Changes between Version 82 and Version 83 of Documentation
Show
09/12/11 10:22:10 (20 months ago)
marcjansen
reference api docs for 2.11
  • Documentation
    v82 v83
    2525Automatically generated API documentation is available:
    2626
    27  * [http://dev.openlayers.org/releases/OpenLayers-2.10/doc/apidocs/files/OpenLayers-js.html 2.10 (Last stable release) API Natural Docs on dev.openlayers.org].
     27 * [http://dev.openlayers.org/releases/OpenLayers-2.11/doc/apidocs/files/OpenLayers-js.html 2.11 (Last stable release) API Natural Docs on dev.openlayers.org].
    2828 * [http://dev.openlayers.org/apidocs/files/OpenLayers-js.html Trunk API Natural Docs on dev.openlayers.org].
    2929
    3636The documentation above only includes the API Methods. Full developer/internal library documentation is also available below, but methods which are not available in the API documentation above can not be depended upon to stay the same between releases. If you use methods included in these docs, you may have to make modifications in your application code to run between minor releases of !OpenLayers.
    3737
    38  * [http://dev.openlayers.org/releases/OpenLayers-2.10/doc/devdocs/files/OpenLayers-js.html 2.10 (Last stable release) Developer Library Natural Docs on dev.openlayers.org]
     38 * [http://dev.openlayers.org/releases/OpenLayers-2.11/doc/devdocs/files/OpenLayers-js.html 2.11 (Last stable release) Developer Library Natural Docs on dev.openlayers.org]
    3939 * [http://dev.openlayers.org/docs/files/OpenLayers-js.html Trunk Developer Library Natural Docs on dev.openlayers.org]
    4040
