Changes between Version 15 and Version 16 of BusinessCase
- 08/14/11 06:37:12 (22 months ago)
BusinessCase
v15 v16 14 14 A data provider afraid of letting users easily choose between their maps and others would not like !OpenLayers. Data providers confident in their data offering, cartographic styling, and licensing model should love !OpenLayers for making it easier for people to consume their data. Using API keys, data providers can '''charge for access''' and levels of usage. As a framework, !OpenLayers simply enables this free market. 15 15 16 If you are a data vendor thinking of offering an API to your data, then consider using !OpenLayers to build that API. No need to re-write all this AJAX yourself. Leverage the open source community and invest in your core. If you have intellectual property in a mapping GUI, then use !OpenLayers as a building block. !OpenLayers is BSD licensed specifically so you can incorporate it in proprietary GUIs.16 If you are a data vendor thinking of offering an API to your data, then consider using !OpenLayers to build that API. No need to re-write all this AJAX yourself. Leverage the open source community and invest in your core. If you have intellectual property in a [http://www.mycaal.com/ loan modification] mapping GUI, then use !OpenLayers as a building block. !OpenLayers is BSD licensed specifically so you can incorporate it in proprietary GUIs. 17 17 18 18
