000/XP
     3226+// (Windows 9x doesn't support it and the programs compiled in Unicode mode
     3227+// will not run under 9x -- but see wxUSE_UNICODE_MSLU below).
     3228+//
     3229+// Default is 0
     3230+//
     3231+// Recommended setting: 0 (unless you only plan to use Windows NT/2000/XP)
     3232+#ifndef wxUSE_UNICODE
     3233+    #define wxUSE_UNICODE 1
     3234+#endif
     3235+
     3236+// Setting wxUSE_WCHAR_T to 1 gives you some degree of Unicode support without
     3237+// compiling the program in Unicode mode. More precisely, it will be possible
     3238+// to construct wxString from a wide (Unicode) string and convert any wxString
     3239+// to Unicode.
     3240+//
     3241+// Default is 1
     3242+//
     3243+// Recommended setting: 1
     3244+#define wxUSE_WCHAR_T 1
     3245+
     3246+// ----------------------------------------------------------------------------
     3247+// global features
     3248+// ----------------------------------------------------------------------------
     3249+
     3250+// Compile library in exception-safe mode? If set to 1, the library will try to
     3251+// behave correctly in presence of exceptions (even though it still will not
     3252+// use the exceptions itself) and notify the user code about any unhandled
     3253+// exceptions. If set to 0, propagation of the exceptions through the library
     3254+// code will lead to undefined behaviour -- but the code itself will be
     3255+// slightly smaller and faster.
     3256+//
     3257+// Note that like wxUSE_THREADS this option is automatically set to 0 if
     3258+// wxNO_EXCEPTIONS is defined.
     3259+//
     3260+// Default is 1
     3261+//
     3262+// Recommended setting: depends on whether you intend to use C++ exceptions
     3263+//                      in your own code (1 if you do, 0 if you don't)
     3264+#define wxUSE_EXCEPTIONS    0
     3265+
     3266+// Set wxUSE_EXTENDED_RTTI to 1 to use extended RTTI
     3267+//
     3268+// Default is 0
     3269+//
     3270+// Recommended setting: 0 (this is still work in progress...)
     3271+#define wxUSE_EXTENDED_RTTI 0
     3272+
     3273+// Set wxUSE_STL to 1 to derive wxList(Foo) and wxArray(Foo) from
     3274+// std::list<Foo*> and std::vector<Foo*>, with a compatibility interface,
     3275+// and for wxHashMap to be implemented with templates.
     3276+//
     3277+// Default is 0
     3278+//
     3279+// Recommended setting: YMMV
     3280+#define wxUSE_STL 0
     3281+
     3282+// Support for message/error logging. This includes wxLogXXX() functions and
     3283+// wxLog and derived classes. Don't set this to 0 unless you really know what
     3284+// you are doing.
     3285+//
     3286+// Default is 1
     3287+//
     3288+// Recommended setting: 1 (always)
     3289+#define wxUSE_LOG 1
     3290+
     3291+// Recommended setting: 1
     3292+#define wxUSE_LOGWINDOW 1
     3293+
     3294+// Recommended setting: 1
     3295+#define wxUSE_LOGGUI 1
     3296+
     3297+// Recommended setting: 1
     3298+#define wxUSE_LOG_DIALOG 1
     3299+
     3300+// Support for command line parsing using wxCmdLineParser class.
     3301+//
     3302+// Default is 1
     3303+//
     3304+// Recommended setting: 1 (can be set to 0 if you don't use the cmd line)
     3305+#define wxUSE_CMDLINE_PARSER 1
     3306+
     3307+// Support for multithreaded applications: if 1, compile in thread classes
     3308+// (thread.h) and make the library a bit more thread safe. Although thread
     3309+// support is quite stable by now, you may still consider recompiling the
     3310+// library without it if you have no use for it - this will result in a
     3311+// somewhat smaller and faster operation.
     3312+//
     3313+// Notice that if wxNO_THREADS is defined, wxUSE_THREADS is automatically reset
     3314+// to 0 in wx/chkconf.h, so, for example, if you set USE_THREADS to 0 in
     3315+// build/msw/config.* file this value will have no effect.
     3316+//
     3317+// Default is 1
     3318+//
     3319+// Recommended setting: 0 unless you do plan to develop MT applications
     3320+#define wxUSE_THREADS 1
     3321+
     3322+// If enabled, compiles wxWidgets streams classes
     3323+//
     3324+// wx stream classes are used for image IO, process IO redirection, network
     3325+// protocols implementation and much more and so disabling this results in a
     3326+// lot of other functionality being lost.
     3327+//
     3328+// Default is 1
     3329+//
     3330+// Recommended setting: 1 as setting it to 0 disables many other things
     3331+#define wxUSE_STREAMS       1
     3332+
     3333+// Use standard C++ streams if 1 instead of wx streams in some places. If
     3334+// disabled (default), wx streams are used everywhere and wxWidgets doesn't
     3335+// depend on the standard streams library.
     3336+//
     3337+// Notice that enabling this does not replace wx streams with std streams
     3338+// everywhere, in a lot of places wx streams are used no matter what.
     3339+//
     3340+// Default is 0
     3341+//
     3342+// Recommended setting: 1 if you use the standard streams anyhow and so
     3343+//                      dependency on the standard streams library is not a
     3344+//                      problem
     3345+#define wxUSE_STD_IOSTREAM  0
     3346+
     3347+// Enable conversion to standard C++ string if 1.
     3348+//
     3349+// Default is 1 for most compilers.
     3350+//
     3351+// Currently the Digital Mars and Watcom compilers come without standard C++
     3352+// library headers by default, wxUSE_STD_STRING can be set to 1 if you do have
     3353+// them (e.g. from STLPort).
     3354+//
     3355+// VC++ 5.0 does include standard C++ library header, however they produce
     3356+// many warnings that can't be turned off when compiled at warning level 4.
     3357+#if defined(__DMC__) || defined(__WATCOMC__) \
     3358+        || (defined(_MSC_VER) && _MSC_VER < 1200)
     3359+    #define wxUSE_STD_STRING  0
     3360+#else
     3361+    #define wxUSE_STD_STRING  1
     3362+#endif
     3363+
     3364+// Support for positional parameters (e.g. %1$d, %2$s ...) in wxVsnprintf.
     3365+// Note that if the system's implementation does not support positional
     3366+// parameters, setting this to 1 forces the use of the wxWidgets implementation
     3367+// of wxVsnprintf. The standard vsnprintf() supports positional parameters on
     3368+// many Unix systems but usually doesn't under Windows.
     3369+//
     3370+// Positional parameters are very useful when translating a program since using
     3371+// them in formatting strings allow translators to correctly reorder the
     3372+// translated sentences.
     3373+//
     3374+// Default is 1
     3375+//
     3376+// Recommended setting: 1 if you want to support multiple languages
     3377+#define wxUSE_PRINTF_POS_PARAMS      1
     3378+
     3379+// ----------------------------------------------------------------------------
     3380+// non GUI features selection
     3381+// ----------------------------------------------------------------------------
     3382+
     3383+// Set wxUSE_LONGLONG to 1 to compile the wxLongLong class. This is a 64 bit
     3384+// integer which is implemented in terms of native 64 bit integers if any or
     3385+// uses emulation otherwise.
     3386+//
     3387+// This class is required by wxDateTime and so you should enable it if you want
     3388+// to use wxDateTime. For most modern platforms, it will use the native 64 bit
     3389+// integers in which case (almost) all of its functions are inline and it
     3390+// almost does not take any space, so there should be no reason to switch it
     3391+// off.
     3392+//
     3393+// Recommended setting: 1
     3394+#define wxUSE_LONGLONG      1
     3395+
     3396+// Set wxUSE_(F)FILE to 1 to compile wx(F)File classes. wxFile uses low level
     3397+// POSIX functions for file access, wxFFile uses ANSI C stdio.h functions.
     3398+//
     3399+// Default is 1
     3400+//
     3401+// Recommended setting: 1 (wxFile is highly recommended as it is required by
     3402+// i18n code, wxFileConfig and others)
     3403+#define wxUSE_FILE          1
     3404+#define wxUSE_FFILE         1
     3405+
     3406+// Use wxFSVolume class providing access to the configured/active mount points
     3407+//
     3408+// Default is 1
     3409+//
     3410+// Recommended setting: 1 (but may be safely disabled if you don't use it)
     3411+#define wxUSE_FSVOLUME      1
     3412+
     3413+// Use wxStandardPaths class which allows to retrieve some standard locations
     3414+// in the file system
     3415+//
     3416+// Default is 1
     3417+//
     3418+// Recommended setting: 1 (may be disabled to save space, but not much)
     3419+#define wxUSE_STDPATHS      1
     3420+
     3421+// use wxTextBuffer class: required by wxTextFile
     3422+#define wxUSE_TEXTBUFFER    1
     3423+
     3424+// use wxTextFile class: requires wxFile and wxTextBuffer, required by
     3425+// wxFileConfig
     3426+#define wxUSE_TEXTFILE      1
     3427+
     3428+// i18n support: _() macro, wxLocale class. Requires wxTextFile.
     3429+#define wxUSE_INTL          1
     3430+
     3431+// Set wxUSE_DATETIME to 1 to compile the wxDateTime and related classes which
     3432+// allow to manipulate dates, times and time intervals. wxDateTime replaces the
     3433+// old wxTime and wxDate classes which are still provided for backwards
     3434+// compatibility (and implemented in terms of wxDateTime).
     3435+//
     3436+// Note that this class is relatively new and is still officially in alpha
     3437+// stage because some features are not yet (fully) implemented. It is already
     3438+// quite useful though and should only be disabled if you are aiming at
     3439+// absolutely minimal version of the library.
     3440+//
     3441+// Requires: wxUSE_LONGLONG
     3442+//
     3443+// Default is 1
     3444+//
     3445+// Recommended setting: 1
     3446+#define wxUSE_DATETIME      1
     3447+
     3448+// Set wxUSE_TIMER to 1 to compile wxTimer class
     3449+//
     3450+// Default is 1
     3451+//
     3452+// Recommended setting: 1
     3453+#define wxUSE_TIMER         1
     3454+
     3455+// Use wxStopWatch clas.
     3456+//
     3457+// Default is 1
     3458+//
     3459+// Recommended setting: 1 (needed by wxSocket)
     3460+#define wxUSE_STOPWATCH     1
     3461+
     3462+// Setting wxUSE_CONFIG to 1 enables the use of wxConfig and related classes
     3463+// which allow the application to store its settings in the persistent
     3464+// storage. Setting this to 1 will also enable on-demand creation of the
     3465+// global config object in wxApp.
     3466+//
     3467+// See also wxUSE_CONFIG_NATIVE below.
     3468+//
     3469+// Recommended setting: 1
     3470+#define wxUSE_CONFIG        1
     3471+
     3472+// If wxUSE_CONFIG is 1, you may choose to use either the native config
     3473+// classes under Windows (using .INI files under Win16 and the registry under
     3474+// Win32) or the portable text file format used by the config classes under
     3475+// Unix.
     3476+//
     3477+// Default is 1 to use native classes. Note that you may still use
     3478+// wxFileConfig even if you set this to 1 - just the config object created by
     3479+// default for the applications needs will be a wxRegConfig or wxIniConfig and
     3480+// not wxFileConfig.
     3481+//
     3482+// Recommended setting: 1
     3483+#define wxUSE_CONFIG_NATIVE   1
     3484+
     3485+// If wxUSE_DIALUP_MANAGER is 1, compile in wxDialUpManager class which allows
     3486+// to connect/disconnect from the network and be notified whenever the dial-up
     3487+// network connection is established/terminated. Requires wxUSE_DYNAMIC_LOADER.
     3488+//
     3489+// Default is 1.
     3490+//
     3491+// Recommended setting: 1
     3492+#define wxUSE_DIALUP_MANAGER   0
     3493+
     3494+// Compile in classes for run-time DLL loading and function calling.
     3495+// Required by wxUSE_DIALUP_MANAGER.
     3496+//
     3497+// This setting is for Win32 only
     3498+//
     3499+// Default is 1.
     3500+//
     3501+// Recommended setting: 1
     3502+#define wxUSE_DYNLIB_CLASS    1
     3503+
     3504+// experimental, don't use for now
     3505+#define wxUSE_DYNAMIC_LOADER  1
     3506+
     3507+// Set to 1 to use socket classes
     3508+#define wxUSE_SOCKETS       1
     3509+
     3510+// Set to 1 to enable virtual file systems (required by wxHTML)
     3511+#define wxUSE_FILESYSTEM    1
     3512+
     3513+// Set to 1 to enable virtual ZIP filesystem (requires wxUSE_FILESYSTEM)
     3514+#define wxUSE_FS_ZIP        1
     3515+
     3516+// Set to 1 to enable virtual archive filesystem (requires wxUSE_FILESYSTEM)
     3517+#define wxUSE_FS_ARCHIVE    1
     3518+
     3519+// Set to 1 to enable virtual Internet filesystem (requires wxUSE_FILESYSTEM)
     3520+#define wxUSE_FS_INET       1
     3521+
     3522+// wxArchive classes for accessing archives such as zip and tar
     3523+#define wxUSE_ARCHIVE_STREAMS     1
     3524+
     3525+// Set to 1 to compile wxZipInput/OutputStream classes.
     3526+#define wxUSE_ZIPSTREAM     1
     3527+
     3528+// Set to 1 to compile wxTarInput/OutputStream classes.
     3529+#define wxUSE_TARSTREAM     1
     3530+
     3531+// Set to 1 to compile wxZlibInput/OutputStream classes. Also required by
     3532+// wxUSE_LIBPNG
     3533+#define wxUSE_ZLIB          1
     3534+
     3535+// If enabled, the code written by Apple will be used to write, in a portable
     3536+// way, float on the disk. See extended.c for the license which is different
     3537+// from wxWidgets one.
     3538+//
     3539+// Default is 1.
     3540+//
     3541+// Recommended setting: 1 unless you don't like the license terms (unlikely)
     3542+#define wxUSE_APPLE_IEEE          1
     3543+
     3544+// Joystick support class
     3545+#define wxUSE_JOYSTICK            1
     3546+
     3547+// wxFontMapper class
     3548+#define wxUSE_FONTMAP 1
     3549+
     3550+// wxMimeTypesManager class
     3551+#define wxUSE_MIMETYPE 1
     3552+
     3553+// wxProtocol and related classes: if you want to use either of wxFTP, wxHTTP
     3554+// or wxURL you need to set this to 1.
     3555+//
     3556+// Default is 1.
     3557+//
     3558+// Recommended setting: 1
     3559+#define wxUSE_PROTOCOL 1
     3560+
     3561+// The settings for the individual URL schemes
     3562+#define wxUSE_PROTOCOL_FILE 1
     3563+#define wxUSE_PROTOCOL_FTP 1
     3564+#define wxUSE_PROTOCOL_HTTP 1
     3565+
     3566+// Define this to use wxURL class.
     3567+#define wxUSE_URL 1
     3568+
     3569+// Define this to use native platform url and protocol support.
     3570+// Currently valid only for MS-Windows.
     3571+// Note: if you set this to 1, you can open ftp/http/gopher sites
     3572+// and obtain a valid input stream for these sites
     3573+// even when you set wxUSE_PROTOCOL_FTP/HTTP to 0.
     3574+// Doing so reduces the code size.
     3575+//
     3576+// This code is experimental and subject to change.
     3577+#define wxUSE_URL_NATIVE 0
     3578+
     3579+// Support for wxVariant class used in several places throughout the library,
     3580+// notably in wxDataViewCtrl API.
     3581+//
     3582+// Default is 1.
     3583+//
     3584+// Recommended setting: 1 unless you want to reduce the library size as much as
     3585+// possible in which case setting this to 0 can gain up to 100KB.
     3586+#define wxUSE_VARIANT 1
     3587+
     3588+// Support for regular expression matching via wxRegEx class: enable this to
     3589+// use POSIX regular expressions in your code. You need to compile regex
     3590+// library from src/regex to use it under Windows.
     3591+//
     3592+// Default is 0
     3593+//
     3594+// Recommended setting: 1 if your compiler supports it, if it doesn't please
     3595+// contribute us a makefile for src/regex for it
     3596+#define wxUSE_REGEX       1
     3597+
     3598+// wxSystemOptions class
     3599+#define wxUSE_SYSTEM_OPTIONS 1
     3600+
     3601+// wxSound class
     3602+#define wxUSE_SOUND      1
     3603+
     3604+// Use wxMediaCtrl
     3605+//
     3606+// Default is 1.
     3607+//
     3608+// Recommended setting: 1
     3609+#define wxUSE_MEDIACTRL     1
     3610+
     3611+// Use GStreamer for Unix (req a lot of dependancies)
     3612+//
     3613+// Default is 0
     3614+//
     3615+// Recommended setting: 1 (wxMediaCtrl won't work by default without it)
     3616+#define wxUSE_GSTREAMER    0
     3617+
     3618+// Use wxWidget's XRC XML-based resource system.  Recommended.
     3619+//
     3620+// Default is 1
     3621+//
     3622+// Recommended setting: 1 (requires wxUSE_XML)
     3623+#define wxUSE_XRC       1
     3624+
     3625+// XML parsing classes. Note that their API will change in the future, so
     3626+// using wxXmlDocument and wxXmlNode in your app is not recommended.
     3627+//
     3628+// Default is the same as wxUSE_XRC, i.e. 1 by default.
     3629+//
     3630+// Recommended setting: 1 (required by XRC)
     3631+#define wxUSE_XML       wxUSE_XRC
     3632+
     3633+// Use wxWidget's AUI docking system
     3634+//
     3635+// Default is 1
     3636+//
     3637+// Recommended setting: 1
     3638+#define wxUSE_AUI       1
     3639+
     3640+
     3641+// Enable the new wxGraphicsPath and wxGraphicsContext classes for an advanced
     3642+// 2D drawing API.  (Still somewhat experimental)
     3643+//
     3644+// Please note that on Windows you will need to link with gdiplus.lib (use
     3645+// USE_GDIPLUS=1 for makefile builds) and distribute gdiplus.dll with your
     3646+// application if you want it to be runnable on pre-XP systems.
     3647+//
     3648+// Default is 0
     3649+//
     3650+// Recommended setting: 1
     3651+#ifndef wxUSE_GRAPHICS_CONTEXT
     3652+#define wxUSE_GRAPHICS_CONTEXT 1
     3653+#endif
     3654+
     3655+// ----------------------------------------------------------------------------
     3656+// Individual GUI controls
     3657+// ----------------------------------------------------------------------------
     3658+
     3659+// You must set wxUSE_CONTROLS to 1 if you are using any controls at all
     3660+// (without it, wxControl class is not compiled)
     3661+//
     3662+// Default is 1
     3663+//
     3664+// Recommended setting: 1 (don't change except for very special programs)
     3665+#define wxUSE_CONTROLS     1
     3666+
     3667+// wxPopupWindow class is a top level transient window. It is currently used
     3668+// to implement wxTipWindow
     3669+//
     3670+// Default is 1
     3671+//
     3672+// Recommended setting: 1 (may be set to 0 if you don't wxUSE_TIPWINDOW)
     3673+#define wxUSE_POPUPWIN     1
     3674+
     3675+// wxTipWindow allows to implement the custom tooltips, it is used by the
     3676+// context help classes. Requires wxUSE_POPUPWIN.
     3677+//
     3678+// Default is 1
     3679+//
     3680+// Recommended setting: 1 (may be set to 0)
     3681+#define wxUSE_TIPWINDOW    1
     3682+
     3683+// Each of the settings below corresponds to one wxWidgets control. They are
     3684+// all switched on by default but may be disabled if you are sure that your
     3685+// program (including any standard dialogs it can show!) doesn't need them and
     3686+// if you desperately want to save some space. If you use any of these you must
     3687+// set wxUSE_CONTROLS as well.
     3688+//
     3689+// Default is 1
     3690+//
     3691+// Recommended setting: 1
     3692+#define wxUSE_ANIMATIONCTRL 1   // wxAnimationCtrl
     3693+#define wxUSE_BUTTON        1   // wxButton
     3694+#define wxUSE_BMPBUTTON     1   // wxBitmapButton
     3695+#define wxUSE_CALENDARCTRL  1   // wxCalendarCtrl
     3696+#define wxUSE_CHECKBOX      1   // wxCheckBox
     3697+#define wxUSE_CHECKLISTBOX  1   // wxCheckListBox (requires wxUSE_OWNER_DRAWN)
     3698+#define wxUSE_CHOICE        1   // wxChoice
     3699+#define wxUSE_COLLPANE      1   // wxCollapsiblePane
     3700+#define wxUSE_COLOURPICKERCTRL 1    // wxColourPickerCtrl
     3701+#define wxUSE_COMBOBOX      1   // wxComboBox
     3702+#define wxUSE_DATAVIEWCTRL  1   // wxDataViewCtrl
     3703+#define wxUSE_DATEPICKCTRL  1   // wxDatePickerCtrl
     3704+#define wxUSE_DIRPICKERCTRL 1   // wxDirPickerCtrl
     3705+#define wxUSE_FILEPICKERCTRL 1  // wxFilePickerCtrl
     3706+#define wxUSE_FONTPICKERCTRL 1  // wxFontPickerCtrl
     3707+#define wxUSE_GAUGE         1   // wxGauge
     3708+#define wxUSE_HYPERLINKCTRL 1   // wxHyperlinkCtrl
     3709+#define wxUSE_LISTBOX       1   // wxListBox
     3710+#define wxUSE_LISTCTRL      1   // wxListCtrl
     3711+#define wxUSE_RADIOBOX      1   // wxRadioBox
     3712+#define wxUSE_RADIOBTN      1   // wxRadioButton
     3713+#define wxUSE_SCROLLBAR     1   // wxScrollBar
     3714+#define wxUSE_SEARCHCTRL    1   // wxSearchCtrl
     3715+#define wxUSE_SLIDER        1   // wxSlider
     3716+#define wxUSE_SPINBTN       1   // wxSpinButton
     3717+#define wxUSE_SPINCTRL      1   // wxSpinCtrl
     3718+#define wxUSE_STATBOX       1   // wxStaticBox
     3719+#define wxUSE_STATLINE      1   // wxStaticLine
     3720+#define wxUSE_STATTEXT      1   // wxStaticText
     3721+#define wxUSE_STATBMP       1   // wxStaticBitmap
     3722+#define wxUSE_TEXTCTRL      1   // wxTextCtrl
     3723+#define wxUSE_TOGGLEBTN     1   // requires wxButton
     3724+#define wxUSE_TREECTRL      1   // wxTreeCtrl
     3725+
     3726+// Use a status bar class? Depending on the value of wxUSE_NATIVE_STATUSBAR
     3727+// below either wxStatusBar95 or a generic wxStatusBar will be used.
     3728+//
     3729+// Default is 1
     3730+//
     3731+// Recommended setting: 1
     3732+#define wxUSE_STATUSBAR    1
     3733+
     3734+// Two status bar implementations are available under Win32: the generic one
     3735+// or the wrapper around native control. For native look and feel the native
     3736+// version should be used.
     3737+//
     3738+// Default is 1 for the platforms where native status bar is supported.
     3739+//
     3740+// Recommended setting: 1 (there is no advantage in using the generic one)
     3741+#define wxUSE_NATIVE_STATUSBAR        1
     3742+
     3743+// wxToolBar related settings: if wxUSE_TOOLBAR is 0, don't compile any toolbar
     3744+// classes at all. Otherwise, use the native toolbar class unless
     3745+// wxUSE_TOOLBAR_NATIVE is 0.
     3746+//
     3747+// Default is 1 for all settings.
     3748+//
     3749+// Recommended setting: 1 for wxUSE_TOOLBAR and wxUSE_TOOLBAR_NATIVE.
     3750+#define wxUSE_TOOLBAR 1
     3751+#define wxUSE_TOOLBAR_NATIVE 1
     3752+
     3753+// wxNotebook is a control with several "tabs" located on one of its sides. It
     3754+// may be used to logically organise the data presented to the user instead of
     3755+// putting everything in one huge dialog. It replaces wxTabControl and related
     3756+// classes of wxWin 1.6x.
     3757+//
     3758+// Default is 1.
     3759+//
     3760+// Recommended setting: 1
     3761+#define wxUSE_NOTEBOOK 1
     3762+
     3763+// wxListbook control is similar to wxNotebook but uses wxListCtrl instead of
     3764+// the tabs
     3765+//
     3766+// Default is 1.
     3767+//
     3768+// Recommended setting: 1
     3769+#define wxUSE_LISTBOOK 1
     3770+
     3771+// wxChoicebook control is similar to wxNotebook but uses wxChoice instead of
     3772+// the tabs
     3773+//
     3774+// Default is 1.
     3775+//
     3776+// Recommended setting: 1
     3777+#define wxUSE_CHOICEBOOK 1
     3778+
     3779+// wxTreebook control is similar to wxNotebook but uses wxTreeCtrl instead of
     3780+// the tabs
     3781+//
     3782+// Default is 1.
     3783+//
     3784+// Recommended setting: 1
     3785+#define wxUSE_TREEBOOK 1
     3786+
     3787+// wxToolbook control is similar to wxNotebook but uses wxToolBar instead of
     3788+// tabs
     3789+//
     3790+// Default is 1.
     3791+//
     3792+// Recommended setting: 1
     3793+#define wxUSE_TOOLBOOK 1
     3794+
     3795+// wxTabDialog is a generic version of wxNotebook but it is incompatible with
     3796+// the new class. It shouldn't be used in new code.
     3797+//
     3798+// Default is 0.
     3799+//
     3800+// Recommended setting: 0 (use wxNotebook)
     3801+#define wxUSE_TAB_DIALOG    0
     3802+
     3803+// wxGrid class
     3804+//
     3805+// Default is 1, set to 0 to cut down compilation time and binaries size if you
     3806+// don't use it.
     3807+//
     3808+// Recommended setting: 1
     3809+//
     3810+#define wxUSE_GRID         1
     3811+
     3812+// wxMiniFrame class: a frame with narrow title bar
     3813+//
     3814+// Default is 1.
     3815+//
     3816+// Recommended setting: 1 (it doesn't cost almost anything)
     3817+#define wxUSE_MINIFRAME 1
     3818+
     3819+// wxComboCtrl and related classes: combobox with custom popup window and
     3820+// not necessarily a listbox.
     3821+//
     3822+// Default is 1.
     3823+//
     3824+// Recommended setting: 1 but can be safely set to 0 except for wxUniv where it
     3825+//                      it used by wxComboBox
     3826+#define wxUSE_COMBOCTRL 1
     3827+
     3828+// wxOwnerDrawnComboBox is a custom combobox allowing to paint the combobox
     3829+// items.
     3830+//
     3831+// Default is 1.
     3832+//
     3833+// Recommended setting: 1 but can be safely set to 0, except where it is
     3834+//                      needed as a base class for generic wxBitmapComboBox.
     3835+#define wxUSE_ODCOMBOBOX 1
     3836+
     3837+// wxBitmapComboBox is a combobox that can have images in front of text items.
     3838+//
     3839+// Default is 1.
     3840+//
     3841+// Recommended setting: 1 but can be safely set to 0
     3842+#define wxUSE_BITMAPCOMBOBOX 1
     3843+
     3844+// ----------------------------------------------------------------------------
     3845+// Miscellaneous GUI stuff
     3846+// ----------------------------------------------------------------------------
     3847+
     3848+// wxAcceleratorTable/Entry classes and support for them in wxMenu(Bar)
     3849+#define wxUSE_ACCEL 1
     3850+
     3851+// Hotkey support (currently Windows only)
     3852+#define wxUSE_HOTKEY 1
     3853+
     3854+// Use wxCaret: a class implementing a "cursor" in a text control (called caret
     3855+// under Windows).
     3856+//
     3857+// Default is 1.
     3858+//
     3859+// Recommended setting: 1 (can be safely set to 0, not used by the library)
     3860+#define wxUSE_CARET         1
     3861+
     3862+// Use wxDisplay class: it allows enumerating all displays on a system and
     3863+// their geometries as well as finding the display on which the given point or
     3864+// window lies.
     3865+//
     3866+// Default is 1.
     3867+//
     3868+// Recommended setting: 1 if you need it, can be safely set to 0 otherwise
     3869+#define wxUSE_DISPLAY       1
     3870+
     3871+// Miscellaneous geometry code: needed for Canvas library
     3872+#define wxUSE_GEOMETRY            1
     3873+
     3874+// Use wxImageList. This class is needed by wxNotebook, wxTreeCtrl and
     3875+// wxListCtrl.
     3876+//
     3877+// Default is 1.
     3878+//
     3879+// Recommended setting: 1 (set it to 0 if you don't use any of the controls
     3880+// enumerated above, then this class is mostly useless too)
     3881+#define wxUSE_IMAGLIST      1
     3882+
     3883+// Use wxMenu, wxMenuBar, wxMenuItem.
     3884+//
     3885+// Default is 1.
     3886+//
     3887+// Recommended setting: 1 (can't be disabled under MSW)
     3888+#define wxUSE_MENUS         1
     3889+
     3890+// Use wxSashWindow class.
     3891+//
     3892+// Default is 1.
     3893+//
     3894+// Recommended setting: 1
     3895+#define wxUSE_SASH          1
     3896+
     3897+// Use wxSplitterWindow class.
     3898+//
     3899+// Default is 1.
     3900+//
     3901+// Recommended setting: 1
     3902+#define wxUSE_SPLITTER      1
     3903+
     3904+// Use wxToolTip and wxWindow::Set/GetToolTip() methods.
     3905+//
     3906+// Default is 1.
     3907+//
     3908+// Recommended setting: 1
     3909+#define wxUSE_TOOLTIPS      1
     3910+
     3911+// wxValidator class and related methods
     3912+#define wxUSE_VALIDATORS 1
     3913+
     3914+// ----------------------------------------------------------------------------
     3915+// common dialogs
     3916+// ----------------------------------------------------------------------------
     3917+
     3918+// On rare occasions (e.g. using DJGPP) may want to omit common dialogs (e.g.
     3919+// file selector, printer dialog). Switching this off also switches off the
     3920+// printing architecture and interactive wxPrinterDC.
     3921+//
     3922+// Default is 1
     3923+//
     3924+// Recommended setting: 1 (unless it really doesn't work)
     3925+#define wxUSE_COMMON_DIALOGS 1
     3926+
     3927+// wxBusyInfo displays window with message when app is busy. Works in same way
     3928+// as wxBusyCursor
     3929+#define wxUSE_BUSYINFO      1
     3930+
     3931+// Use single/multiple choice dialogs.
     3932+//
     3933+// Default is 1
     3934+//
     3935+// Recommended setting: 1 (used in the library itself)
     3936+#define wxUSE_CHOICEDLG     1
     3937+
     3938+// Use colour picker dialog
     3939+//
     3940+// Default is 1
     3941+//
     3942+// Recommended setting: 1
     3943+#define wxUSE_COLOURDLG     1
     3944+
     3945+// wxDirDlg class for getting a directory name from user
     3946+#define wxUSE_DIRDLG 1
     3947+
     3948+// TODO: setting to choose the generic or native one
     3949+
     3950+// Use file open/save dialogs.
     3951+//
     3952+// Default is 1
     3953+//
     3954+// Recommended setting: 1 (used in many places in the library itself)
     3955+#define wxUSE_FILEDLG       1
     3956+
     3957+// Use find/replace dialogs.
     3958+//
     3959+// Default is 1
     3960+//
     3961+// Recommended setting: 1 (but may be safely set to 0)
     3962+#define wxUSE_FINDREPLDLG       1
     3963+
     3964+// Use font picker dialog
     3965+//
     3966+// Default is 1
     3967+//
     3968+// Recommended setting: 1 (used in the library itself)
     3969+#define wxUSE_FONTDLG       1
     3970+
     3971+// Use wxMessageDialog and wxMessageBox.
     3972+//
     3973+// Default is 1
     3974+//
     3975+// Recommended setting: 1 (used in the library itself)
     3976+#define wxUSE_MSGDLG        1
     3977+
     3978+// progress dialog class for lengthy operations
     3979+#define wxUSE_PROGRESSDLG 1
     3980+
     3981+// support for startup tips (wxShowTip &c)
     3982+#define wxUSE_STARTUP_TIPS 1
     3983+
     3984+// text entry dialog and wxGetTextFromUser function
     3985+#define wxUSE_TEXTDLG 1
     3986+
     3987+// number entry dialog
     3988+#define wxUSE_NUMBERDLG 1
     3989+
     3990+// splash screen class
     3991+#define wxUSE_SPLASH 1
     3992+
     3993+// wizards
     3994+#define wxUSE_WIZARDDLG 1
     3995+
     3996+// Compile in wxAboutBox() function showing the standard "About" dialog.
     3997+//
     3998+// Default is 1
     3999+//
     4000+// Recommended setting: 1 but can be set to 0 to save some space if you don't
     4001+//                      use this function
     4002+#define wxUSE_ABOUTDLG 1
     4003+
     4004+// ----------------------------------------------------------------------------
     4005+// Metafiles support
     4006+// ----------------------------------------------------------------------------
     4007+
     4008+// Windows supports the graphics format known as metafile which is, though not
     4009+// portable, is widely used under Windows and so is supported by wxWin (under
     4010+// Windows only, of course). Win16 (Win3.1) used the so-called "Window
     4011+// MetaFiles" or WMFs which were replaced with "Enhanced MetaFiles" or EMFs in
     4012+// Win32 (Win9x, NT, 2000). Both of these are supported in wxWin and, by
     4013+// default, WMFs will be used under Win16 and EMFs under Win32. This may be
     4014+// changed by setting wxUSE_WIN_METAFILES_ALWAYS to 1 and/or setting
     4015+// wxUSE_ENH_METAFILE to 0. You may also set wxUSE_METAFILE to 0 to not compile
     4016+// in any metafile related classes at all.
     4017+//
     4018+// Default is 1 for wxUSE_ENH_METAFILE and 0 for wxUSE_WIN_METAFILES_ALWAYS.
     4019+//
     4020+// Recommended setting: default or 0 for everything for portable programs.
     4021+#define wxUSE_METAFILE              1
     4022+#define wxUSE_ENH_METAFILE          1
     4023+#define wxUSE_WIN_METAFILES_ALWAYS  0
     4024+
     4025+// ----------------------------------------------------------------------------
     4026+// Big GUI components
     4027+// ----------------------------------------------------------------------------
     4028+
     4029+// Set to 0 to disable MDI support.
     4030+//
     4031+// Requires wxUSE_NOTEBOOK under platforms other than MSW.
     4032+//
     4033+// Default is 1.
     4034+//
     4035+// Recommended setting: 1, can be safely set to 0.
     4036+#define wxUSE_MDI 1
     4037+
     4038+// Set to 0 to disable document/view architecture
     4039+#define wxUSE_DOC_VIEW_ARCHITECTURE 1
     4040+
     4041+// Set to 0 to disable MDI document/view architecture
     4042+//
     4043+// Requires wxUSE_MDI && wxUSE_DOC_VIEW_ARCHITECTURE
     4044+#define wxUSE_MDI_ARCHITECTURE    1
     4045+
     4046+// Set to 0 to disable print/preview architecture code
     4047+#define wxUSE_PRINTING_ARCHITECTURE  1
     4048+
     4049+// wxHTML sublibrary allows to display HTML in wxWindow programs and much,
     4050+// much more.
     4051+//
     4052+// Default is 1.
     4053+//
     4054+// Recommended setting: 1 (wxHTML is great!), set to 0 if you want compile a
     4055+// smaller library.
     4056+#define wxUSE_HTML          1
     4057+
     4058+// Setting wxUSE_GLCANVAS to 1 enables OpenGL support. You need to have OpenGL
     4059+// headers and libraries to be able to compile the library with wxUSE_GLCANVAS
     4060+// set to 1. Note that for some compilers (notably Microsoft Visual C++) you
     4061+// will need to manually add opengl32.lib and glu32.lib to the list of
     4062+// libraries linked with your program if you use OpenGL.
     4063+//
     4064+// Default is 0.
     4065+//
     4066+// Recommended setting: 1 if you intend to use OpenGL, 0 otherwise
     4067+#define wxUSE_GLCANVAS       1
     4068+
     4069+// wxRichTextCtrl allows editing of styled text.
     4070+//
     4071+// Default is 1.
     4072+//
     4073+// Recommended setting: 1, set to 0 if you want compile a
     4074+// smaller library.
     4075+#define wxUSE_RICHTEXT       1
     4076+
     4077+// ----------------------------------------------------------------------------
     4078+// Data transfer
     4079+// ----------------------------------------------------------------------------
     4080+
     4081+// Use wxClipboard class for clipboard copy/paste.
     4082+//
     4083+// Default is 1.
     4084+//
     4085+// Recommended setting: 1
     4086+#define wxUSE_CLIPBOARD     1
     4087+
     4088+// Use wxDataObject and related classes. Needed for clipboard and OLE drag and
     4089+// drop
     4090+//
     4091+// Default is 1.
     4092+//
     4093+// Recommended setting: 1
     4094+#define wxUSE_DATAOBJ       1
     4095+
     4096+// Use wxDropTarget and wxDropSource classes for drag and drop (this is
     4097+// different from "built in" drag and drop in wxTreeCtrl which is always
     4098+// available). Requires wxUSE_DATAOBJ.
     4099+//
     4100+// Default is 1.
     4101+//
     4102+// Recommended setting: 1
     4103+#define wxUSE_DRAG_AND_DROP 1
     4104+
     4105+// Use wxAccessible for enhanced and customisable accessibility.
     4106+// Depends on wxUSE_OLE.
     4107+//
     4108+// Default is 0.
     4109+//
     4110+// Recommended setting (at present): 0
     4111+#define wxUSE_ACCESSIBILITY 0
     4112+
     4113+// ----------------------------------------------------------------------------
     4114+// miscellaneous settings
     4115+// ----------------------------------------------------------------------------
     4116+
     4117+// wxSingleInstanceChecker class allows to verify at startup if another program
     4118+// instance is running.
     4119+//
     4120+// Default is 1
     4121+//
     4122+// Recommended setting: 1 (the class is tiny, disabling it won't save much
     4123+// space)
     4124+#define wxUSE_SNGLINST_CHECKER  1
     4125+
     4126+#define wxUSE_DRAGIMAGE 1
     4127+
     4128+#define wxUSE_IPC         1
     4129+                                // 0 for no interprocess comms
     4130+#define wxUSE_HELP        1
     4131+                                // 0 for no help facility
     4132+
     4133+// Should we use MS HTML help for wxHelpController? If disabled, neither
     4134+// wxCHMHelpController nor wxBestHelpController are available.
     4135+//
     4136+// Default is 1 under MSW, 0 is always used for the other platforms.
     4137+//
     4138+// Recommended setting: 1, only set to 0 if you have trouble compiling
     4139+// wxCHMHelpController (could be a problem with really ancient compilers)
     4140+#define wxUSE_MS_HTML_HELP 1
     4141+
     4142+
     4143+// Use wxHTML-based help controller?
     4144+#define wxUSE_WXHTML_HELP 1
     4145+
     4146+#define wxUSE_RESOURCES   0
     4147+                                // 0 for no wxGetResource/wxWriteResource
     4148+#define wxUSE_CONSTRAINTS 1
     4149+                                // 0 for no window layout constraint system
     4150+
     4151+#define wxUSE_SPLINES     1
     4152+                                // 0 for no splines
     4153+
     4154+#define wxUSE_MOUSEWHEEL        1
     4155+                                // Include mouse wheel support
     4156+
     4157+// ----------------------------------------------------------------------------
     4158+// postscript support settings
     4159+// ----------------------------------------------------------------------------
     4160+
     4161+// Set to 1 for PostScript device context.
     4162+#define wxUSE_POSTSCRIPT  1
     4163+
     4164+// Set to 1 to use font metric files in GetTextExtent
     4165+#define wxUSE_AFM_FOR_POSTSCRIPT 1
     4166+
     4167+// ----------------------------------------------------------------------------
     4168+// database classes
     4169+// ----------------------------------------------------------------------------
     4170+
     4171+// Define 1 to use ODBC classes
     4172+#define wxUSE_ODBC          0
     4173+
     4174+// For backward compatibility reasons, this parameter now only controls the
     4175+// default scrolling method used by cursors.  This default behavior can be
     4176+// overriden by setting the second param of wxDB::wxDbGetConnection() or
     4177+// wxDb() constructor to indicate whether the connection (and any wxDbTable()s
     4178+// that use the connection) should support forward only scrolling of cursors,
     4179+// or both forward and backward support for backward scrolling cursors is
     4180+// dependent on the data source as well as the ODBC driver being used.
     4181+#define wxODBC_FWD_ONLY_CURSORS         1
     4182+
     4183+// Default is 0.  Set to 1 to use the deprecated classes, enum types, function,
     4184+// member variables.  With a setting of 1, full backward compatibility with the
     4185+// 2.0.x release is possible. It is STRONGLY recommended that this be set to 0,
     4186+// as future development will be done only on the non-deprecated
     4187+// functions/classes/member variables/etc.
     4188+#define wxODBC_BACKWARD_COMPATABILITY 0
     4189+
     4190+// ----------------------------------------------------------------------------
     4191+// other compiler (mis)features
     4192+// ----------------------------------------------------------------------------
     4193+
     4194+// Set this to 0 if your compiler can't cope with omission of prototype
     4195+// parameters.
     4196+//
     4197+// Default is 1.
     4198+//
     4199+// Recommended setting: 1 (should never need to set this to 0)
     4200+#define REMOVE_UNUSED_ARG   1
     4201+
     4202+// VC++ 4.2 and above allows <iostream> and <iostream.h> but you can't mix
     4203+// them. Set to 1 for <iostream.h>, 0 for <iostream>. Note that VC++ 7.1
     4204+// and later doesn't support wxUSE_IOSTREAMH == 1 and so <iostream> will be
     4205+// used anyhow.
     4206+//
     4207+// Default is 1.
     4208+//
     4209+// Recommended setting: whatever your compiler likes more
     4210+#define wxUSE_IOSTREAMH     1
     4211+
     4212+// ----------------------------------------------------------------------------
     4213+// image format support
     4214+// ----------------------------------------------------------------------------
     4215+
     4216+// wxImage supports many different image formats which can be configured at
     4217+// compile-time. BMP is always supported, others are optional and can be safely
     4218+// disabled if you don't plan to use images in such format sometimes saving
     4219+// substantial amount of code in the final library.
     4220+//
     4221+// Some formats require an extra library which is included in wxWin sources
     4222+// which is mentioned if it is the case.
     4223+
     4224+// Set to 1 for wxImage support (recommended).
     4225+#define wxUSE_IMAGE         1
     4226+
     4227+// Set to 1 for PNG format support (requires libpng). Also requires wxUSE_ZLIB.
     4228+#define wxUSE_LIBPNG        1
     4229+
     4230+// Set to 1 for JPEG format support (requires libjpeg)
     4231+#define wxUSE_LIBJPEG       1
     4232+
     4233+// Set to 1 for TIFF format support (requires libtiff)
     4234+#define wxUSE_LIBTIFF       1
     4235+
     4236+// Set to 1 for TGA format support (loading only)
     4237+#define wxUSE_TGA           1
     4238+
     4239+// Set to 1 for GIF format support
     4240+#define wxUSE_GIF           1
     4241+
     4242+// Set to 1 for PNM format support
     4243+#define wxUSE_PNM           1
     4244+
     4245+// Set to 1 for PCX format support
     4246+#define wxUSE_PCX           1
     4247+
     4248+// Set to 1 for IFF format support (Amiga format)
     4249+#define wxUSE_IFF           0
     4250+
     4251+// Set to 1 for XPM format support
     4252+#define wxUSE_XPM           1
     4253+
     4254+// Set to 1 for MS Icons and Cursors format support
     4255+#define wxUSE_ICO_CUR       1
     4256+
     4257+// Set to 1 to compile in wxPalette class
     4258+#define wxUSE_PALETTE       1
     4259+
     4260+// ----------------------------------------------------------------------------
     4261+// wxUniversal-only options
     4262+// ----------------------------------------------------------------------------
     4263+
     4264+// Set to 1 to enable compilation of all themes, this is the default
     4265+#define wxUSE_ALL_THEMES    1
     4266+
     4267+// Set to 1 to enable the compilation of individual theme if wxUSE_ALL_THEMES
     4268+// is unset, if it is set these options are not used; notice that metal theme
     4269+// uses Win32 one
     4270+#define wxUSE_THEME_GTK     0
     4271+#define wxUSE_THEME_METAL   0
     4272+#define wxUSE_THEME_MONO    0
     4273+#define wxUSE_THEME_WIN32   0
     4274+
     4275+
     4276+/* --- end common options --- */
     4277+
     4278+// ----------------------------------------------------------------------------
     4279+// Windows-only settings
     4280+// ----------------------------------------------------------------------------
     4281+
     4282+// Set wxUSE_UNICODE_MSLU to 1 if you're compiling wxWidgets in Unicode mode
     4283+// and want to run your programs under Windows 9x and not only NT/2000/XP.
     4284+// This setting enables use of unicows.dll from MSLU (MS Layer for Unicode, see
     4285+// http://www.microsoft.com/globaldev/handson/dev/mslu_announce.mspx). Note
     4286+// that you will have to modify the makefiles to include unicows.lib import
     4287+// library as the first library (see installation instructions in install.txt
     4288+// to learn how to do it when building the library or samples).
     4289+//
     4290+// If your compiler doesn't have unicows.lib, you can get a version of it at
     4291+// http://libunicows.sourceforge.net
     4292+//
     4293+// Default is 0
     4294+//
     4295+// Recommended setting: 0 (1 if you want to deploy Unicode apps on 9x systems)
     4296+#ifndef wxUSE_UNICODE_MSLU
     4297+    #define wxUSE_UNICODE_MSLU 1
     4298+#endif
     4299+
     4300+// Set this to 1 if you want to use wxWidgets and MFC in the same program. This
     4301+// will override some other settings (see below)
     4302+//
     4303+// Default is 0.
     4304+//
     4305+// Recommended setting: 0 unless you really have to use MFC
     4306+#define wxUSE_MFC           0
     4307+
     4308+// Set this to 1 for generic OLE support: this is required for drag-and-drop,
     4309+// clipboard, OLE Automation. Only set it to 0 if your compiler is very old and
     4310+// can't compile/doesn't have the OLE headers.
     4311+//
     4312+// Default is 1.
     4313+//
     4314+// Recommended setting: 1
     4315+#define wxUSE_OLE           1
     4316+
     4317+// Set this to 1 to enable wxAutomationObject class.
     4318+//
     4319+// Default is 1.
     4320+//
     4321+// Recommended setting: 1 if you need to control other applications via OLE
     4322+// Automation, can be safely set to 0 otherwise
     4323+#define wxUSE_OLE_AUTOMATION 1
     4324+
     4325+// Set this to 1 to enable wxActiveXContainer class allowing to embed OLE
     4326+// controls in wx.
     4327+//
     4328+// Default is 1.
     4329+//
     4330+// Recommended setting: 1, required by wxMediaCtrl
     4331+#define wxUSE_ACTIVEX 1
     4332+
     4333+// wxDC cacheing implementation
     4334+#define wxUSE_DC_CACHEING 1
     4335+
     4336+// Set this to 1 to enable the use of DIB's for wxBitmap to support
     4337+// bitmaps > 16MB on Win95/98/Me.  Set to 0 to use DDB's only.
     4338+#define wxUSE_DIB_FOR_BITMAP 1
     4339+
     4340+// Set this to 1 to enable wxDIB class used internally for manipulating
     4341+// wxBitmao data.
     4342+//
     4343+// Default is 1, set it to 0 only if you don't use wxImage neither
     4344+//
     4345+// Recommended setting: 1 (without it conversion to/from wxImage won't work)
     4346+#define wxUSE_WXDIB 1
     4347+
     4348+// Set to 0 to disable PostScript print/preview architecture code under Windows
     4349+// (just use Windows printing).
     4350+#define wxUSE_POSTSCRIPT_ARCHITECTURE_IN_MSW 1
     4351+
     4352+// Set this to 1 to use RICHEDIT controls for wxTextCtrl with style wxTE_RICH
     4353+// which allows to put more than ~32Kb of text in it even under Win9x (NT
     4354+// doesn't have such limitation).
     4355+//
     4356+// Default is 1 for compilers which support it
     4357+//
     4358+// Recommended setting: 1, only set it to 0 if your compiler doesn't have
     4359+//                      or can't compile <richedit.h>
     4360+#define wxUSE_RICHEDIT  1
     4361+
     4362+// Set this to 1 to use extra features of richedit v2 and later controls
     4363+//
     4364+// Default is 1 for compilers which support it
     4365+//
     4366+// Recommended setting: 1
     4367+#define wxUSE_RICHEDIT2 1
     4368+
     4369+// Set this to 1 to enable support for the owner-drawn menu and listboxes. This
     4370+// is required by wxUSE_CHECKLISTBOX.
     4371+//
     4372+// Default is 1.
     4373+//
     4374+// Recommended setting: 1, set to 0 for a small library size reduction
     4375+#define wxUSE_OWNER_DRAWN 1
     4376+
     4377+// Set to 1 to compile MS Windows XP theme engine support
     4378+#define wxUSE_UXTHEME           1
     4379+
     4380+// Set to 1 to auto-adapt to MS Windows XP themes where possible
     4381+// (notably, wxNotebook pages)
     4382+#define wxUSE_UXTHEME_AUTO      1
     4383+
     4384+// Set to 1 to use InkEdit control (Tablet PC), if available
     4385+#define wxUSE_INKEDIT  0
     4386+
     4387+// ----------------------------------------------------------------------------
     4388+// Generic versions of native controls
     4389+// ----------------------------------------------------------------------------
     4390+
     4391+// Set this to 1 to be able to use wxDatePickerCtrlGeneric in addition to the
     4392+// native wxDatePickerCtrl
     4393+//
     4394+// Default is 0.
     4395+//
     4396+// Recommended setting: 0, this is mainly used for testing
     4397+#define wxUSE_DATEPICKCTRL_GENERIC 1
     4398+
     4399+// ----------------------------------------------------------------------------
     4400+// Crash debugging helpers
     4401+// ----------------------------------------------------------------------------
     4402+
     4403+// Set this to 1 to be able to use wxCrashReport::Generate() to create mini
     4404+// dumps of your program when it crashes (or at any other moment)
     4405+//
     4406+// Default is 1 if supported by the compiler (VC++ and recent BC++ only).
     4407+//
     4408+// Recommended setting: 1, set to 0 if your programs never crash
     4409+#define wxUSE_CRASHREPORT 1
     4410+
     4411+// ----------------------------------------------------------------------------
     4412+// obsolete settings
     4413+// ----------------------------------------------------------------------------
     4414+
     4415+// NB: all settings in this section are obsolete and should not be used/changed
     4416+//     at all, they will disappear
     4417+
     4418+// Define 1 to use bitmap messages.
     4419+#define wxUSE_BITMAP_MESSAGE         1
     4420+
     4421+#endif // _WX_SETUP_H_
     4422+
     4423diff '--exclude-from=wxPython-src-2.8.9.1/exclude' -Nur orig/wxPython-src-2.8.9.1//lib/vc_dll/mswud/wx/setup.h wxPython-src-2.8.9.1//lib/vc_dll/mswud/wx/setup.h
     4424--- orig/wxPython-src-2.8.9.1//lib/vc_dll/mswud/wx/setup.h      1970-01-01 01:00:00.000000000 +0100
     4425+++ wxPython-src-2.8.9.1//lib/vc_dll/mswud/wx/setup.h   2009-01-30 18:59:12.000000000 +0100
     4426@@ -0,0 +1,1349 @@
     4427+/////////////////////////////////////////////////////////////////////////////
     4428+// Name:        wx/msw/setup.h
     4429+// Purpose:     Configuration for the library
     4430+// Author:      Julian Smart
     4431+// Modified by:
     4432+// Created:     01/02/97
     4433+// RCS-ID:      $Id: setup0.h 51451 2008-01-29 23:11:55Z VZ $
     4434+// Copyright:   (c) Julian Smart
     4435+// Licence:     wxWindows licence
     4436+/////////////////////////////////////////////////////////////////////////////
     4437+
     4438+#ifndef _WX_SETUP_H_
     4439+#define _WX_SETUP_H_
     4440+
     4441+/* --- start common options --- */
     4442+// ----------------------------------------------------------------------------
     4443+// global settings
     4444+// ----------------------------------------------------------------------------
     4445+
     4446+// define this to 0 when building wxBase library - this can also be done from
     4447+// makefile/project file overriding the value here
     4448+#ifndef wxUSE_GUI
     4449+    #define wxUSE_GUI            1
     4450+#endif // wxUSE_GUI
     4451+
     4452+// ----------------------------------------------------------------------------
     4453+// compatibility settings
     4454+// ----------------------------------------------------------------------------
     4455+
     4456+// This setting determines the compatibility with 2.4 API: set it to 1 to
     4457+// enable it but please consider updating your code instead.
     4458+//
     4459+// Default is 0
     4460+//
     4461+// Recommended setting: 0 (please update your code)
     4462+#define WXWIN_COMPATIBILITY_2_4 0
     4463+
     4464+// This setting determines the compatibility with 2.6 API: set it to 0 to
     4465+// flag all cases of using deprecated functions.
     4466+//
     4467+// Default is 1 but please try building your code with 0 as the default will
     4468+// change to 0 in the next version and the deprecated functions will disappear
     4469+// in the version after it completely.
     4470+//
     4471+// Recommended setting: 0 (please update your code)
     4472+#define WXWIN_COMPATIBILITY_2_6 1
     4473+
     4474+// MSW-only: Set to 0 for accurate dialog units, else 1 for old behaviour when
     4475+// default system font is used for wxWindow::GetCharWidth/Height() instead of
     4476+// the current font.
     4477+//
     4478+// Default is 0
     4479+//
     4480+// Recommended setting: 0
     4481+#define wxDIALOG_UNIT_COMPATIBILITY   0
     4482+
     4483+// ----------------------------------------------------------------------------
     4484+// debugging settings
     4485+// ----------------------------------------------------------------------------
     4486+
     4487+// Generic comment about debugging settings: they are very useful if you don't
     4488+// use any other memory leak detection tools such as Purify/BoundsChecker, but
     4489+// are probably redundant otherwise. Also, Visual C++ CRT has the same features
     4490+// as wxWidgets memory debugging subsystem built in since version 5.0 and you
     4491+// may prefer to use it instead of built in memory debugging code because it is
     4492+// faster and more fool proof.
     4493+//
     4494+// Using VC++ CRT memory debugging is enabled by default in debug mode
     4495+// (__WXDEBUG__) if wxUSE_GLOBAL_MEMORY_OPERATORS is *not* enabled (i.e. is 0)
     4496+// and if __NO_VC_CRTDBG__ is not defined.
     4497+
     4498+// If 1, enables wxDebugContext, for writing error messages to file, etc. If
     4499+// __WXDEBUG__ is not defined, will still use the normal memory operators.
     4500+//
     4501+// Default is 0
     4502+//
     4503+// Recommended setting: 0
     4504+#define wxUSE_DEBUG_CONTEXT 0
     4505+
     4506+// If 1, enables debugging versions of wxObject::new and wxObject::delete *IF*
     4507+// __WXDEBUG__ is also defined.
     4508+//
     4509+// WARNING: this code may not work with all architectures, especially if
     4510+// alignment is an issue. This switch is currently ignored for mingw / cygwin
     4511+//
     4512+// Default is 0
     4513+//
     4514+// Recommended setting: 1 if you are not using a memory debugging tool, else 0
     4515+#define wxUSE_MEMORY_TRACING 0
     4516+
     4517+// In debug mode, cause new and delete to be redefined globally.
     4518+// If this causes problems (e.g. link errors which is a common problem
     4519+// especially if you use another library which also redefines the global new
     4520+// and delete), set this to 0.
     4521+// This switch is currently ignored for mingw / cygwin
     4522+//
     4523+// Default is 0
     4524+//
     4525+// Recommended setting: 0
     4526+#define wxUSE_GLOBAL_MEMORY_OPERATORS 0
     4527+
     4528+// In debug mode, causes new to be defined to be WXDEBUG_NEW (see object.h). If
     4529+// this causes problems (e.g. link errors), set this to 0. You may need to set
     4530+// this to 0 if using templates (at least for VC++). This switch is currently
     4531+// ignored for mingw / cygwin / CodeWarrior
     4532+//
     4533+// Default is 0
     4534+//
     4535+// Recommended setting: 0
     4536+#define wxUSE_DEBUG_NEW_ALWAYS 0
     4537+
     4538+// wxHandleFatalExceptions() may be used to catch the program faults at run
     4539+// time and, instead of terminating the program with a usual GPF message box,
     4540+// call the user-defined wxApp::OnFatalException() function. If you set
     4541+// wxUSE_ON_FATAL_EXCEPTION to 0, wxHandleFatalExceptions() will not work.
     4542+//
     4543+// This setting is for Win32 only and can only be enabled if your compiler
     4544+// supports Win32 structured exception handling (currently only VC++ does)
     4545+//
     4546+// Default is 1
     4547+//
     4548+// Recommended setting: 1 if your compiler supports it.
     4549+#define wxUSE_ON_FATAL_EXCEPTION 1
     4550+
     4551+// Set this to 1 to be able to generate a human-readable (unlike
     4552+// machine-readable minidump created by wxCrashReport::Generate()) stack back
     4553+// trace when your program crashes using wxStackWalker
     4554+//
     4555+// Default is 1 if supported by the compiler.
     4556+//
     4557+// Recommended setting: 1, set to 0 if your programs never crash
     4558+#define wxUSE_STACKWALKER 1
     4559+
     4560+// Set this to 1 to compile in wxDebugReport class which allows you to create
     4561+// and optionally upload to your web site a debug report consisting of back
     4562+// trace of the crash (if wxUSE_STACKWALKER == 1) and other information.
     4563+//
     4564+// Default is 1 if supported by the compiler.
     4565+//
     4566+// Recommended setting: 1, it is compiled into a separate library so there
     4567+//                         is no overhead if you don't use it
     4568+#define wxUSE_DEBUGREPORT 0
     4569+
     4570+// ----------------------------------------------------------------------------
     4571+// Unicode support
     4572+// ----------------------------------------------------------------------------
     4573+
     4574+// Set wxUSE_UNICODE to 1 to compile wxWidgets in Unicode mode: wxChar will be
     4575+// defined as wchar_t, wxString will use Unicode internally. If you set this
     4576+// to 1, you must use wxT() macro for all literal strings in the program.
     4577+//
     4578+// Unicode is currently only fully supported under Windows NT/2000/XP
     4579+// (Windows 9x doesn't support it and the programs compiled in Unicode mode
     4580+// will not run under 9x -- but see wxUSE_UNICODE_MSLU below).
     4581+//
     4582+// Default is 0
     4583+//
     4584+// Recommended setting: 0 (unless you only plan to use Windows NT/2000/XP)
     4585+#ifndef wxUSE_UNICODE
     4586+    #define wxUSE_UNICODE 1
     4587+#endif
     4588+
     4589+// Setting wxUSE_WCHAR_T to 1 gives you some degree of Unicode support without
     4590+// compiling the program in Unicode mode. More precisely, it will be possible
     4591+// to construct wxString from a wide (Unicode) string and convert any wxString
     4592+// to Unicode.
     4593+//
     4594+// Default is 1
     4595+//
     4596+// Recommended setting: 1
     4597+#define wxUSE_WCHAR_T 1
     4598+
     4599+// ----------------------------------------------------------------------------
     4600+// global features
     4601+// ----------------------------------------------------------------------------
     4602+
     4603+// Compile library in exception-safe mode? If set to 1, the library will try to
     4604+// behave correctly in presence of exceptions (even though it still will not
     4605+// use the exceptions itself) and notify the user code about any unhandled
     4606+// exceptions. If set to 0, propagation of the exceptions through the library
     4607+// code will lead to undefined behaviour -- but the code itself will be
     4608+// slightly smaller and faster.
     4609+//
     4610+// Note that like wxUSE_THREADS this option is automatically set to 0 if
     4611+// wxNO_EXCEPTIONS is defined.
     4612+//
     4613+// Default is 1
     4614+//
     4615+// Recommended setting: depends on whether you intend to use C++ exceptions
     4616+//                      in your own code (1 if you do, 0 if you don't)
     4617+#define wxUSE_EXCEPTIONS    0
     4618+
     4619+// Set wxUSE_EXTENDED_RTTI to 1 to use extended RTTI
     4620+//
     4621+// Default is 0
     4622+//
     4623+// Recommended setting: 0 (this is still work in progress...)
     4624+#define wxUSE_EXTENDED_RTTI 0
     4625+
     4626+// Set wxUSE_STL to 1 to derive wxList(Foo) and wxArray(Foo) from
     4627+// std::list<Foo*> and std::vector<Foo*>, with a compatibility interface,
     4628+// and for wxHashMap to be implemented with templates.
     4629+//
     4630+// Default is 0
     4631+//
     4632+// Recommended setting: YMMV
     4633+#define wxUSE_STL 0
     4634+
     4635+// Support for message/error logging. This includes wxLogXXX() functions and
     4636+// wxLog and derived classes. Don't set this to 0 unless you really know what
     4637+// you are doing.
     4638+//
     4639+// Default is 1
     4640+//
     4641+// Recommended setting: 1 (always)
     4642+#define wxUSE_LOG 1
     4643+
     4644+// Recommended setting: 1
     4645+#define wxUSE_LOGWINDOW 1
     4646+
     4647+// Recommended setting: 1
     4648+#define wxUSE_LOGGUI 1
     4649+
     4650+// Recommended setting: 1
     4651+#define wxUSE_LOG_DIALOG 1
     4652+
     4653+// Support for command line parsing using wxCmdLineParser class.
     4654+//
     4655+// Default is 1
     4656+//
     4657+// Recommended setting: 1 (can be set to 0 if you don't use the cmd line)
     4658+#define wxUSE_CMDLINE_PARSER 1
     4659+
     4660+// Support for multithreaded applications: if 1, compile in thread classes
     4661+// (thread.h) and make the library a bit more thread safe. Although thread
     4662+// support is quite stable by now, you may still consider recompiling the
     4663+// library without it if you have no use for it - this will result in a
     4664+// somewhat smaller and faster operation.
     4665+//
     4666+// Notice that if wxNO_THREADS is defined, wxUSE_THREADS is automatically reset
     4667+// to 0 in wx/chkconf.h, so, for example, if you set USE_THREADS to 0 in
     4668+// build/msw/config.* file this value will have no effect.
     4669+//
     4670+// Default is 1
     4671+//
     4672+// Recommended setting: 0 unless you do plan to develop MT applications
     4673+#define wxUSE_THREADS 1
     4674+
     4675+// If enabled, compiles wxWidgets streams classes
     4676+//
     4677+// wx stream classes are used for image IO, process IO redirection, network
     4678+// protocols implementation and much more and so disabling this results in a
     4679+// lot of other functionality being lost.
     4680+//
     4681+// Default is 1
     4682+//
     4683+// Recommended setting: 1 as setting it to 0 disables many other things
     4684+#define wxUSE_STREAMS       1
     4685+
     4686+// Use standard C++ streams if 1 instead of wx streams in some places. If
     4687+// disabled (default), wx streams are used everywhere and wxWidgets doesn't
     4688+// depend on the standard streams library.
     4689+//
     4690+// Notice that enabling this does not replace wx streams with std streams
     4691+// everywhere, in a lot of places wx streams are used no matter what.
     4692+//
     4693+// Default is 0
     4694+//
     4695+// Recommended setting: 1 if you use the standard streams anyhow and so
     4696+//                      dependency on the standard streams library is not a
     4697+//                      problem
     4698+#define wxUSE_STD_IOSTREAM  0
     4699+
     4700+// Enable conversion to standard C++ string if 1.
     4701+//
     4702+// Default is 1 for most compilers.
     4703+//
     4704+// Currently the Digital Mars and Watcom compilers come without standard C++
     4705+// library headers by default, wxUSE_STD_STRING can be set to 1 if you do have
     4706+// them (e.g. from STLPort).
     4707+//
     4708+// VC++ 5.0 does include standard C++ library header, however they produce
     4709+// many warnings that can't be turned off when compiled at warning level 4.
     4710+#if defined(__DMC__) || defined(__WATCOMC__) \
     4711+        || (defined(_MSC_VER) && _MSC_VER < 1200)
     4712+    #define wxUSE_STD_STRING  0
     4713+#else
     4714+    #define wxUSE_STD_STRING  1
     4715+#endif
     4716+
     4717+// Support for positional parameters (e.g. %1$d, %2$s ...) in wxVsnprintf.
     4718+// Note that if the system's implementation does not support positional
     4719+// parameters, setting this to 1 forces the use of the wxWidgets implementation
     4720+// of wxVsnprintf. The standard vsnprintf() supports positional parameters on
     4721+// many Unix systems but usually doesn't under Windows.
     4722+//
     4723+// Positional parameters are very useful when translating a program since using
     4724+// them in formatting strings allow translators to correctly reorder the
     4725+// translated sentences.
     4726+//
     4727+// Default is 1
     4728+//
     4729+// Recommended setting: 1 if you want to support multiple languages
     4730+#define wxUSE_PRINTF_POS_PARAMS      1
     4731+
     4732+// ----------------------------------------------------------------------------
     4733+// non GUI features selection
     4734+// ----------------------------------------------------------------------------
     4735+
     4736+// Set wxUSE_LONGLONG to 1 to compile the wxLongLong class. This is a 64 bit
     4737+// integer which is implemented in terms of native 64 bit integers if any or
     4738+// uses emulation otherwise.
     4739+//
     4740+// This class is required by wxDateTime and so you should enable it if you want
     4741+// to use wxDateTime. For most modern platforms, it will use the native 64 bit
     4742+// integers in which case (almost) all of its functions are inline and it
     4743+// almost does not take any space, so there should be no reason to switch it
     4744+// off.
     4745+//
     4746+// Recommended setting: 1
     4747+#define wxUSE_LONGLONG      1
     4748+
     4749+// Set wxUSE_(F)FILE to 1 to compile wx(F)File classes. wxFile uses low level
     4750+// POSIX functions for file access, wxFFile uses ANSI C stdio.h functions.
     4751+//
     4752+// Default is 1
     4753+//
     4754+// Recommended setting: 1 (wxFile is highly recommended as it is required by
     4755+// i18n code, wxFileConfig and others)
     4756+#define wxUSE_FILE          1
     4757+#define wxUSE_FFILE         1
     4758+
     4759+// Use wxFSVolume class providing access to the configured/active mount points
     4760+//
     4761+// Default is 1
     4762+//
     4763+// Recommended setting: 1 (but may be safely disabled if you don't use it)
     4764+#define wxUSE_FSVOLUME      1
     4765+
     4766+// Use wxStandardPaths class which allows to retrieve some standard locations
     4767+// in the file system
     4768+//
     4769+// Default is 1
     4770+//
     4771+// Recommended setting: 1 (may be disabled to save space, but not much)
     4772+#define wxUSE_STDPATHS      1
     4773+
     4774+// use wxTextBuffer class: required by wxTextFile
     4775+#define wxUSE_TEXTBUFFER    1
     4776+
     4777+// use wxTextFile class: requires wxFile and wxTextBuffer, required by
     4778+// wxFileConfig
     4779+#define wxUSE_TEXTFILE      1
     4780+
     4781+// i18n support: _() macro, wxLocale class. Requires wxTextFile.
     4782+#define wxUSE_INTL          1
     4783+
     4784+// Set wxUSE_DATETIME to 1 to compile the wxDateTime and related classes which
     4785+// allow to manipulate dates, times and time intervals. wxDateTime replaces the
     4786+// old wxTime and wxDate classes which are still provided for backwards
     4787+// compatibility (and implemented in terms of wxDateTime).
     4788+//
     4789+// Note that this class is relatively new and is still officially in alpha
     4790+// stage because some features are not yet (fully) implemented. It is already
     4791+// quite useful though and should only be disabled if you are aiming at
     4792+// absolutely minimal version of the library.
     4793+//
     4794+// Requires: wxUSE_LONGLONG
     4795+//
     4796+// Default is 1
     4797+//
     4798+// Recommended setting: 1
     4799+#define wxUSE_DATETIME      1
     4800+
     4801+// Set wxUSE_TIMER to 1 to compile wxTimer class
     4802+//
     4803+// Default is 1
     4804+//
     4805+// Recommended setting: 1
     4806+#define wxUSE_TIMER         1
     4807+
     4808+// Use wxStopWatch clas.
     4809+//
     4810+// Default is 1
     4811+//
     4812+// Recommended setting: 1 (needed by wxSocket)
     4813+#define wxUSE_STOPWATCH     1
     4814+
     4815+// Setting wxUSE_CONFIG to 1 enables the use of wxConfig and related classes
     4816+// which allow the application to store its settings in the persistent
     4817+// storage. Setting this to 1 will also enable on-demand creation of the
     4818+// global config object in wxApp.
     4819+//
     4820+// See also wxUSE_CONFIG_NATIVE below.
     4821+//
     4822+// Recommended setting: 1
     4823+#define wxUSE_CONFIG        1
     4824+
     4825+// If wxUSE_CONFIG is 1, you may choose to use either the native config
     4826+// classes under Windows (using .INI files under Win16 and the registry under
     4827+// Win32) or the portable text file format used by the config classes under
     4828+// Unix.
     4829+//
     4830+// Default is 1 to use native classes. Note that you may still use
     4831+// wxFileConfig even if you set this to 1 - just the config object created by
     4832+// default for the applications needs will be a wxRegConfig or wxIniConfig and
     4833+// not wxFileConfig.
     4834+//
     4835+// Recommended setting: 1
     4836+#define wxUSE_CONFIG_NATIVE   1
     4837+
     4838+// If wxUSE_DIALUP_MANAGER is 1, compile in wxDialUpManager class which allows
     4839+// to connect/disconnect from the network and be notified whenever the dial-up
     4840+// network connection is established/terminated. Requires wxUSE_DYNAMIC_LOADER.
     4841+//
     4842+// Default is 1.
     4843+//
     4844+// Recommended setting: 1
     4845+#define wxUSE_DIALUP_MANAGER   0
     4846+
     4847+// Compile in classes for run-time DLL loading and function calling.
     4848+// Required by wxUSE_DIALUP_MANAGER.
     4849+//
     4850+// This setting is for Win32 only
     4851+//
     4852+// Default is 1.
     4853+//
     4854+// Recommended setting: 1
     4855+#define wxUSE_DYNLIB_CLASS    1
     4856+
     4857+// experimental, don't use for now
     4858+#define wxUSE_DYNAMIC_LOADER  1
     4859+
     4860+// Set to 1 to use socket classes
     4861+#define wxUSE_SOCKETS       1
     4862+
     4863+// Set to 1 to enable virtual file systems (required by wxHTML)
     4864+#define wxUSE_FILESYSTEM    1
     4865+
     4866+// Set to 1 to enable virtual ZIP filesystem (requires wxUSE_FILESYSTEM)
     4867+#define wxUSE_FS_ZIP        1
     4868+
     4869+// Set to 1 to enable virtual archive filesystem (requires wxUSE_FILESYSTEM)
     4870+#define wxUSE_FS_ARCHIVE    1
     4871+
     4872+// Set to 1 to enable virtual Internet filesystem (requires wxUSE_FILESYSTEM)
     4873+#define wxUSE_FS_INET       1
     4874+
     4875+// wxArchive classes for accessing archives such as zip and tar
     4876+#define wxUSE_ARCHIVE_STREAMS     1
     4877+
     4878+// Set to 1 to compile wxZipInput/OutputStream classes.
     4879+#define wxUSE_ZIPSTREAM     1
     4880+
     4881+// Set to 1 to compile wxTarInput/OutputStream classes.
     4882+#define wxUSE_TARSTREAM     1
     4883+
     4884+// Set to 1 to compile wxZlibInput/OutputStream classes. Also required by
     4885+// wxUSE_LIBPNG
     4886+#define wxUSE_ZLIB          1
     4887+
     4888+// If enabled, the code written by Apple will be used to write, in a portable
     4889+// way, float on the disk. See extended.c for the license which is different
     4890+// from wxWidgets one.
     4891+//
     4892+// Default is 1.
     4893+//
     4894+// Recommended setting: 1 unless you don't like the license terms (unlikely)
     4895+#define wxUSE_APPLE_IEEE          1
     4896+
     4897+// Joystick support class
     4898+#define wxUSE_JOYSTICK            1
     4899+
     4900+// wxFontMapper class
     4901+#define wxUSE_FONTMAP 1
     4902+
     4903+// wxMimeTypesManager class
     4904+#define wxUSE_MIMETYPE 1
     4905+
     4906+// wxProtocol and related classes: if you want to use either of wxFTP, wxHTTP
     4907+// or wxURL you need to set this to 1.
     4908+//
     4909+// Default is 1.
     4910+//
     4911+// Recommended setting: 1
     4912+#define wxUSE_PROTOCOL 1
     4913+
     4914+// The settings for the individual URL schemes
     4915+#define wxUSE_PROTOCOL_FILE 1
     4916+#define wxUSE_PROTOCOL_FTP 1
     4917+#define wxUSE_PROTOCOL_HTTP 1
     4918+
     4919+// Define this to use wxURL class.
     4920+#define wxUSE_URL 1
     4921+
     4922+// Define this to use native platform url and protocol support.
     4923+// Currently valid only for MS-Windows.
     4924+// Note: if you set this to 1, you can open ftp/http/gopher sites
     4925+// and obtain a valid input stream for these sites
     4926+// even when you set wxUSE_PROTOCOL_FTP/HTTP to 0.
     4927+// Doing so reduces the code size.
     4928+//
     4929+// This code is experimental and subject to change.
     4930+#define wxUSE_URL_NATIVE 0
     4931+
     4932+// Support for wxVariant class used in several places throughout the library,
     4933+// notably in wxDataViewCtrl API.
     4934+//
     4935+// Default is 1.
     4936+//
     4937+// Recommended setting: 1 unless you want to reduce the library size as much as
     4938+// possible in which case setting this to 0 can gain up to 100KB.
     4939+#define wxUSE_VARIANT 1
     4940+
     4941+// Support for regular expression matching via wxRegEx class: enable this to
     4942+// use POSIX regular expressions in your code. You need to compile regex
     4943+// library from src/regex to use it under Windows.
     4944+//
     4945+// Default is 0
     4946+//
     4947+// Recommended setting: 1 if your compiler supports it, if it doesn't please
     4948+// contribute us a makefile for src/regex for it
     4949+#define wxUSE_REGEX       1
     4950+
     4951+// wxSystemOptions class
     4952+#define wxUSE_SYSTEM_OPTIONS 1
     4953+
     4954+// wxSound class
     4955+#define wxUSE_SOUND      1
     4956+
     4957+// Use wxMediaCtrl
     4958+//
     4959+// Default is 1.
     4960+//
     4961+// Recommended setting: 1
     4962+#define wxUSE_MEDIACTRL     1
     4963+
     4964+// Use GStreamer for Unix (req a lot of dependancies)
     4965+//
     4966+// Default is 0
     4967+//
     4968+// Recommended setting: 1 (wxMediaCtrl won't work by default without it)
     4969+#define wxUSE_GSTREAMER    0
     4970+
     4971+// Use wxWidget's XRC XML-based resource system.  Recommended.
     4972+//
     4973+// Default is 1
     4974+//
     4975+// Recommended setting: 1 (requires wxUSE_XML)
     4976+#define wxUSE_XRC       1
     4977+
     4978+// XML parsing classes. Note that their API will change in the future, so
     4979+// using wxXmlDocument and wxXmlNode in your app is not recommended.
     4980+//
     4981+// Default is the same as wxUSE_XRC, i.e. 1 by default.
     4982+//
     4983+// Recommended setting: 1 (required by XRC)
     4984+#define wxUSE_XML       wxUSE_XRC
     4985+
     4986+// Use wxWidget's AUI docking system
     4987+//
     4988+// Default is 1
     4989+//
     4990+// Recommended setting: 1
     4991+#define wxUSE_AUI       1
     4992+
     4993+
     4994+// Enable the new wxGraphicsPath and wxGraphicsContext classes for an advanced
     4995+// 2D drawing API.  (Still somewhat experimental)
     4996+//
     4997+// Please note that on Windows you will need to link with gdiplus.lib (use
     4998+// USE_GDIPLUS=1 for makefile builds) and distribute gdiplus.dll with your
     4999+// application if you want it to be runnable on pre-XP systems.
     5000+//
     5001+// Default is 0
     5002+//
     5003+// Recommended setting: 1
     5004+#ifndef wxUSE_GRAPHICS_CONTEXT
     5005+#define wxUSE_GRAPHICS_CONTEXT 1
     5006+#endif
     5007+
     5008+// ----------------------------------------------------------------------------
     5009+// Individual GUI controls
     5010+// ----------------------------------------------------------------------------
     5011+
     5012+// You must set wxUSE_CONTROLS to 1 if you are using any controls at all
     5013+// (without it, wxControl class is not compiled)
     5014+//
     5015+// Default is 1
     5016+//
     5017+// Recommended setting: 1 (don't change except for very special programs)
     5018+#define wxUSE_CONTROLS     1
     5019+
     5020+// wxPopupWindow class is a top level transient window. It is currently used
     5021+// to implement wxTipWindow
     5022+//
     5023+// Default is 1
     5024+//
     5025+// Recommended setting: 1 (may be set to 0 if you don't wxUSE_TIPWINDOW)
     5026+#define wxUSE_POPUPWIN     1
     5027+
     5028+// wxTipWindow allows to implement the custom tooltips, it is used by the
     5029+// context help classes. Requires wxUSE_POPUPWIN.
     5030+//
     5031+// Default is 1
     5032+//
     5033+// Recommended setting: 1 (may be set to 0)
     5034+#define wxUSE_TIPWINDOW    1
     5035+
     5036+// Each of the settings below corresponds to one wxWidgets control. They are
     5037+// all switched on by default but may be disabled if you are sure that your
     5038+// program (including any standard dialogs it can show!) doesn't need them and
     5039+// if you desperately want to save some space. If you use any of these you must
     5040+// set wxUSE_CONTROLS as well.
     5041+//
     5042+// Default is 1
     5043+//
     5044+// Recommended setting: 1
     5045+#define wxUSE_ANIMATIONCTRL 1   // wxAnimationCtrl
     5046+#define wxUSE_BUTTON        1   // wxButton
     5047+#define wxUSE_BMPBUTTON     1   // wxBitmapButton
     5048+#define wxUSE_CALENDARCTRL  1   // wxCalendarCtrl
     5049+#define wxUSE_CHECKBOX      1   // wxCheckBox
     5050+#define wxUSE_CHECKLISTBOX  1   // wxCheckListBox (requires wxUSE_OWNER_DRAWN)
     5051+#define wxUSE_CHOICE        1   // wxChoice
     5052+#define wxUSE_COLLPANE      1   // wxCollapsiblePane
     5053+#define wxUSE_COLOURPICKERCTRL 1    // wxColourPickerCtrl
     5054+#define wxUSE_COMBOBOX      1   // wxComboBox
     5055+#define wxUSE_DATAVIEWCTRL  1   // wxDataViewCtrl
     5056+#define wxUSE_DATEPICKCTRL  1   // wxDatePickerCtrl
     5057+#define wxUSE_DIRPICKERCTRL 1   // wxDirPickerCtrl
     5058+#define wxUSE_FILEPICKERCTRL 1  // wxFilePickerCtrl
     5059+#define wxUSE_FONTPICKERCTRL 1  // wxFontPickerCtrl
     5060+#define wxUSE_GAUGE         1   // wxGauge
     5061+#define wxUSE_HYPERLINKCTRL 1   // wxHyperlinkCtrl
     5062+#define wxUSE_LISTBOX       1   // wxListBox
     5063+#define wxUSE_LISTCTRL      1   // wxListCtrl
     5064+#define wxUSE_RADIOBOX      1   // wxRadioBox
     5065+#define wxUSE_RADIOBTN      1   // wxRadioButton
     5066+#define wxUSE_SCROLLBAR     1   // wxScrollBar
     5067+#define wxUSE_SEARCHCTRL    1   // wxSearchCtrl
     5068+#define wxUSE_SLIDER        1   // wxSlider
     5069+#define wxUSE_SPINBTN       1   // wxSpinButton
     5070+#define wxUSE_SPINCTRL      1   // wxSpinCtrl
     5071+#define wxUSE_STATBOX       1   // wxStaticBox
     5072+#define wxUSE_STATLINE      1   // wxStaticLine
     5073+#define wxUSE_STATTEXT      1   // wxStaticText
     5074+#define wxUSE_STATBMP       1   // wxStaticBitmap
     5075+#define wxUSE_TEXTCTRL      1   // wxTextCtrl
     5076+#define wxUSE_TOGGLEBTN     1   // requires wxButton
     5077+#define wxUSE_TREECTRL      1   // wxTreeCtrl
     5078+
     5079+// Use a status bar class? Depending on the value of wxUSE_NATIVE_STATUSBAR
     5080+// below either wxStatusBar95 or a generic wxStatusBar will be used.
     5081+//
     5082+// Default is 1
     5083+//
     5084+// Recommended setting: 1
     5085+#define wxUSE_STATUSBAR    1
     5086+
     5087+// Two status bar implementations are available under Win32: the generic one
     5088+// or the wrapper around native control. For native look and feel the native
     5089+// version should be used.
     5090+//
     5091+// Default is 1 for the platforms where native status bar is supported.
     5092+//
     5093+// Recommended setting: 1 (there is no advantage in using the generic one)
     5094+#define wxUSE_NATIVE_STATUSBAR        1
     5095+
     5096+// wxToolBar related settings: if wxUSE_TOOLBAR is 0, don't compile any toolbar
     5097+// classes at all. Otherwise, use the native toolbar class unless
     5098+// wxUSE_TOOLBAR_NATIVE is 0.
     5099+//
     5100+// Default is 1 for all settings.
     5101+//
     5102+// Recommended setting: 1 for wxUSE_TOOLBAR and wxUSE_TOOLBAR_NATIVE.
     5103+#define wxUSE_TOOLBAR 1
     5104+#define wxUSE_TOOLBAR_NATIVE 1
     5105+
     5106+// wxNotebook is a control with several "tabs" located on one of its sides. It
     5107+// may be used to logically organise the data presented to the user instead of
     5108+// putting everything in one huge dialog. It replaces wxTabControl and related
     5109+// classes of wxWin 1.6x.
     5110+//
     5111+// Default is 1.
     5112+//
     5113+// Recommended setting: 1
     5114+#define wxUSE_NOTEBOOK 1
     5115+
     5116+// wxListbook control is similar to wxNotebook but uses wxListCtrl instead of
     5117+// the tabs
     5118+//
     5119+// Default is 1.
     5120+//
     5121+// Recommended setting: 1
     5122+#define wxUSE_LISTBOOK 1
     5123+
     5124+// wxChoicebook control is similar to wxNotebook but uses wxChoice instead of
     5125+// the tabs
     5126+//
     5127+// Default is 1.
     5128+//
     5129+// Recommended setting: 1
     5130+#define wxUSE_CHOICEBOOK 1
     5131+
     5132+// wxTreebook control is similar to wxNotebook but uses wxTreeCtrl instead of
     5133+// the tabs
     5134+//
     5135+// Default is 1.
     5136+//
     5137+// Recommended setting: 1
     5138+#define wxUSE_TREEBOOK 1
     5139+
     5140+// wxToolbook control is similar to wxNotebook but uses wxToolBar instead of
     5141+// tabs
     5142+//
     5143+// Default is 1.
     5144+//
     5145+// Recommended setting: 1
     5146+#define wxUSE_TOOLBOOK 1
     5147+
     5148+// wxTabDialog is a generic version of wxNotebook but it is incompatible with
     5149+// the new class. It shouldn't be used in new code.
     5150+//
     5151+// Default is 0.
     5152+//
     5153+// Recommended setting: 0 (use wxNotebook)
     5154+#define wxUSE_TAB_DIALOG    0
     5155+
     5156+// wxGrid class
     5157+//
     5158+// Default is 1, set to 0 to cut down compilation time and binaries size if you
     5159+// don't use it.
     5160+//
     5161+// Recommended setting: 1
     5162+//
     5163+#define wxUSE_GRID         1
     5164+
     5165+// wxMiniFrame class: a frame with narrow title bar
     5166+//
     5167+// Default is 1.
     5168+//
     5169+// Recommended setting: 1 (it doesn't cost almost anything)
     5170+#define wxUSE_MINIFRAME 1
     5171+
     5172+// wxComboCtrl and related classes: combobox with custom popup window and
     5173+// not necessarily a listbox.
     5174+//
     5175+// Default is 1.
     5176+//
     5177+// Recommended setting: 1 but can be safely set to 0 except for wxUniv where it
     5178+//                      it used by wxComboBox
     5179+#define wxUSE_COMBOCTRL 1
     5180+
     5181+// wxOwnerDrawnComboBox is a custom combobox allowing to paint the combobox
     5182+// items.
     5183+//
     5184+// Default is 1.
     5185+//
     5186+// Recommended setting: 1 but can be safely set to 0, except where it is
     5187+//                      needed as a base class for generic wxBitmapComboBox.
     5188+#define wxUSE_ODCOMBOBOX 1
     5189+
     5190+// wxBitmapComboBox is a combobox that can have images in front of text items.
     5191+//
     5192+// Default is 1.
     5193+//
     5194+// Recommended setting: 1 but can be safely set to 0
     5195+#define wxUSE_BITMAPCOMBOBOX 1
     5196+
     5197+// ----------------------------------------------------------------------------
     5198+// Miscellaneous GUI stuff
     5199+// ----------------------------------------------------------------------------
     5200+
     5201+// wxAcceleratorTable/Entry classes and support for them in wxMenu(Bar)
     5202+#define wxUSE_ACCEL 1
     5203+
     5204+// Hotkey support (currently Windows only)
     5205+#define wxUSE_HOTKEY 1
     5206+
     5207+// Use wxCaret: a class implementing a "cursor" in a text control (called caret
     5208+// under Windows).
     5209+//
     5210+// Default is 1.
     5211+//
     5212+// Recommended setting: 1 (can be safely set to 0, not used by the library)
     5213+#define wxUSE_CARET         1
     5214+
     5215+// Use wxDisplay class: it allows enumerating all displays on a system and
     5216+// their geometries as well as finding the display on which the given point or
     5217+// window lies.
     5218+//
     5219+// Default is 1.
     5220+//
     5221+// Recommended setting: 1 if you need it, can be safely set to 0 otherwise
     5222+#define wxUSE_DISPLAY       1
     5223+
     5224+// Miscellaneous geometry code: needed for Canvas library
     5225+#define wxUSE_GEOMETRY            1
     5226+
     5227+// Use wxImageList. This class is needed by wxNotebook, wxTreeCtrl and
     5228+// wxListCtrl.
     5229+//
     5230+// Default is 1.
     5231+//
     5232+// Recommended setting: 1 (set it to 0 if you don't use any of the controls
     5233+// enumerated above, then this class is mostly useless too)
     5234+#define wxUSE_IMAGLIST      1
     5235+
     5236+// Use wxMenu, wxMenuBar, wxMenuItem.
     5237+//
     5238+// Default is 1.
     5239+//
     5240+// Recommended setting: 1 (can't be disabled under MSW)
     5241+#define wxUSE_MENUS         1
     5242+
     5243+// Use wxSashWindow class.
     5244+//
     5245+// Default is 1.
     5246+//
     5247+// Recommended setting: 1
     5248+#define wxUSE_SASH          1
     5249+
     5250+// Use wxSplitterWindow class.
     5251+//
     5252+// Default is 1.
     5253+//
     5254+// Recommended setting: 1
     5255+#define wxUSE_SPLITTER      1
     5256+
     5257+// Use wxToolTip and wxWindow::Set/GetToolTip() methods.
     5258+//
     5259+// Default is 1.
     5260+//
     5261+// Recommended setting: 1
     5262+#define wxUSE_TOOLTIPS      1
     5263+
     5264+// wxValidator class and related methods
     5265+#define wxUSE_VALIDATORS 1
     5266+
     5267+// ----------------------------------------------------------------------------
     5268+// common dialogs
     5269+// ----------------------------------------------------------------------------
     5270+
     5271+// On rare occasions (e.g. using DJGPP) may want to omit common dialogs (e.g.
     5272+// file selector, printer dialog). Switching this off also switches off the
     5273+// printing architecture and interactive wxPrinterDC.
     5274+//
     5275+// Default is 1
     5276+//
     5277+// Recommended setting: 1 (unless it really doesn't work)
     5278+#define wxUSE_COMMON_DIALOGS 1
     5279+
     5280+// wxBusyInfo displays window with message when app is busy. Works in same way
     5281+// as wxBusyCursor
     5282+#define wxUSE_BUSYINFO      1
     5283+
     5284+// Use single/multiple choice dialogs.
     5285+//
     5286+// Default is 1
     5287+//
     5288+// Recommended setting: 1 (used in the library itself)
     5289+#define wxUSE_CHOICEDLG     1
     5290+
     5291+// Use colour picker dialog
     5292+//
     5293+// Default is 1
     5294+//
     5295+// Recommended setting: 1
     5296+#define wxUSE_COLOURDLG     1
     5297+
     5298+// wxDirDlg class for getting a directory name from user
     5299+#define wxUSE_DIRDLG 1
     5300+
     5301+// TODO: setting to choose the generic or native one
     5302+
     5303+// Use file open/save dialogs.
     5304+//
     5305+// Default is 1
     5306+//
     5307+// Recommended setting: 1 (used in many places in the library itself)
     5308+#define wxUSE_FILEDLG       1
     5309+
     5310+// Use find/replace dialogs.
     5311+//
     5312+// Default is 1
     5313+//
     5314+// Recommended setting: 1 (but may be safely set to 0)
     5315+#define wxUSE_FINDREPLDLG       1
     5316+
     5317+// Use font picker dialog
     5318+//
     5319+// Default is 1
     5320+//
     5321+// Recommended setting: 1 (used in the library itself)
     5322+#define wxUSE_FONTDLG       1
     5323+
     5324+// Use wxMessageDialog and wxMessageBox.
     5325+//
     5326+// Default is 1
     5327+//
     5328+// Recommended setting: 1 (used in the library itself)
     5329+#define wxUSE_MSGDLG        1
     5330+
     5331+// progress dialog class for lengthy operations
     5332+#define wxUSE_PROGRESSDLG 1
     5333+
     5334+// support for startup tips (wxShowTip &c)
     5335+#define wxUSE_STARTUP_TIPS 1
     5336+
     5337+// text entry dialog and wxGetTextFromUser function
     5338+#define wxUSE_TEXTDLG 1
     5339+
     5340+// number entry dialog
     5341+#define wxUSE_NUMBERDLG 1
     5342+
     5343+// splash screen class
     5344+#define wxUSE_SPLASH 1
     5345+
     5346+// wizards
     5347+#define wxUSE_WIZARDDLG 1
     5348+
     5349+// Compile in wxAboutBox() function showing the standard "About" dialog.
     5350+//
     5351+// Default is 1
     5352+//
     5353+// Recommended setting: 1 but can be set to 0 to save some space if you don't
     5354+//                      use this function
     5355+#define wxUSE_ABOUTDLG 1
     5356+
     5357+// ----------------------------------------------------------------------------
     5358+// Metafiles support
     5359+// ----------------------------------------------------------------------------
     5360+
     5361+// Windows supports the graphics format known as metafile which is, though not
     5362+// portable, is widely used under Windows and so is supported by wxWin (under
     5363+// Windows only, of course). Win16 (Win3.1) used the so-called "Window
     5364+// MetaFiles" or WMFs which were replaced with "Enhanced MetaFiles" or EMFs in
     5365+// Win32 (Win9x, NT, 2000). Both of these are supported in wxWin and, by
     5366+// default, WMFs will be used under Win16 and EMFs under Win32. This may be
     5367+// changed by setting wxUSE_WIN_METAFILES_ALWAYS to 1 and/or setting
     5368+// wxUSE_ENH_METAFILE to 0. You may also set wxUSE_METAFILE to 0 to not compile
     5369+// in any metafile related classes at all.
     5370+//
     5371+// Default is 1 for wxUSE_ENH_METAFILE and 0 for wxUSE_WIN_METAFILES_ALWAYS.
     5372+//
     5373+// Recommended setting: default or 0 for everything for portable programs.
     5374+#define wxUSE_METAFILE              1
     5375+#define wxUSE_ENH_METAFILE          1
     5376+#define wxUSE_WIN_METAFILES_ALWAYS  0
     5377+
     5378+// ----------------------------------------------------------------------------
     5379+// Big GUI components
     5380+// ----------------------------------------------------------------------------
     5381+
     5382+// Set to 0 to disable MDI support.
     5383+//
     5384+// Requires wxUSE_NOTEBOOK under platforms other than MSW.
     5385+//
     5386+// Default is 1.
     5387+//
     5388+// Recommended setting: 1, can be safely set to 0.
     5389+#define wxUSE_MDI 1
     5390+
     5391+// Set to 0 to disable document/view architecture
     5392+#define wxUSE_DOC_VIEW_ARCHITECTURE 1
     5393+
     5394+// Set to 0 to disable MDI document/view architecture
     5395+//
     5396+// Requires wxUSE_MDI && wxUSE_DOC_VIEW_ARCHITECTURE
     5397+#define wxUSE_MDI_ARCHITECTURE    1
     5398+
     5399+// Set to 0 to disable print/preview architecture code
     5400+#define wxUSE_PRINTING_ARCHITECTURE  1
     5401+
     5402+// wxHTML sublibrary allows to display HTML in wxWindow programs and much,
     5403+// much more.
     5404+//
     5405+// Default is 1.
     5406+//
     5407+// Recommended setting: 1 (wxHTML is great!), set to 0 if you want compile a
     5408+// smaller library.
     5409+#define wxUSE_HTML          1
     5410+
     5411+// Setting wxUSE_GLCANVAS to 1 enables OpenGL support. You need to have OpenGL
     5412+// headers and libraries to be able to compile the library with wxUSE_GLCANVAS
     5413+// set to 1. Note that for some compilers (notably Microsoft Visual C++) you
     5414+// will need to manually add opengl32.lib and glu32.lib to the list of
     5415+// libraries linked with your program if you use OpenGL.
     5416+//
     5417+// Default is 0.
     5418+//
     5419+// Recommended setting: 1 if you intend to use OpenGL, 0 otherwise
     5420+#define wxUSE_GLCANVAS       1
     5421+
     5422+// wxRichTextCtrl allows editing of styled text.
     5423+//
     5424+// Default is 1.
     5425+//
     5426+// Recommended setting: 1, set to 0 if you want compile a
     5427+// smaller library.
     5428+#define wxUSE_RICHTEXT       1
     5429+
     5430+// ----------------------------------------------------------------------------
     5431+// Data transfer
     5432+// ----------------------------------------------------------------------------
     5433+
     5434+// Use wxClipboard class for clipboard copy/paste.
     5435+//
     5436+// Default is 1.
     5437+//
     5438+// Recommended setting: 1
     5439+#define wxUSE_CLIPBOARD     1
     5440+
     5441+// Use wxDataObject and related classes. Needed for clipboard and OLE drag and
     5442+// drop
     5443+//
     5444+// Default is 1.
     5445+//
     5446+// Recommended setting: 1
     5447+#define wxUSE_DATAOBJ       1
     5448+
     5449+// Use wxDropTarget and wxDropSource classes for drag and drop (this is
     5450+// different from "built in" drag and drop in wxTreeCtrl which is always
     5451+// available). Requires wxUSE_DATAOBJ.
     5452+//
     5453+// Default is 1.
     5454+//
     5455+// Recommended setting: 1
     5456+#define wxUSE_DRAG_AND_DROP 1
     5457+
     5458+// Use wxAccessible for enhanced and customisable accessibility.
     5459+// Depends on wxUSE_OLE.
     5460+//
     5461+// Default is 0.
     5462+//
     5463+// Recommended setting (at present): 0
     5464+#define wxUSE_ACCESSIBILITY 0
     5465+
     5466+// ----------------------------------------------------------------------------
     5467+// miscellaneous settings
     5468+// ----------------------------------------------------------------------------
     5469+
     5470+// wxSingleInstanceChecker class allows to verify at startup if another program
     5471+// instance is running.
     5472+//
     5473+// Default is 1
     5474+//
     5475+// Recommended setting: 1 (the class is tiny, disabling it won't save much
     5476+// space)
     5477+#define wxUSE_SNGLINST_CHECKER  1
     5478+
     5479+#define wxUSE_DRAGIMAGE 1
     5480+
     5481+#define wxUSE_IPC         1
     5482+                                // 0 for no interprocess comms
     5483+#define wxUSE_HELP        1
     5484+                                // 0 for no help facility
     5485+
     5486+// Should we use MS HTML help for wxHelpController? If disabled, neither
     5487+// wxCHMHelpController nor wxBestHelpController are available.
     5488+//
     5489+// Default is 1 under MSW, 0 is always used for the other platforms.
     5490+//
     5491+// Recommended setting: 1, only set to 0 if you have trouble compiling
     5492+// wxCHMHelpController (could be a problem with really ancient compilers)
     5493+#define wxUSE_MS_HTML_HELP 1
     5494+
     5495+
     5496+// Use wxHTML-based help controller?
     5497+#define wxUSE_WXHTML_HELP 1
     5498+
     5499+#define wxUSE_RESOURCES   0
     5500+                                // 0 for no wxGetResource/wxWriteResource
     5501+#define wxUSE_CONSTRAINTS 1
     5502+                                // 0 for no window layout constraint system
     5503+
     5504+#define wxUSE_SPLINES     1
     5505+                                // 0 for no splines
     5506+
     5507+#define wxUSE_MOUSEWHEEL        1
     5508+                                // Include mouse wheel support
     5509+
     5510+// ----------------------------------------------------------------------------
     5511+// postscript support settings
     5512+// ----------------------------------------------------------------------------
     5513+
     5514+// Set to 1 for PostScript device context.
     5515+#define wxUSE_POSTSCRIPT  1
     5516+
     5517+// Set to 1 to use font metric files in GetTextExtent
     5518+#define wxUSE_AFM_FOR_POSTSCRIPT 1
     5519+
     5520+// ----------------------------------------------------------------------------
     5521+// database classes
     5522+// ----------------------------------------------------------------------------
     5523+
     5524+// Define 1 to use ODBC classes
     5525+#define wxUSE_ODBC          0
     5526+
     5527+// For backward compatibility reasons, this parameter now only controls the
     5528+// default scrolling method used by cursors.  This default behavior can be
     5529+// overriden by setting the second param of wxDB::wxDbGetConnection() or
     5530+// wxDb() constructor to indicate whether the connection (and any wxDbTable()s
     5531+// that use the connection) should support forward only scrolling of cursors,
     5532+// or both forward and backward support for backward scrolling cursors is
     5533+// dependent on the data source as well as the ODBC driver being used.
     5534+#define wxODBC_FWD_ONLY_CURSORS         1
     5535+
     5536+// Default is 0.  Set to 1 to use the deprecated classes, enum types, function,
     5537+// member variables.  With a setting of 1, full backward compatibility with the
     5538+// 2.0.x release is possible. It is STRONGLY recommended that this be set to 0,
     5539+// as future development will be done only on the non-deprecated
     5540+// functions/classes/member variables/etc.
     5541+#define wxODBC_BACKWARD_COMPATABILITY 0
     5542+
     5543+// ----------------------------------------------------------------------------
     5544+// other compiler (mis)features
     5545+// ----------------------------------------------------------------------------
     5546+
     5547+// Set this to 0 if your compiler can't cope with omission of prototype
     5548+// parameters.
     5549+//
     5550+// Default is 1.
     5551+//
     5552+// Recommended setting: 1 (should never need to set this to 0)
     5553+#define REMOVE_UNUSED_ARG   1
     5554+
     5555+// VC++ 4.2 and above allows <iostream> and <iostream.h> but you can't mix
     5556+// them. Set to 1 for <iostream.h>, 0 for <iostream>. Note that VC++ 7.1
     5557+// and later doesn't support wxUSE_IOSTREAMH == 1 and so <iostream> will be
     5558+// used anyhow.
     5559+//
     5560+// Default is 1.
     5561+//
     5562+// Recommended setting: whatever your compiler likes more
     5563+#define wxUSE_IOSTREAMH     1
     5564+
     5565+// ----------------------------------------------------------------------------
     5566+// image format support
     5567+// ----------------------------------------------------------------------------
     5568+
     5569+// wxImage supports many different image formats which can be configured at
     5570+// compile-time. BMP is always supported, others are optional and can be safely
     5571+// disabled if you don't plan to use images in such format sometimes saving
     5572+// substantial amount of code in the final library.
     5573+//
     5574+// Some formats require an extra library which is included in wxWin sources
     5575+// which is mentioned if it is the case.
     5576+
     5577+// Set to 1 for wxImage support (recommended).
     5578+#define wxUSE_IMAGE         1
     5579+
     5580+// Set to 1 for PNG format support (requires libpng). Also requires wxUSE_ZLIB.
     5581+#define wxUSE_LIBPNG        1
     5582+
     5583+// Set to 1 for JPEG format support (requires libjpeg)
     5584+#define wxUSE_LIBJPEG       1
     5585+
     5586+// Set to 1 for TIFF format support (requires libtiff)
     5587+#define wxUSE_LIBTIFF       1
     5588+
     5589+// Set to 1 for TGA format support (loading only)
     5590+#define wxUSE_TGA           1
     5591+
     5592+// Set to 1 for GIF format support
     5593+#define wxUSE_GIF           1
     5594+
     5595+// Set to 1 for PNM format support
     5596+#define wxUSE_PNM           1
     5597+
     5598+// Set to 1 for PCX format support
     5599+#define wxUSE_PCX           1
     5600+
     5601+// Set to 1 for IFF format support (Amiga format)
     5602+#define wxUSE_IFF           0
     5603+
     5604+// Set to 1 for XPM format support
     5605+#define wxUSE_XPM           1
     5606+
     5607+// Set to 1 for MS Icons and Cursors format support
     5608+#define wxUSE_ICO_CUR       1
     5609+
     5610+// Set to 1 to compile in wxPalette class
     5611+#define wxUSE_PALETTE       1
     5612+
     5613+// ----------------------------------------------------------------------------
     5614+// wxUniversal-only options
     5615+// ----------------------------------------------------------------------------
     5616+
     5617+// Set to 1 to enable compilation of all themes, this is the default
     5618+#define wxUSE_ALL_THEMES    1
     5619+
     5620+// Set to 1 to enable the compilation of individual theme if wxUSE_ALL_THEMES
     5621+// is unset, if it is set these options are not used; notice that metal theme
     5622+// uses Win32 one
     5623+#define wxUSE_THEME_GTK     0
     5624+#define wxUSE_THEME_METAL   0
     5625+#define wxUSE_THEME_MONO    0
     5626+#define wxUSE_THEME_WIN32   0
     5627+
     5628+
     5629+/* --- end common options --- */
     5630+
     5631+// ----------------------------------------------------------------------------
     5632+// Windows-only settings
     5633+// ----------------------------------------------------------------------------
     5634+
     5635+// Set wxUSE_UNICODE_MSLU to 1 if you're compiling wxWidgets in Unicode mode
     5636+// and want to run your programs under Windows 9x and not only NT/2000/XP.
     5637+// This setting enables use of unicows.dll from MSLU (MS Layer for Unicode, see
     5638+// http://www.microsoft.com/globaldev/handson/dev/mslu_announce.mspx). Note
     5639+// that you will have to modify the makefiles to include unicows.lib import
     5640+// library as the first library (see installation instructions in install.txt
     5641+// to learn how to do it when building the library or samples).
     5642+//
     5643+// If your compiler doesn't have unicows.lib, you can get a version of it at
     5644+// http://libunicows.sourceforge.net
     5645+//
     5646+// Default is 0
     5647+//
     5648+// Recommended setting: 0 (1 if you want to deploy Unicode apps on 9x systems)
     5649+#ifndef wxUSE_UNICODE_MSLU
     5650+    #define wxUSE_UNICODE_MSLU 1
     5651+#endif
     5652+
     5653+// Set this to 1 if you want to use wxWidgets and MFC in the same program. This
     5654+// will override some other settings (see below)
     5655+//
     5656+// Default is 0.
     5657+//
     5658+// Recommended setting: 0 unless you really have to use MFC
     5659+#define wxUSE_MFC           0
     5660+
     5661+// Set this to 1 for generic OLE support: this is required for drag-and-drop,
     5662+// clipboard, OLE Automation. Only set it to 0 if your compiler is very old and
     5663+// can't compile/doesn't have the OLE headers.
     5664+//
     5665+// Default is 1.
     5666+//
     5667+// Recommended setting: 1
     5668+#define wxUSE_OLE           1
     5669+
     5670+// Set this to 1 to enable wxAutomationObject class.
     5671+//
     5672+// Default is 1.
     5673+//
     5674+// Recommended setting: 1 if you need to control other applications via OLE
     5675+// Automation, can be safely set to 0 otherwise
     5676+#define wxUSE_OLE_AUTOMATION 1
     5677+
     5678+// Set this to 1 to enable wxActiveXContainer class allowing to embed OLE
     5679+// controls in wx.
     5680+//
     5681+// Default is 1.
     5682+//
     5683+// Recommended setting: 1, required by wxMediaCtrl
     5684+#define wxUSE_ACTIVEX 1
     5685+
     5686+// wxDC cacheing implementation
     5687+#define wxUSE_DC_CACHEING 1
     5688+
     5689+// Set this to 1 to enable the use of DIB's for wxBitmap to support
     5690+// bitmaps > 16MB on Win95/98/Me.  Set to 0 to use DDB's only.
     5691+#define wxUSE_DIB_FOR_BITMAP 1
     5692+
     5693+// Set this to 1 to enable wxDIB class used internally for manipulating
     5694+// wxBitmao data.
     5695+//
     5696+// Default is 1, set it to 0 only if you don't use wxImage neither
     5697+//
     5698+// Recommended setting: 1 (without it conversion to/from wxImage won't work)
     5699+#define wxUSE_WXDIB 1
     5700+
     5701+// Set to 0 to disable PostScript print/preview architecture code under Windows
     5702+// (just use Windows printing).
     5703+#define wxUSE_POSTSCRIPT_ARCHITECTURE_IN_MSW 1
     5704+
     5705+// Set this to 1 to use RICHEDIT controls for wxTextCtrl with style wxTE_RICH
     5706+// which allows to put more than ~32Kb of text in it even under Win9x (NT
     5707+// doesn't have such limitation).
     5708+//
     5709+// Default is 1 for compilers which support it
     5710+//
     5711+// Recommended setting: 1, only set it to 0 if your compiler doesn't have
     5712+//                      or can't compile <richedit.h>
     5713+#define wxUSE_RICHEDIT  1
     5714+
     5715+// Set this to 1 to use extra features of richedit v2 and later controls
     5716+//
     5717+// Default is 1 for compilers which support it
     5718+//
     5719+// Recommended setting: 1
     5720+#define wxUSE_RICHEDIT2 1
     5721+
     5722+// Set this to 1 to enable support for the owner-drawn menu and listboxes. This
     5723+// is required by wxUSE_CHECKLISTBOX.
     5724+//
     5725+// Default is 1.
     5726+//
     5727+// Recommended setting: 1, set to 0 for a small library size reduction
     5728+#define wxUSE_OWNER_DRAWN 1
     5729+
     5730+// Set to 1 to compile MS Windows XP theme engine support
     5731+#define wxUSE_UXTHEME           1
     5732+
     5733+// Set to 1 to auto-adapt to MS Windows XP themes where possible
     5734+// (notably, wxNotebook pages)
     5735+#define wxUSE_UXTHEME_AUTO      1
     5736+
     5737+// Set to 1 to use InkEdit control (Tablet PC), if available
     5738+#define wxUSE_INKEDIT  0
     5739+
     5740+// ----------------------------------------------------------------------------
     5741+// Generic versions of native controls
     5742+// ----------------------------------------------------------------------------
     5743+
     5744+// Set this to 1 to be able to use wxDatePickerCtrlGeneric in addition to the
     5745+// native wxDatePickerCtrl
     5746+//
     5747+// Default is 0.
     5748+//
     5749+// Recommended setting: 0, this is mainly used for testing
     5750+#define wxUSE_DATEPICKCTRL_GENERIC 1
     5751+
     5752+// ----------------------------------------------------------------------------
     5753+// Crash debugging helpers
     5754+// ----------------------------------------------------------------------------
     5755+
     5756+// Set this to 1 to be able to use wxCrashReport::Generate() to create mini
     5757+// dumps of your program when it crashes (or at any other moment)
     5758+//
     5759+// Default is 1 if supported by the compiler (VC++ and recent BC++ only).
     5760+//
     5761+// Recommended setting: 1, set to 0 if your programs never crash
     5762+#define wxUSE_CRASHREPORT 1
     5763+
     5764+// ----------------------------------------------------------------------------
     5765+// obsolete settings
     5766+// ----------------------------------------------------------------------------
     5767+
     5768+// NB: all settings in this section are obsolete and should not be used/changed
     5769+//     at all, they will disappear
     5770+
     5771+// Define 1 to use bitmap messages.
     5772+#define wxUSE_BITMAP_MESSAGE         1
     5773+
     5774+#endif // _WX_SETUP_H_
     5775+
     5776diff '--exclude-from=wxPython-src-2.8.9.1/exclude' -Nur orig/wxPython-src-2.8.9.1//package.cmd wxPython-src-2.8.9.1//package.cmd
     5777--- orig/wxPython-src-2.8.9.1//package.cmd      1970-01-01 01:00:00.000000000 +0100
     5778+++ wxPython-src-2.8.9.1//package.cmd   2011-04-28 18:46:50.000000000 +0200
     5779@@ -0,0 +1,18 @@
     5780+set WXWIN=%CD%
     5781+set WXDIR=%CD%
     5782+set PATH=%PATH%;%WXWIN%\lib\vc_dll
     5783+
     5784+cd build\msw
     5785+nmake -f makefile.vc OFFICIAL_BUILD=1 BUILD=release SHARED=1 MONOLITHIC=0 USE_XML=1 USE_OPENGL=1 USE_GDIPLUS=1 UNICODE=1 MSLU=1 HYBRID=1
     5786+
     5787+cd %WXWIN%\contrib\build\stc
     5788+nmake -f makefile.vc OFFICIAL_BUILD=1 BUILD=release SHARED=1 MONOLITHIC=0 USE_XML=1 USE_OPENGL=1 USE_GDIPLUS=1 UNICODE=1 MSLU=1 HYBRID=1
     5789+
     5790+cd %WXWIN%\contrib\build\gizmos
     5791+nmake -f makefile.vc OFFICIAL_BUILD=1 BUILD=release SHARED=1 MONOLITHIC=0 USE_XML=1 USE_OPENGL=1 USE_GDIPLUS=1 UNICODE=1 MSLU=1 HYBRID=1
     5792+
     5793+cd %WXWIN%\wxPython
     5794+python setup.py build_ext --inplace UNICODE=1 FINAL=1 -D WXUSINGDLL
     5795+python setup.py install UNICODE=1 FINAL=1
     5796+
     5797+cd %WXWIN%
     5798}}}
     5799
     5800I suppose the package was then tarred up manually.
