Changes between Version 2 and Version 3 of pkg-gdal16-ecw
Oct 20, 2010, 11:11:00 PM (14 years ago)
Mike Taves
elaborate and provide reference to 1.7 version
  • pkg-gdal16-ecw
    v2 v3
    77== Installing ECW SDK ==
    88
    9 The GDAL ECW Plugin requires the ECW 3.3 Runtime libraries which the end user is required to download and install directly from the Erdas Web Site directly.  See the [wiki:pkg-gdal-ecw] for details on how to manually install the ECW SDK.  The underlying SDK only needs to be installed once for both the gdal-ecw and gda16-ecw plugins.
     9The GDAL ECW Plugin requires the ECW 3.3 Runtime libraries, which were distributed by ERDAS, but are no longer available for download (see [wiki:pkg-gdal17-ecw] for newer version that is available for download). In order to use the runtime libraries, the end user is required to install the DLLs into a system directory. For 32-bit versions of Windows, this is {{{C:\Windows\system32}}}, and for 64-bit versions this directory is {{{C:\Windows\SysWOW64}}}.
     10
     11See the [wiki:pkg-gdal-ecw] for details on how to manually install the ECW SDK.  The underlying SDK only needs to be installed once for both the gdal-ecw and gda16-ecw plugins.
