Changes between Version 3 and Version 4 of WikiPageNames
Feb 1, 2017 12:38:20 AM (2 years ago)
  • WikiPageNames
    v3 v4
    1919   and with a label: [wiki:"Space Matters" all about white space]
    2020 * or simply: ["WikiPageName"]s
    21  * even better, the new [[WikiCreole link style]]
     21 * even better, the [[WikiCreole link style]]
    2222   and with a label: [[WikiCreole link style|WikiCreole style links]]
    2323}}}
    2929   and with a label: [wiki:"Space Matters" all about white space]
    3030 * or simply: ["WikiPageName"]s
    31  * even better, the new [[WikiCreole link style]]
     31 * even better, the [[WikiCreole link style]]
    3232   and with a label: [[WikiCreole link style|WikiCreole style links]]
    3333
    3434It is possible to link to a specific ''version'' of a Wiki page as you would do for a specific version of a file, for example: WikiStart@1.
    3535
    36 You can also prevent a !CamelCase name from being interpreted as a [TracLinks link] by quoting it with an exclamation mark: `!CamelCase`. See TracLinks#EscapingLinks.
     36You can prevent a !CamelCase name from being interpreted as a [TracLinks link] by quoting it with an exclamation mark: `!CamelCase`. See TracLinks#EscapingLinks.
    3737
    38 As in the example above, you can also append an anchor to a Wiki page name to link to a specific section within that page. The anchor can be seen by hovering the mouse over a section heading, then clicking on the [[html(¶)]] sign that appears at its end. The anchor is usually generated automatically, but it is also possible to specify it explicitly: see WikiFormatting#using-explicit-id-in-heading.
     38As in the example above, you can append an anchor to a Wiki page name to link to a specific section within that page. The anchor can be seen by hovering the mouse over a section heading, then clicking on the [[html(¶)]] sign that appears at its end. The anchor is usually generated automatically, but it is also possible to specify it explicitly: see WikiFormatting#using-explicit-id-in-heading.
     39
     40There are a few options that govern the rendering of WikiPageNames:
     41* CamelCase linking to missing pages can be disabled with the `ignore_missing_pages` [https://trac.edgewall.org/wiki/TracIni#wiki-section option]. Linking to missing pages is enabled by default.
     42* The `split_page_names` option, when enabled, will split CamelCase words when rendering a link. For example, WikiStart will be rendered as [WikiStart Wiki Start].
    3943
    4044----
