Changes between Version 66 and Version 67 of WikiStart
- May 24, 2014, 5:39:30 AM (10 years ago)
WikiStart
v66 v67 25 25 * Step 2 must be run on a computer with internet access as the installer downloads individual packages as needed. You may also need to enable your software firewall to allow the installer to have outbound access. 26 26 * 32bit/64bit don't contain the same set of packages/versions [http://download.osgeo.org/osgeo4w/versions_diff-x86-x86_64.html (compare)] (purple is 32 bit only) 27 * Don't blindly do a full install in Advanced mode. Some components require third party additions that need to be installed manually (see the wiki page of the package). Without the additons the components might renderer the installation unuseable. 27 28 28 29 After installation:
