Changes between Version 8 and Version 9 of Infrastructure
Show
05/10/12 14:57:30 (13 months ago)
tschaub
udpates based on directory shuffle
  • Infrastructure
    v8 v9
    44
    55 * m.openlayers.org - redirects to listing of mobile examples (http://openlayers.org/dev/examples/?q=mobile)
    6  * docs.openlayers.org (root /osgeo/openlayers/documentation) - sphinx docs
    7  * dev.openlayers.org (root /osgeo/openlayers/dev) - hosted releases, old sandboxes, nightly build
    8  * openlayers.org (root /osgeo/openlayers/docs) - main website
     6 * docs.openlayers.org (root /osgeo/openlayers/sites/docs.openlayers.org) - sphinx docs
     7 * dev.openlayers.org (root /osgeo/openlayers/sites/dev.openlayers.org) - hosted releases, old sandboxes, nightly build
     8 * openlayers.org (root /osgeo/openlayers/sites/openlayers.org) - main website
    1010== Updating the Website & Examples ==
    1111
    12 Periodically, the [source:trunk/openlayers/tools/update_dev_dir.sh] script is run to update the working copy of the [source:/project/website website source], to update the hosted examples with the latest from the trunk, parse metadata from the examples, build an example index, and build a single-file OpenLayers.js.
     12Periodically, the [https://github.com/openlayers/openlayers/blob/master/tools/update_dev_dir.sh update_dev_dir.sh] script is run to update the working copy of the [https://github.com/openlayers/website website source], to update the hosted examples with the latest from the trunk, parse metadata from the examples, build an example index, and build a single-file OpenLayers.js.
    1313
    1414The frequency of this process is determined by a cron job on the openlayers.org machine.  To get details on this job, run the following:
    1919If there are conflicts in the update for some reason, this job may fail.  If you clean things up in the target directory or otherwise need to manually run this job, do so as the {{{openlayers}}} user:
    2020{{{
    21 sudo -u openlayers /osgeo/openlayers/docs/dev/tools/update_dev_dir.sh
    22 }}}
    23
    24 '''Note''' The update script only updates the website if the library source (not the website source) has been changed since the last time the update ran.  To update the website manually, run the following:
    25 {{{
    26 sudo -u openlayers svn up /osgeo/openlayers/docs
     21sudo -u openlayers /osgeo/openlayers/repos/openlayers/tools/update_dev_dir.sh
    2722}}}
    2823
    2924=== Modifying the Website ===
    3025
    31 You can check out the [browser:project/website website sources] from the repository, make local modifications, and see what those changes are going to look like on the live site before committing them.  To do this, you'll need to modify your Apache config to process the SSI directives in the website markup.  In addition, it is convenient to proxy the requests to {{{/api/OpenLayers.js}}}.  Below is a sample config section that handles requests to http://ol-localhost/:
     26You can check out the [https://github.com/openlayers/website website sources] from the repository, make local modifications, and see what those changes are going to look like on the live site before committing them.  To do this, you'll need to modify your Apache config to process the SSI directives in the website markup.  In addition, it is convenient to proxy the requests to {{{/api/OpenLayers.js}}}.  Below is a sample config section that handles requests to http://ol-localhost/:
    3227
    3328{{{
