Changes between Version 87 and Version 88 of Documentation
- 06/27/12 14:33:39 (12 months ago)
Documentation
v87 v88 25 25 Automatically generated API documentation is available: 26 26 27 * [http://dev.openlayers.org/releases/OpenLayers-2.1 1/doc/apidocs/files/OpenLayers-js.html 2.11(Last stable release) API Natural Docs on dev.openlayers.org].27 * [http://dev.openlayers.org/releases/OpenLayers-2.12/doc/apidocs/files/OpenLayers-js.html 2.12 (Last stable release) API Natural Docs on dev.openlayers.org]. 28 28 * [http://dev.openlayers.org/apidocs/files/OpenLayers-js.html Trunk API Natural Docs on dev.openlayers.org]. 29 29 … … 36 36 The documentation above only includes the API Methods. Full developer/internal library documentation is also available below, but methods which are not available in the API documentation above can not be depended upon to stay the same between releases. If you use methods included in these docs, you may have to make modifications in your application code to run between minor releases of !OpenLayers. 37 37 38 * [http://dev.openlayers.org/releases/OpenLayers-2.1 1/doc/devdocs/files/OpenLayers-js.html 2.11(Last stable release) Developer Library Natural Docs on dev.openlayers.org]38 * [http://dev.openlayers.org/releases/OpenLayers-2.12/doc/devdocs/files/OpenLayers-js.html 2.12 (Last stable release) Developer Library Natural Docs on dev.openlayers.org] 39 39 * [http://dev.openlayers.org/docs/files/OpenLayers-js.html Trunk Developer Library Natural Docs on dev.openlayers.org] 40 40
